Rear Axle Ring and Pinion Failure! - Page 2 - Nissan Titan Forum: Club Titan Forums
Nissan Titan Forum Nissan Titan Forum
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Nissan Titan Forum: Club Titan Forums > Nissan Titan Forums > General Discussion
Please Visit our Site Sponsors
ClubTitan.org is the premier Nissan Titan Forum on the internet. Registered Users do not see the above ads.
  #11
Old 12-05-2012, 07:19 AM
CrashBoss CrashBoss is offline
Man...never seen one disintergrate like that...sucks.
justdifferentials (site sponsor) just posted that they have full axle assys...might give them a try.
05 KC 2x Big Tow LE-Injen CAI, Armada Lip, Volant LED tails, led 3rd lamp, DDM HID 55W high, 35W low, 880 fog all 5000K, Lorado tonneau.
  #12
Old 12-05-2012, 11:56 AM
04titanss's Avatar
04titanss 04titanss is offline
Moderator
The spider gears is what breakers in the 04-07 axles, this would be the first for the improved 08-Up design.
Guess Nissan only improved the axle bearings and seals and left the carrier with the same weak spider gears.
2004 XE KC Performance Mods: UNDER GROUND
Quickest UNTUNED Titan 13.900 @ 96.67mph
N/A Tuned Non Cammed 13.180@102.31
04 XE Mod List
Rosetta Stone by HRTKD Part Number List by baseballfanz
07 Pipes w/ 22" M/F Sound Clip
  #13
Old 12-11-2012, 04:48 AM
NBhunter80's Avatar
NBhunter80 NBhunter80 is offline
Yeah, unfortunately that's a common failure for the spider gears to disintegrate like that. I have seen quite a few in my days. And you are correct, the '08+ have the exact same spider gears as the '05-07 Titans. It was only the axle seals and bearings that were changed in 2008. The early '04 rear ends had an even crappier spider gear design, but mid '05 model year to current is all the same as far as carrier design. Anyway, it's a good thing your R&P gears survived. Just grab yourself a truetrac or ARB air locker and it will be better than new. Good luck!
2005 LE King Cab 4x4 Offroad Big Tow FFV, Purchased used on 2008/11/30.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, 33 x12.50r17LT Hercules Trail Digger tires on OEM OR 7-spoke 17" rims, 3" Rough country Lift, Bilstein 5100s front and rear, Hawk LTS brake pads, MOOG lower ball joints, 2011 Pro4x rear end, Axle vent mod, NGK iridium spark plugs, 2 degree timing advance, Stock airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
  #14
Old 12-14-2012, 05:39 PM
Drummer0314's Avatar
Drummer0314 Drummer0314 is offline
with the ring and pinion still intake if I purchased a trutrac will i need to do any shimming or alignment?
2008 Nissan Titan CC XE Majestic Blue, Big Tow, Dynomax Bullets, Xtreme Rhino-Lined Badges, 6" Pro Comp Lift (Stage I), Alpine IVA-W505, MTX 604, MTX 801D, 20x8.5, +10 Offset XD775 Rockstars, 35x12.50x20 Toyo M/T's.
  #15
Old 12-15-2012, 08:28 AM
TA CC TX's Avatar
TA CC TX TA CC TX is offline
This is pretty dang complete, take it as far as you want,,,,http://www.titantalk.com/forums/tita...f-install.html
04 cc bt offroad pkg / RB UPREV Tuned / DTLT's/ JBA catback/16" Borla XR-1/ vibrant UQ resonator/ Custom Cajun Catless B-pipes/Airaid MXP CAI/ 4" Air mod/ 07+ manifold/ TruTrac/ MagHytech Diff cover/ Long tru-cool transmission cooler/T-B mod/ 170* thermostat/ H-D's all corners/ Curt front hitch/ BrakePerformance slotted and dimpled rotors/Hellwigg traction springs/Airlift air bags/ ARB onboard air/2" Drop shackles/ Wolo powerhouse air horn! On wall at Cafe in Dripping Springs,Texas " I spent most of my money on Wine ,Women and Song ,the rest I just blew"
  #16
Old 12-21-2012, 08:57 AM
giocascio giocascio is offline
at stealership have warranty and noticed i have no axle vent so i may not be 2 far behind you. they're trying to charge me to check oil in diff and put in vent/ breather and assess they're ignorence when they actually worked on my rear end b4 i bought truck since i bought warranty. if nothings broke its not covered so dumb
  #17
Old 12-23-2012, 11:27 PM
Wyatt's Avatar
Wyatt Wyatt is offline
Shift_Newbie
I have an 04 2 wheel drive. At around 120k..one afternoon heading home from work the rearend started with a wining noise...then a metal on metal grind,...turned it around midway home and started back to work....about 25mins in - a pop noise as I pulled back into work.....NOT GOOD
Was sooo pissed at Nissan, I wrote a letter to corporate. Got a Rep that said,...well its out of warranty? I said check out the web,...their are a lot of these same rearend malfunction issues with faithful Titan owners!! Didn't care
I certainly did not want another Nissan OEM replacement!!
I found a differential company that developed a stronger true Dana 60\44 set up with 3:31 gears-LOVE IT...LOVE IT!! Its a costly expense, but I did'nt want this to happen again!
I'm a die hard Titan owner....can't seem to put it up for sale-It just does everything I throw at it and more!!
  #18
Old 12-24-2012, 07:54 AM
04titanss's Avatar
Moderator
Got yours from Currie?
04 XE Mod List
  #19
Old 12-24-2012, 10:02 AM
Wyatt's Avatar
Shift_Newbie
I had it done at AZ DIFFERENTIAL in Phoenix Arizona. They actually build them, not sure what they call it.
WTB: 3.36 Rear Ring and Pinion or Axle for 04 N20ntegra24 For Sale/For Trade 0 08-17-2011 10:28 PM
WTB Rear End and/or Ring and Pinion for '05 Jeff0825 For Sale/For Trade 7 02-11-2009 03:59 PM
Need BT Ring and pinion chrisfuji For Sale/For Trade 16 11-09-2007 10:23 PM
Rear Axle Seall Failure at 16K Miles Jaho1979 General Discussion 17 11-09-2007 02:12 AM
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin®
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
