Detailed write-up:
http://www.burtmanindustries.com/zoomprod.php?id=ttnc_led_3rd
Back in stock. Read the write-up to see what makes this unit so special.
Someone on here did post pics, but I can't find the post.float_test said:Very Nice! Any pics of the smoked?
Yours sure did look good in person last wekendsupadupaj said:Those are nice. Mine only have 3 white led's on each side and the rest red. They don't light up very much at all...
JasonB said:Someone on here did post pics, but I can't find the post.
Here is a shot of the smoked, but the picture came out pretty bad...
http://www.clubfrontier.org/forums/vbpgimage.php?do=full&p=2311
Jason remeber mine at the meet? The one i have is the one Burtmans sells. instead of a large red center it is mostly white with a narrow bit of red. the larger white area lights up the bed a lot better.supadupaj said:Those are nice. Mine only have 3 white led's on each side and the rest red. They don't light up very much at all...
Don't know what that wire is for on that Titan but no wire will be expose on the LEDs 3rd brake light. Everything is like stock, plug and play and is hidden inside.TitanLE said:You know on the stock light only the part facing the rear is red, and the rest is covered by a bodycolored case. With the LED does that body colored case still get used?
And is there any other way to route that wire so its hidden?
Oh ok. Any input about the casing? Or do you have a top view of the light bar?baseballfanz said:Don't know what that wire is for on that Titan but no wire will be expose on the LEDs 3rd brake light. Everything is like stock, plug and play and is hidden inside.
YES thats rightWiskers said:So by the looks of it only 6 LED's light up red for the brake light and the rest are all for the cargo bed light?
Not for the one we sell. It's the opposite.Wiskers said:So by the looks of it only 6 LED's light up red for the brake light and the rest are all for the cargo bed light?
JasonB said:Not for the one we sell. It's the opposite.
The picture is not that of a Titan light. I would like to see an actual one on a Titan.Wiskers said:Looks like only 6 LED's light up in red to me.
