Nitro Gear packages, now with 1 part number! - Nissan Titan Forum
post #1 of 17 Old 03-23-2015, 12:29 AM Thread Starter
justdifferentials
Shift_Enthusiast
justdifferentials's Avatar
Quoted: 1 Post(s)
Nitro Gear packages for your vehicle, now with 1 part number!
Nitro Gear and Axle has led the way for many innovating R&P and axle packages. Now they have simplified the way you purchase gears. With one part number you can purchase your front and rear ring and pinions, master install kits, solid preload spacers, and new yokes if they are required. No more searching around to find the correct install kits and ratios for both your axles!
Do you really need new gears in your axles?
It is a common misconception that Re-Gearing a vehicle is only for Hardcore Off-roaders or for huge oversized tires. In fact, most of the late model vehicles we produce aftermarket ratio’s for are daily driven vehicles with slightly oversized tires. In an effort to improve fuel economy, Late model overdrive transmissions are geared very high which means RPM’s are very low on the highway. When even a slightly taller tire is installed the RPM’s are reduced below acceptable levels that the engine was designed to run. This causes constant shifting out of overdrive, sluggish acceleration, poor economy and rapid wear on the transmission and other components.
By changing the Ring & Pinions in your vehicles differentials, you can match the ratio to the tire size to bring the RPM’s back to where the manufacturer intended. Typically it is recommended to select a ratio slightly lower (higher numerically) than what the math will tell you. This will help accommodate increased rolling resistance, wind drag, and added weight of aftermarket accessories and gear.
If you have any questions or need a quote, contact us
(866) 525-4620
Follow us on
justdifferentials is offline
post #2 of 17 Old 06-01-2015, 10:24 PM Thread Starter
justdifferentials
Shift_Enthusiast
Quoted: 1 Post(s)
We recently added a few more Nissan options to our line of products. Sorry, no Titan kits yet. If you don't see the options you are looking for, give us a call at 866 349 6801 or email us info@justdifferentials.com. Check out all our gear package kits online:
(866) 525-4620
Follow us on
post #3 of 17 Old 08-07-2015, 01:02 AM Thread Starter
justdifferentials
Shift_Enthusiast
Quoted: 1 Post(s)
Check out all the NITRO Gear Packages Kits we offer for Chevrolet & GMC, Ford, Nissan, Dodge, Jeep and Toyota vehicles HERE.
(866) 525-4620
Follow us on
post #4 of 17 Old 08-21-2015, 07:17 PM Thread Starter
justdifferentials
Shift_Enthusiast
Quoted: 1 Post(s)
Overlanding.
I don't need to regear, my tires are only a little bigger than stock.
It's a common statement and one we enjoy addressing when the opportunity presents itself. Overland preparation tends to add weight to the base vehicle. Bumpers, winches, skidplates and tire carriers can add a tremendous amount of weight from stock. Add a rooftop tent or rack assembly up high and aerodynamic drag is greatly increased as well further reducing performance both on and off-road.
Beyond increased weight, vehicle manufacturers almost always opt for a borderline gear ratio from the factory to optimize unloaded fuel economy. This means that even running near stock size tires, a heavily loaded, taller than stock and factory undergeared Overland 4x4 is a very poor performing machine both in terms of acceleration and fuel economy. This reduces cross country fuel range, on road responsiveness and off-road control all at the same time.
The solution is regearing. Proper gear ratios put the engine at optimum RPM for performance and fuel economy and give you the opportunity to add traction aiding differentials during gear installation greatly enhancing the capability of your backcountry 4x4 in the field, on the highway and around town.
Just Differentials is the leader with gear packages available for all the common Overlanding platforms. These kits include ring and pinions, full master setup parts and everything your mechanic needs to regear your rig and make it function as it should instead of gasping every time you climb a mild grade.
Call us at 866-349-6801 or check out our package options here.
(866) 525-4620
Follow us on
post #5 of 17 Old 02-27-2016, 01:27 AM Thread Starter
justdifferentials
Shift_Enthusiast
Quoted: 1 Post(s)
The aftermarket is flooded with cheap low quality noisy and hard to set up gears that don't last when worked hard. At Just Differentials we stock brands that we believe in and hold up to what our customers put them through on the trail, race track or towing a trailer.
JustDifferentials.com for all your gear and axle needs.
(866) 525-4620
Follow us on
post #6 of 17 Old 04-11-2016, 05:22 PM Thread Starter
justdifferentials
Shift_Enthusiast
Quoted: 1 Post(s)
We've been putting this LX470 together in the shop over the last few days. Recently we went through the suspension and axles, and added a Nitro Gear Package. Now we are adding Slee Off-Road bumpers, sliders and a Engo winch. If you are in the PNW and need a quote for some work on your vehicle let us know!
All our Gear Package Kits are available online. You can email us at info@justdifferentials.com or call us at 866 349 6801 for a parts quote.
(866) 525-4620
Follow us on
post #7 of 17 Old 05-11-2016, 04:01 PM Thread Starter
justdifferentials
Shift_Enthusiast
Quoted: 1 Post(s)
Building a sweet 9 inch assembly in the shop this week. Nitro Nodular housing, Nitro LSD unit, Nitro 1350 forged yoke and a REM treated 3.50 Nitro Gear Set. REM treating produces an incredibly smooth surface finish for reduced noise, cooler running and longer lasting gears. Ideal for keeping gear noise to a minimum and an option on some Nitro gearsets.
We can build one for you as well, or just about anything else for your axles. Call 866-349-6801 or click on the link below to see all our gear and axle options:
Nitro Gears at JustDifferentials.com
(866) 525-4620
Follow us on
post #8 of 17 Old 05-30-2016, 01:45 AM Thread Starter
justdifferentials
Shift_Enthusiast
Quoted: 1 Post(s)
NITRO Gear Packages are always in stock at JustDifferentials.com!
(866) 525-4620
Follow us on
post #9 of 17 Old 07-14-2016, 01:53 AM Thread Starter
justdifferentials
Shift_Enthusiast
Quoted: 1 Post(s)
When was the last time you checked your gear oil? This 10 bolt rear end came in from a local customer. Don't forget about your axles when you are performing routine maintenance on your vehicles!
(866) 525-4620
Follow us on
post #10 of 17 Old 08-13-2016, 08:55 PM Thread Starter
justdifferentials
Shift_Enthusiast
Quoted: 1 Post(s)
The little guy is a Toyota 8 inch pinion gear. Big one is a Nitro 11.8 AAM pinion gear going into a new Chevy. We stock them both should you be ready to regear everything from a mini truck to a seriously built HD diesel. Give us a call at: 866 349 6801 or email us at: info@justdifferentials.com if you have any questions or can't find what you need at: JustDifferentials.com
(866) 525-4620
Follow us on
User Tag List
Linear Mode Linear Mode
Nitro Gear at the Baja 1000 justdifferentials Off Topic 3 11-21-2014 08:06 PM
New Nitro Gear & Axle Catalog available for download justdifferentials JTS Parts & Accessories 0 10-10-2014 01:35 PM
Nitro Gear Apparel! justdifferentials JTS Parts & Accessories 0 11-04-2013 08:00 PM
New Nitro Gear packages for your vehicle, now with 1 part number! justdifferentials JTS Parts & Accessories 3 10-28-2013 11:15 AM
Nitro Gear on Truck U! justdifferentials JTS Parts & Accessories 2 04-01-2013 03:01 PM
