Here is some reading material...
Technical Service Bulletins as of 11/2005
NTB04105
Nissan has determined that some 2004 model year Nissan Titan vehicles may have a defect which relates to motor vehicle safety. There is a possibility that the transmission shift lever assembly for the column shifter may have been damaged during manufacture. The damage could eventually result in the failure of the portion of the assembly that holds the shift lever in the "Park" position when the key is not in the ignition or when the key is in the "Lock", "Off" or "Accessory" position. This would allowthe shift lever to be capable of being moved from "Park" without the key or when the ignition is in a position other than "On". In some situations, the ability of the shift lever to be moved out of the Park position could result in rollaway of the vehicle and cause a crash. To prevent this condition from occurring, Nissan is conducting a Voluntary Safety Recall Campaign to replace the shift lever assembly.
NTB04109
IF YOU CONFIRM: DTC P1774 (LC/B SOLENOID FNCT) is stored, and the transmission fluid is not burnt, NOTE: P1730 and/or P1731 may be stored with P1774. ACTIONS: Step A: Confirm this bulletin applies: Check the Current TCM Part Number Compare your Current TCM Part Number to Chart A. If that part number does not match one in Chart A, this bulletin does not apply. Go back to ASIST for further diagnostic and repair information. Step B: Reprogram the TCM See this bulletin for further detail
NTB05022
IF YOU CONFIRM: ATF is leaking from a transmission air cooler line: The line from tube to air cooler, Or The line from air cooler to radiator, ACTION: Replace the leaking cooler line. Both early and later type cooler lines are available. See this bulletin for further detail.
NTB05029
IF YOU CONFIRM: A "squeak" and/or "tick" noise coming from the left and/or right front seat cushion. ACTIONS: 1. Scuff the edges on the back side of the power seat switch trim. 2. Apply Dupont Krytox?Lubricant GPL-105 (or equivalent) to the bottom edge of the front seat cushion and around the outer edge of the power seat switch trim. See this bulletin for further detail.
NTB05017
IF YOU CONFIRM A ticking noise at the front LH and/or front RH window with the window partially rolled down over rough/uneven roads or when the the door is closed and holding the glass stationary under the same condtions eliminates the noise. ACTION Order the required parts, in the Parts Information section, and perform the repair as stated in the Service Procedure. See this bulletin for further detail.
NTB05016
IF YOU CONFIRM: An applied vehicle has a Sunroof Sunshade with worn or ripped fabric in the area shown in Figure 1 (below). ACTION: Replace the Sunroof Sunshade without removing the Headliner or Sunroof Track Assembly. See the Service Procedure for details.
NTB05046
IF YOU CONFIRM: A ticking or creaking type noise coming from a left or right front door, DETERMINE IF: This bulletin applies (see steps 1 and 2 of the Service Procedure). ACTIONS: 1. Clean the upper body side seal. 2. Apply DuPont Krytox?Lubricant-GPL-105 to the upper body side seal. 3. Test drive the vehicle, if the noise is still there remove the door finisher, separate door sheet metal, and install felt cloth tape as shown in step 11 of the Service Procedure in this bulletin. See this bulletin for further detail.
NTB05083
IF YOU CONFIRM An applied vehicle has a Durabed?spray-in bedliner that is discolored (milky-white surface), ACTION Use the below noted materials and Service Procedure to refinish the bedliner.
NTB05004
IF YOU CONFIRM: Water is leaking from the Rear Sliding Window Track into the passenger compartment (see Figure 1). ACTION: Add drain holes to the Rear Sliding Window Track (see Figure 1). Drill through the window track and glass sealant so the water can escape to the outside of the vehicle. Refer to the Service Procedure for details.
NTB05014
SERVICE INFORMATION The All Season Rubber Winter Floor Mat should be installed on existing carpeting, never on top of another floor mat. DO NOT install (stack) the All Season Rubber Winter Floor Mat on top of any other floor mat, to avoid interference with pedal operation. See this bulletin for further detail.
