UPDATE MARCH 2010: Hold Off, still an error on this Relay p/N. The one detailed here is a 5 Pin, not a 4 Pin as we need!
We need a CM1a-D-12V, not a CM1-D-12V. The "a" denotes a 4 Pin SPST Relay
Correct Link: http://search.digikey.com/scripts/DkSearch/dksus.dll?vendor=0&keywords=CM1a-D-12V
Here is a link where you can buy the correct Relay for the ECU on your Original Version IPDM. This Relay has the Internal Diode, which is makes it different from the others on the IPDM (i.e. Fog Light Relay). Part number has been extensively researched and confirmed. This is the exact same item that Nissan uses.
This may save you from buying an expensive IPDM module. Consider buying this ahead of time, to keep as a spare in the glove box. I'll be buying myself 2 or 3, just too inexpensive not to. Relay is less than $4! Cost Shipped is roughly $7 via USPS. This Relay fits the original design IPDM. May be back ordered sometimes, be patient.
:thumbsup-big:
http://search.digikey.com/scripts/DkSearch/dksus.dll?vendor=0&keywords=cm1-d-12v
:thumbsup-big:
