Hi guys,
new member here, posting on behalf of my dad's 2008 titan.
specs:
2008 Titan
175,000 miles
no mods
This is my dad's truck. I took it to discount tire today to get some new tires. Afterwards I took it a local shop to get the breaks & alignment done.
shop said the front hubs are gone (there is a loud noise coming from the truck, so I think hubs and/or bearing is the cause)
They also said the front camber is out of spec and would need camber bolts to align properly. I just read about this online and it sounds legit.
They found that the rear differential pinion is leaking and that the seal would need to be replaced. They mentioned this is a very common problem with the Titan & Armada.
last item, power steering pressure hose is leaking and would need to be replaced.
here are the estimates
Front camber bolt $216.20
Front wheel hubs (2 front) & break pads (front only) $767.21
Rear differential pinion seal $283.89
Power Steering pressure hose $421.56
Total $1688.86 (price includes, parts, labor, taxes)
fair deal?
Thanks
specs:
2008 Titan
175,000 miles
no mods
fair deal?
Thanks