NTB05077
IF YOU CONFIRM The passenger seat does not recline or tilt forward when lifting UP on the recliner handle. ACTION - Remove the seat and use a steel split spring pin (roll pin) to repair shaft of inboard recliner mechanism. - This will prevent theinboard recliner mechanism pin from slipping inside the shaft. See this bulletin for further detail.
NTB01087
IF YOU CONFIRM: There are environmental particles in the paint. NOTE: Environmental particles can be identified as follows: On light-colored painted surfaces or on the Bedliner: Small rust/orange dots with black centers. On dark-colored painted surfaces: Small white or silver dots with a "rainbow hue" around the edge on dark colored surfaces. In both cases, the surface will feel rough or gritty to the touch. ACTION: Perform the steps in the Service Procedure. NOTE: The steps in the Service Procedure have been found effective in most cases for removing environmental iron particles (sometimes called "rail dust") from a vehicle's painted surfaces. See this bulletin for further detail.
NTB04064
If you should need to service the window regulator or motor on an Applied model, removing the door window is no longer needed. See the chart in this bulletin to find out which revised service procedure applies to the vehicle you are working on.
NTB05092
IF YOU CONFIRM An unoccupied front passenger seat back rattles and moves side-to-side when driven Over speed bumps at 5 mph or above On bumpy roads at 15 mph or above ACTION Remove the seat from the vehicle. Remove the seat cushion, apply thread locker to 4 existing screws, and reinforce the seat by adding pop rivets as per the Service Information section of this bulletin. See this bulletin for further detail.
NTB05002
IF YOU CONFIRM: An applied vehicle has damage to the Spray-In Bedliner smaller than 1 inch in diameter. ACTION: Refer to the Repair Level Definitions (page 3) to find out what action is needed to repair the Spray-In Bedliner. See this bulletin forfurther detail. NOTE: If an Applied Vehicle spray-in bedliner is discolored (milky white surface), this TSB doesn't apply. Please see NTB05-044 for discoloration.
NTB04066
IF YOU CONFIRM: While braking, especially when braking at highway speeds: ?A steering wheel shake, ?Body vibration, or ?Brake pedal pulsation (also known as "brake judder"). ACTIONS: Closely follow the entire Service Procedure in this bulletin, as it contains information that is essential to successfully completing this repair. See this bulletin for further detail.
NTB04104
IF YOU CONFIRM: The customer says the brake pedal feels "Mushy", "Soft", or the pedal stroke feels too long, ACTIONS: 1. Check and adjust the brake pedal height. 2. If adjustment of the brake pedal height does not correct the "pedal feel", refer to ASIST for additional brake inspection and repair information. See this bulletin for further detail.
NTB00033
SERVICE INFORMATION This bulletin is to assist you in responding to customer questions about brake operation, and provides diagnostic and repair information for each item listed, if any should occur. Most brake incidents fall into the following categories: a. Brake Noise: A squeak, squeal, clunk, or groan that occurs when the brakes are applied or released. b. Brake Judder: A vibration that can be felt in the vehicle, steering wheel, or brake pedal when the brakes are applied. c. Pedal Feel:The effort needed to operate the brakes is too high or too low. SERVICE PROCEDURE 1. Verify the condition by road testing the vehicle with the customer. 2. Determine the specific brake incident based on the description in the Service Information above. 3. Follow the appropriate repair procedure(s), listed on the following pages, for your specific incident. See this bulletin for further details.
NTB04094
If YOU CONFIRM: A vehicle needs to have the brake rotors resurfaced (front or rear), ACTION: Use the ProCut?PFM Series on-car brake lathe to perform brake rotor resurfacing and follow the tips listed in this bulletin.
