Some of you might remember I had posted a spotty problem with my fan/blower cutting off by itself. Others have too. When it happened I would have to turn off the fan and then turn it back on and it would work fine. I could never get it to repeat itself for the Dealer. This started happening just a couple of weeks after taking delivery in May of '05. It would only happen, as I recall, when using the A/C. Finally, the other day I was sitting in a parking lot with the A/C on and the fan quit without any imput from me. I was a couple of miles from the Dealer and I took it to them so they could observe it happening. The tech, after putting a tester on the blower control, said it was the resistor in the "Variable Blower Control Module" located under the glove box. It is a $56.95 part. Part number 27151-5Z000. It is an easy install. Just two screws and the power plug. Hope this helps you other folks who have the same issue. Time will tell if this new module will permanantly solve the problem. I will let you know if it happens again.
Titan 5.6/It's the price we pay for the power we want / 2005 SE 4X4/ Red Alert/ Crew Cab/ Big Tow pkg/ SE Popular pkg/ Westin stainless nerf bars / Truxedo bed cover/ AccuPower-USA POD brake controler/ LineX Bedliner
The fan in my Xterra recently started only working on level 4 (high). Turns out this is a common problem with the Xterra & the solution was the same as yours. A new blower resistor. It was a $25 part & took 10 minutes to replace. Location was also under the glove box. Works perfectly now.
It's been eight months now and the problem has never repeated. Looks like the new module is the permanent fix.
Do you know if the module had three fins or five. The five fin is the fix for the problem. The old dealer stock may not have been upgraded yet. The three fin did not have enough surface area to dissipate the heat from the power transistor in the module.
New module has five fins. I did not think to look and count the old modules fins.
Did not think about the heat disipation either but it makes sense. Good point.
Tried it today and my a/c was still broken. This makes the 3rd repair attempt. They are sending someone from Nissan to check it out now.
Turbo system by me, tuned by Bully Dog
444hp and 512ft lbs at the wheels on 91 octane
The trouble with doing something right the first time is that nobody appreciates how difficult it was. http://www.youtube.com/watch?v=gw8srjVVVXI
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
