Ok guys...I have searched and I know its personal preference but I have got to get some opinions on this. I have quadurple measured and calculated and designed 2 enclosures for (1) 10W7 in my king cab that will be powered by a 500/1. Confirmed measurements after my rear seat lift allows enclosure to be 57" long x 12" tall (front) x 9" tall (back) x 12" deep.
The questions plauging my mind are as follows:
Current ported design is 1.5 cu. ft. after displacments...front firing sub (driver side) front firing port (middle). Port design assisted by JL to ensure cu. in. and fq. accuracy.
Current sealed design is 1.25 cu. ft. after displacements...front firing (option either side).
As I am used to car enclosures is I need input on whether to go ported or sealed and if the front firing direction will be suitable or if I should work on a new design.
Musical tastes range from 20's blues to current metal with everything inbetween. I side on SQ quicker than SPL. I am determined not to lose my back seats.
Thanks in advance for the input...