NTB05086
Nissan is committed to providing the highest levels of product quality and customer satisfaction. We know that towing a trailer may have been an important consideration in the customer's purchase decision. In new Titan, Armada, Frontier, Pathfinder, and Xterra vehicles, Nissan recently introduced enhanced electronic circuitry which may help further protect a vehicle from damage or fire caused by a short circuit in the electrical system of a towed trailer due to problems with the trailer's wiring or mis-installation of trailer lighting or electrical accessories. Nissan is making this production enhancement available to owners of previously purchased vehicles so that they will have the same protection should they ever tow a trailer with a defective electrical system.
NTB04010
If, for any reason, you have to replace the BCM in an applied vehicle, please note that the H/L Bulb configuration (for the new BCM) must be set to "HID". It doesn't matter if the vehicle is equipped with Halogen or Xenon headlamps.
NTB04138
IF YOU CONFIRM: Either of the Front Door Power Windows: Will not go UP when using the "AUTO UP" feature, Otherwise operate normally. NOTE: This incident, if it occurs, may be intermittent. ACTIONS: Replace both the driver's-side and the passenger's-side Front Door Power Window Switch units. Use the parts listed in the Parts Information section of this bulletin. Refer to Section "EI" DOOR FINISHER Removal and Installation in the appropriate Electronic Service Manual, if needed. See this bulletin for further detail.
NTB04102
IF YOU CONFIRM: The rear sonar "beeps" continuously when the transmission is put into reverse and there is nothing behind the vehicle. ACTIONS: ?Check the Sonar Control Unit, and replace if necessary. ?Check the Sonar Sensors, and replace if necessary. See this bulletin for further detail.
NTB03101
SERVICE INFORMATION Applied Vehicles equipped with the trailer towing package: ?Are supplied with a jumper harness for use with an electric trailer brake controller. ?This jumper harness is placed in the glove box at the factory. ?This jumper harness is used to connect an electric trailer brake controller to the vehicle harness. See this bulletin for further detail.
NTB04082
IF YOU CONFIRM: ?The Intelligent Cruise Control (ICC) and Automatic Speed Control Device (ASCD) on an applied vehicle is inoperative. ACTION: ?Use CONSULT to confirm the incident. ?If needed, adjust the ASCD Cancel Switch (brown upper switch). ?Refer to the Service Procedure for details.
NTB04131
IF YOU CONFIRM any of the following: - The engine will not crank (starter will not operate). - The engine cranks but will not start. - Code U1000 and/or U1001 (CAN COMUNICATION LINE) is stored in the ECM. - TCM, BCM and/or IPDM will not display onthe CONSULT-II Systems screen. - The transmission doesn't function properly (i.e. harsh shift, slips, improper shift timing, etc.). DETERMINE IF: Connector F9 has water or corrosion. NOTE: If there is no water or corrosion in the connector, thisbulletin does not apply. Go back to ASIST for further diagnostic and repair information. ACTIONS: Replace the entire Engine Control Harness and the A/T assembly Harness Connector. See this bulletin for further detail.
NTB99048
SERVICE INFORMATION The "Micro 620" is the factory-approved battery tester. - Use of the "Micro 620" tool is required when testing any Nissan original equipment battery for warranty adjustment purposes. - Use of the "Micro 620" tool is required when testing any Genuine Nissan replacement battery for warranty adjustment purposes. When setting up the "Micro 620" for testing, a battery CCA (Cold Cranking Amps) rating is required. - This bulletin has charts which contain this CCA rating information. - One chart is for Nissan original equipment batteries, and the other is for Genuine Nissan replacement batteries. See this bulletin for further details.
NTB04087
IF YOU CONFIRM: While listening to FM radio while driving, the treble fades in and out, and/or the radio switches from stereo to mono. ACTION: Replace the radio head unit. Order the replacement through the Panasonic Exchange Program. When ordering the replacement unit, you need to give Panasonic the radio head unit's number. The part number will begin with "28185". To determine the radio part number: Refer to the audio matrix section of the most current Dealer Parts Book/CD. The matrix lists part no. information by audio component, vehicle model and model year. It also identifies the supplier of the audio component. or Use the WINFAST parts system by entering the full VIN. For radio head unit replacement information, refer tosection AV in the appropriate Service Manual (ESM). See this bulletin for further detail.
