Can someone tell me the basics on how the Titan's 4 wheel drive system works.
My basic question is should the front drive shaft from the transfer case to the front differential turn if you are in 2 wheel drive mine does?
I guess my only experience is my old 1979 Chevy that as long as the hubs were manually unlocked and you didn't select 4 wheel drive that shaft would not turn..
Thanks
Pappy
If any one read this and was interested in the answer I found the answer else where. Yes it should turn in 2 wheel drive since the Nissan has a live axle. So its normal.
Pappy
Thanks
Pappy
Pappy
