How hard to remove drivers floorboard Carpet? - Nissan Titan Forum: Club Titan Forums
Nissan Titan Forum Nissan Titan Forum
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Nissan Titan Forum: Club Titan Forums > Nissan Titan Forums > General Discussion
Please Visit our Site Sponsors
ClubTitan.org is the premier Nissan Titan Forum on the internet. Registered Users do not see the above ads.
  #1
Old 12-11-2012, 04:12 PM
BigA's Avatar
BigA BigA is offline
Shift_Hardcore
I noticed I have damp to wet carpet under my drivers side floor mat. When I get moved back to OH next weekend I want to pull the carpet to see if I can find the leak. How do I remove the carpet from the front floorboard? I would assume thiers a seam somewhere between the front and the back?
2005 Nissan Titan SE 4x2 Radiant Silver, Big Tow, Popular Package with Captains chairs, OEM Foglights, Bugsheild, Bedliner, XM/Sirius Radio
  #2
Old 12-11-2012, 07:00 PM
scr38's Avatar
scr38 scr38 is online now
Administrator
I think the carpet is one piece. You will have to remove the seats, seat belt anchors, center console (if you have one) and the thresholds and kick panels.
  #3
Old 12-12-2012, 08:21 AM
BigA's Avatar
Shift_Hardcore
OK, yea I'm not going to do all that, I'll just have to pull back the drivers side as much as I can then get the garden hose out and check for leaks.
  #4
Old 12-13-2012, 12:55 AM
goodkill's Avatar
goodkill goodkill is offline
its a AC hose,its a $10 Home Depot fix carpet should peel back pretty easy. i did my passenger side a few months ago.
http://www.dirtkingfabrication.com/
http://legitaccessories.com/
Recognizing that I volunteered as a Ranger, fully knowing the hazards of my chosen profession, I will always endeavor to uphold the prestige, honor, and high esprit de corps of the Rangers.
  #5
Old 12-29-2012, 01:57 AM
PAPARYNO's Avatar
PAPARYNO PAPARYNO is offline
How do u fix it. Where is the write up?
Sent from my iPhone using AutoGuide.com App
06 TITAN LE CC 4X2 Loaded w/Nav & DVD,BT, ValentineRD, G-Tech, TrueTrac,
AEM BruteForce CAI, Stillen LongTubes and Fr&R Swaybars, Jwt Cams, Uprev,
Magnaflow 50 Duals, NX 75Shot w/RemoteOpener, PRG Trac Bars & Fr. Leveler
Stock> 0-60mph 7.81sec. 1/4mile 16.01sec.@87.0mph
Mods> 0-60mph 5.21sec. 1/4mile 13.67sec..@99.93mph
DT Dyno SAE #'s N/A Map 325.71 RWHP / 364.06 TQ
DT Dyno SAE #'s NX100 Map 458RWHP / 518RWTQ !!!
  #6
Old 12-29-2012, 05:01 PM
BigA's Avatar
Shift_Hardcore
Would the AC cause the drivers side to be wet? I thought the drain was on the passenger side? It being winter I have not run the AC lately, but the AC runs when the defrost is on correct? The AC has begun to have a mildew like smell when I first turn it on. I did pull the carpet back and couldn't find anything. I did find a seam gap on the underside on the transmission tunnel and I sealed that up.
  #7
Old 12-29-2012, 11:06 PM
sht06's Avatar
sht06 sht06 is offline
Could be back window due to the stance of truck.That's 06 and newer with big back glass.Mine ran the gully from back to front floor board.The noise/heat insulation acts like a sponge. And yes A/C dose run when you select defrost.But I would start with seal around back glass.There was a T.B about squirting silicone in the large gap around back glass.Mine would leak after heavy rains.
Advise for racers/hard drivers KINGMADE General Discussion 18 10-27-2008 02:11 AM
wet floorboard timothyodell2525 Technical Discussion 1 04-06-2008 11:32 PM
Help, Wet Floorboard?!?!?! SniperT38 General Discussion 6 01-04-2007 08:30 PM
Wet Floorboard BigShowJoe General Discussion 5 10-14-2005 12:56 PM
front floorboard still wet galaxy Technical Discussion 10 08-26-2005 08:05 AM
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin®
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