NTB04099
IF YOU CONFIRM: The navigation system is inoperative and the display shows "Disc Error", or "DVD-ROM version is not correct." NOTE: This incident, if it occurs, may be intermittent. ACTION: Replace the navigation control unit. See this bulletin for further detail.
NTB05061
SERVICE INFORMATION When installing the glass-mounted antenna for XM radio, make sure to closely follow the instructions supplied with the installation kit. This bulletin is provided to emphasize some key steps in the installation instructions thatrequire special attention. See this bulletin for further detail.
NTB04034
SERVICE INFORMATION If a DVD player incident occurs: ?Incorrect DVD care or usage may be a possible cause. ?Or, a defective DVD may have been used. This bulletin provides important information on DVD usage and care. ?This will helpto avoid DVD incidents/customer concerns. ?It also contains information on removing a jammed DVD from the player. See this bulletin for further detail.
NTB04111
IF YOU CONFIRM: A "No Crank" (starter doesn't work) incident under all of the following conditions: 1. The vehicle sat for several hours (cold soak) with outside temperatures below 10?F (-12?C); and 2. The vehicle was then driven for a short periodof time (5-10 minutes); and 3. The engine was then turned OFF for a short time (5-10 minutes); and 4. The engine would then not crank when a restart was attempted (starter doesn't work). NOTE: This TSB applies only if all of the above occurred. ACTION: Replace the Intelligent Power Distribution Module-IPDM (see the Parts Information). ?For IPDM replacement instructions, go to the Service Manual (ESM) > section PG > Removal and Installation of IPDM E/R See this bulletin for further detail.
NTB03031
SERVICE INFORMATION ?This bulletin covers the latest version of the Nissan Vehicle Immobilizer System/Nissan Anti-Theft System (NVIS/NATS). ?This version of NATS uses advanced anti-theft functions which are "password protected". This helps prevent "unauthorized access" into the NATS registration procedure. ?To obtain the password from ASIST, CONSULT-II is used to pull up the "BCM-specific" 5-digit number (PIN) code. IMPORTANT: The NATS "Control Unit (C/U) Initialization and Key Registration" Procedure in this bulletin is for the Applied Vehicles in this bulletin. Do not use this procedure on earlier NATS-equipped vehicles. See this bulletin for further detail.
NTB05062
SERVICE INFORMATION This bulletin supplements the diagnostic and repair information in the Electronic Service Manual (ESM) for the factory installed auto dimming mirror with compass. When servicing the auto dimming mirror or compass, refer to the information in this bulletin along with the repair information contained in the ESM. See this bulletin for further detail.
NTB99067
SERVICE INFORMATION Some of the Applied Vehicles, as an option, feature the Nissan Integrated HomeLink Transmitter system. This Radio Frequency (RF) system can be programmed to activate most RF-operated electronic garage doors and security gates. A laminated card contained in the vehicle's Literature Kit covers the simple programming instructions. A copy of this card is included in this bulletin as Attachment II. Programming instructions can also be downloaded at
www.homelink.com. This bulletin summarizes important customer support and diagnostic information for Nissan dealership staff. See this bulletin for further detail.
NTB05076
IF YOU CONFIRM The map disc for the DVD-based navigation system must be replaced or updated for any reason, ACTION Use the information in this bulletin to identify the current DVD map disc series and select the correct replacement DVD part number. See this bulletin for further detail.
NTB04001
IF YOU CONFIRM: The Remote Keyless Entry keyfob of an Applied Vehicle needs to be replaced for any reason. ACTIONS: The keyfob is now available as 2 separate service parts: the cover (outer shell), and the print board assembly (inner circuit pad). See this bulletin for further detail.
