Help with axle shaft removal - Nissan Titan Forum
post #1 of 8 Old 12-09-2012, 06:27 PM Thread Starter
Drummer0314
Drummer0314's Avatar
I am trying to pull the axle shafts out of the diff. any ideas whats holding them to the LSD. I have everything off that can come off still nothing. Any ideas?
2008 Nissan Titan CC XE Majestic Blue, Big Tow, Dynomax Bullets, Xtreme Rhino-Lined Badges, 6" Pro Comp Lift (Stage I), Alpine IVA-W505, MTX 604, MTX 801D, 20x8.5, +10 Offset XD775 Rockstars, 35x12.50x20 Toyo M/T's.
Drummer0314 is offline
post #2 of 8 Old 12-09-2012, 09:21 PM
04titanss
Moderator
04titanss's Avatar
Quoted: 2 Post(s)
A long pry bar wedged bewteen the axle flange and backing plate is all I needed to pop the axle out of my housing. Nothing holds them in to the carrier, remove the 4 nuts off the axle retainer, behind the backing plate, and all should pop out.
2004 XE KC Performance Mods: UNDER GROUND
Quickest UNTUNED Titan 13.900 @ 96.67mph
N/A Tuned Non Cammed 13.180@102.31
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
04titanss is offline
post #3 of 8 Old 12-09-2012, 10:18 PM Thread Starter
Drummer0314
so the plates on each side of the LSD and ring gear assembly and they should just slide out? What holds them in?
post #4 of 8 Old 12-09-2012, 10:19 PM Thread Starter
Drummer0314
never mind I see what your saying I have all that off so the spines are the only thing holding them in?
post #5 of 8 Old 12-09-2012, 11:32 PM
HRTKD
HRTKD's Avatar
Quoted: 3 Post(s)
I believe there is a square bracket with four bolts (that come through the brake backing plate towards the inside) that holds the shaft in.
«Granite '07 LE Crew Cab, 4x4, Big Tow, Off-Road, Side Curtain Airbags, Sunroof»
«ClearBra, Leer 100XQ, MM SI9500 Winch, Volant PowerCore, 18" Magnaflow, AMSoil in everything»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Berk Technology B-Pipes»
Jim
HRTKD is offline
post #6 of 8 Old 12-10-2012, 01:03 PM
04titanss
Moderator
04titanss's Avatar
Quoted: 2 Post(s)
That only holds the backlash/preload adjuster. With every thing removed the axles should come out with a little force. With the spider gears coming apart in yours, some of the material may have wedged itself between the splines. May have to rent a slide hammer from the local auto parts store to get the axle out.
post #7 of 8 Old 12-10-2012, 10:33 PM Thread Starter
Drummer0314
I work for a family business which is a shipyard and we have huge slide hammer to remove 3 inch diameter shaft out of yachts, and still it wont budge. I guess next its off to putting a portable hydraulic press on it.
post #8 of 8 Old 12-11-2012, 12:30 AM
04titanss
Moderator
04titanss's Avatar
Quoted: 2 Post(s)
Post some pics before you put the hydro on it.
Rear Axle shaft and seals. gebeaird General Discussion 2 10-14-2011 08:52 AM
Drive shaft removal HELP! AlwaysBeingDumb Technical Discussion 2 09-03-2011 12:06 AM
wtb a true trac a uprev and a body lift and a rear axle shaft williamseng1 For Sale/For Trade 1 06-03-2010 07:10 PM
Axle Shaft Wes13_07TITAN General Discussion 2 11-25-2009 05:50 PM
axle shaft replacement q TitanLE General Discussion 4 03-19-2008 12:27 AM
