Same Here. ALSO, looking for stock fog lights for my Titan. I did find some OEM for god freaking expensive as hell. Anyone know the dimension of the fog lights?
Same Here. ALSO, looking for stock fog lights for my Titan. I did find some OEM for god freaking expensive as hell. Anyone know the dimension of the fog lights? or any fog lights that are the same size?
I believe the code is clubtitan. The question about auto headlights is because the kit comes with a new turn signal stalk to control the fogs. They need to know what stalk you need.
Hey jersey do you have online instructions so I can look at them? If I do not have autolights am I going to have to change the stalk and then how hard is it to do? Thanks.
Yes you will have to change the stalk, how else you gonna turn on your new fog lights??? You don't need online instructions, it is very easy!!!! You simply remove 3 screws I believe and unsnap the plastic shroud around the steering wheel. (between the steering wheel and dash) You then have access to the stalk, and it simply plugs in and out.
Like Bixll said,
It's one the simplest things to do.
Your truck should already be prewired so just put the fogs in, screw then down and connect the male-female connectors together.
The wiper stalks comes out without a fight and you put the new one in.
It shouldn't take you more that 60 minutes to do this mod. I had my wife and step daughter help me out... they put the fogs in while I replaced the stalk... it took us 25 minutes all together.
Yea, it is really easy, I do not have a PDF on the installation, but I will see what I can come up with...
37.5K members