NTB04119
IF YOU CONFIRM: A satellite (SAT) radio related incident has occurred on a Nissan vehicle factory equipped with SAT radio. ACTIONS: Refer to this bulletin for service and diagnostic information
ITB99037
SERVICE INFORMATION The "Micro 620" is the factory-approved battery tester, essential tool #J-44373. See Figure 1. For Warranty Adjustment Purposes, use of the "Micro 620" tool is required when testing any Infiniti original equipment or Genuine Infiniti Replacement battery. For more information, reference the current "Infiniti Assurance Products Resource Manual", Section 26, Page 1. The Battery Tester Printer and Carrying Case #J- 44373-PRT are recommended to accurately document the test codes for Warranty Claims and protect the tester when not in use. Additional tools can be ordered from TECH-MATE at 1-800-662-2001. When setting up the "Micro 620" for testing, a battery CCA rating is required. - CCA stands for Cold Cranking Amps. This bulletin has charts that contain this CCA rating information. - One chart is for Infiniti original equipment batteries, and the other is for Genuine Infiniti replacement batteries. See this bulletin for further details.
NTB03093
Improper or incorrect service and repair procedures may cause damage to new or repaired parts and components. Damage to repaired or replaced engine, transmission, or other components caused by improper procedures during repair or replacement is not covered by warranty. This TSB contains information to help you avoid damaging these parts and components.
NTB04018
IF YOU CONFIRM: An applied vehicle has any of the following symptoms: ?Leaking radiator ?Overheating cooling system OR If you removed the radiator cap for any other reason. ACTION: ?Look for a "swollen" (enlarged) radiator cap gasket. SeeFigure 1a and 1b. ?An enlarged radiator cap gasket can cause the cap to not vent properly. This can result in coolant loss and overheating. ?See the Service Procedure on page two for more details.
NTB04041
This bulletin introduces the Customer Diagnostic Worksheet. It's a two-page form used to help service advisers "document" (provide information about) the customer's concern. It also makes it easier to communicate these concerns to the technician. See this bulletin for further detail.
NTB04117
IF YOU CONFIRM: A humming noise is coming from the HVAC system during the following 4 conditions: The vehicle is in "front defrost" mode, and the A/C is off, and the temperature is at "max warm", and the fan speed is at #3 or #4. ACTIONS: Replace the Heater Side Link (Cam) assembly. See this bulletin for further detail.
NTB05065
IF YOU CONFIRM: An applied vehicle has the following symptoms during extreme hot temperatures: A/C compressor shuts off when engine is at idle (due to high A/C system pressures) Poor A/C cooling ACTION: Refer to this bulletin for details.
NTB05096
IF YOU CONFIRM The customer reports there is a rattle noise coming from the engine compartment, and the fan assembly has looseness or play at the lower mounting tabs. ACTIONS 1. Remove the condenser fan and apply felt cloth tape to the lower mounting tabs 2. Reinstall the fan using the new attachment bolt listed in the Parts Information of this bulletin. When reinstalling the fan, make sure it's adjusted to the full down position. 3. Test drive the vehicle and make sure the rattle is gone. See this bulletin for further detail.
NTB05008
SERVICE INFORMATION: The rear final drive gear oil specification (for all 2004 Titans) has been changed. The new gear oil is Nissan Synthetic Gear Oil (SAE 75W-140), P/N 999MP-DF100P. See this bulletin for more information.
NTB04086
Nissan has determined that some 2004 model year Nissan Titan King Cab and Crew Cab vehicles fail to comply with Federal Motor Vehicle Safety Standard 201 - Occupant Protection in Interior Impact. FMVSS 201 specifies certain requirements for components of the upper interior of vehicles such as roof rails and pillars to assure they afford appropriate protection in the event an occupant's head strikes the component in a crash. Nissan has determined that an area on the rear pillar where the rear seat beltupper anchor is attached may not be sufficiently energy absorbent. This could result in an increased risk of injury if the area is struck in some types of crashes. All other requirements under FMVSS 201 and other standards are met. To correct this condition, Nissan is conducting a Voluntary Safety Recall Campaign to replace the outboard rear seat belt assemblies with new ones, which have a larger, more energy-absorbent upper D-ring cover and D-ring. This will enable the vehicle to meet the FMVSS 201 standard at this location.
NTB04003
IF YOU CONFIRM: ?The "AIR BAG" warning light is ON, with ?DTC "Passenger Air Bag Indicator Circuit" (B1023) stored, and/or ?The passenger air bag "Status Lamp" does not come ON (it's inoperative), ACTION: ?Replace the Status Lamp with the newone listed in the Parts Information. See this bulletin for further detail.
NTB01005
IF YOU CONFIRM: Seat belt retraction of front seat belt(s) is slow, caused by "residue" build-up on the "D" ring(s), NOTE: Slow seat belt retraction, if it occurs, may result in the following incidents after the seat belt is unbuckled: * Seat belt latch plate hanging up on clothing, * Seat belt latch plate becoming caught in the door, ACTION Use the "D" ring cleaning and refurbishing kit to: * Clean the residue off of the "D" rings. * Apply fluorine resin tape to the "D" rings. See this bulletin for further detail.
NTB04036
IF YOU CONFIRM: An applied vehicle has the following symptoms: ?The "4 LO" light (see Figure 1) is flashing in all the 4WD Shift Switch positions AND/OR ?The "ATP" light (see Figure 1) is ON when the transmission is in the "P" Park position ACTION: ?Replace the "ATP" Switch. See the Service Procedure (next page) for details.
NTB04038
IF YOU CONFIRM: A slow air leak coming from the area around the Low Tire Pressure Warning transmitter. ACTIONS: ?Remove the transmitter from the affected wheel(s). ?Replace the seal at the base of the valve stem on the transmitter with the parts listed in the PARTS INFORMATION section. ?Re-install the transmitter(s). See this bulletin for further detail.
NTB05003
SERVICE INFORMATION An aftermarket chemical product called "tire dressing" is sometimes used on tires. When the tire dressing is applied, it may combine with an anti-ozonant compound (applied by tire manufacturers) to form a new compound that could stain vehicle paint. The paint stains occur if the wet tire dressing /anti-ozonant compound slings onto the vehicle paint when the vehicle is driven. See this bulletin for further detail.
NTB04073
SERVICE INFORMATION LTPWS and TPMS are the same systems. Only the name has changed. - Old name: TPMS (Tire Pressure Monitor System) - New name: LTPWS (Low Tire Pressure Warning System) This bulletin provides important information for the LTPWS. Use this information: - For correctly setting the tire air pressure. - When inspecting an incident vehicle or when performing a PDI. - When speaking to customers. - To help avoid LTPWS incidents and customer concerns. See this bulletinfor further detail.
NTB04023
SERVICE INFORMATION When doing a tire rotation on a vehicle with the Low Tire Pressure Warning System (LTPWS), please note: - "ID registration" of the LTPWS is not required. For 2004 Armada (TA60), 2004 Quest (V42), 2004 Titan (A60) - In the Electronic Service Manual (ESM) for the Above Vehicles, on pages WT-13 and WT-14, it says that you need to perform ID registration when the tires are rotated. This is not the case. As stated above, ID registration does not have to be done when rotating thetires. - Future amendments to these ESMs will have this change made. See this bulletin for further details.
NTB04054
SERVICE INFORMATION When adjusting the wheel alignment on Nissan vehicles, please note the following: Preliminary Steps: 1. You should make sure that Tire Pressures are properly set before performing alignment checks. 2. Inspect the vehicle to makesure there are no signs of visible damage to any suspension components. See this bulletin for further detail.
