» Featured Product
» Wheel & Tire Center
» Sponsors
» Sponsors
Go Back   Nissan Titan Forum: Club Titan Forums > Mods and Technical Discussions > Performance Mods
  #1
Old 03-18-2006, 08:10 AM
shailey's Avatar
shailey shailey is offline
SHIFT_The_Real_Slim_Shailey
Shift_Obsessed
My exhaust findings!
First of all, if one of the mods finds this useful enough to make a sticky on it...great. If not that is fine too.
I have received quite a number of PM's lately asking about exhaust. I do not mind them, in fact I enjoy helping people out and answering their questions. If you have questions after this post, still feel free to ask them, I will answer.
I know that there are many peole on here who know more about exhausts than I do as far as the technical stuff. But, in the last two months I have done around 40 dynos with many different combinations of modifications and exhausts. The systems that I have had include the following now:
1) Full Stock set-up with 22" magnaflow muffler
2) Magnaflow Catback
3) Gibson swept side
4) Borla Dual
5) Flowmaster 40 series
6) Flowmaster 70 series
7) JBA single exit
For 2007 Titan Owners: You have the best set up from what I found with my previous 2005 model. That is a true dual in to a single out muffler. It produced the most torque of any of my systems. You can do a muffler swap with Magnaflow part number 12580 (satin stainless) or 14580 (polished stainless). This is a dual inlet/single out muffler that is wide open straight through design. I will be putting this muffler on my 07 titan in the near future after doing a baseline STOCK dyno. I need to get some miles on her first. One thing that may need to be noted. In installing this muffler, it is best to cut the drivers side pipe about 2 feet before the muffler and again at the muffler. Now take this pipe and rotate it 180*. THis is because the muffler has a center to center inlet width that is 3" less than the stock muffler.
I will provide what I observed during the whole process to try and help others determine what is best for their needs. When I mention drone, I am extremely sensitive to the frequency that exhaust emits. So your level of hearing may be different than mine.
1) The full stock set up with the 22" magnaflow provided great numbers. The hp and torque increase from stock was 8 and 14. Sound was a little louder than stock and there was noticeable drone to me at 58 to 62 mph. Bang for your buck can not be beat here. Once again I ONLY changed out the muffler. Part number 12586 (satin finish stainless) or 14586 polished stainless). If you want to go with the 18" magnaflow part number 12256 (satin) and 14256 (polished).
2) Maganflow catback single exit provided the best gain period with the STOCK titan. The numbers on the website of 18 and 22 were factual peak to peak numbers. Not a play on numbers like many manufacturers do and show how much you gained at a certain rpm when you actually gained on 2 or 3 peak horsies. One odd thing that needs to be realized with this set up is it uses the STOCK Y-PIPE. I tried this set up with a custom 3 1/2" Y-pipe and lost a lot of torque. drone once again, is pretty noticeable at speeds mentioned above.
3) Gibson Swept Side is in my opinion a great all around exhaust for a couple of reasons. One it does provide medium gains in hp and torque. But two it has a great sound with almost no drone. It is louder than stock at WOT, but at start up it is just a deep tone that sounds great. But if you want something that is loud and mean, this is not for you. Gains 12 hp and 14 lbs.
4) Borla dual. It sounds really good to me. Cruising speeds had no drone, drone was only around 45 mph. the gains in hp were comparable to the gibson (12), but the torque gain was very minimal (9). But it is a very clean sounding exhaust that will please MANY and the finished look is very nice.
5) Flowmaster 40 series did not stay on for an entire day. Drone felt like my head was going to cave in. I greatly apologize for not being able to tolerate it to give a full evaluation, but the drone was heavy between 40 and 70 mph to me. And that is where I drive 90 percent of the time.
6) Flowmaster 70 series. Very good sound. Not to loud, drone was minimal around 1600 rpms. Provided nice hp gains that were equivalent to Gibson and Borla (12 hp and 8 lbs of torque), but once again the torque gain was very minimal. This exhaust at wot was definitely able to turn some heads with its volume and I did notice a couple of pops after going WOT and then letting completely off the gas. So it performs like the Gibson and Borla but has a little more agressive sound than both of them.
7) The JBA provided the best gains AFTER the header install. I do not have perforamnce numbers with the stock exhaust manifold, because I purchased this system AFTER headers. Previously the Magnaflow had the top gains hands down, but after the headers, this one etched out on top by 4 hp and 6 pounds of torque. I think that JBA did a good job matching their systems up. One thing that is interesting though is the muffler that came with it was a K & N muffler. The Y-pipe is smaller than ALL OTHER catback systems at 2.5"...EXCEPT where the bend in the tubing is and at the Y. The bend in the tubing on the drivers side expands to a little under 3" and then shrinks back down and it seems to act like a velocity channel. And the Y has two 2.5" pipes that come together to a 3" collector. There is some drone at 1600 rpms does not matter the speed, but it is definitely tolerable to me. This is a fairly loud agressive exhaust but is still not up with the Flowmasters or Bnaks.
I have another one that I will be adding the dyno numbers on in the near future. I got a magnaflow 2.25" dual in/ 3" single out muffler and ran two separate pipes to the muffler. Just in front of the muffler I put in Magnaflow resonators to help quieten down the truck. So I no longer have a y-pipe and it is set up like the 2007 Titan exhaust but with a wide-open magnaflow. I am now producing the best times the truck has ever produced and am very happy with the sound of it. The extra resonators did help reduce the in cab noise and drone is acceptable for the first time since adding the long tube headers.
So one conclusion that I was able to come to is that the 5.6 loves small pipes. That is where the low end torque comes from as does the max torque. It is funny that the 3 systems that produced the best numbers (hp and torque) used the smallest diameter Y-pipe and 2 of those were with the STOCK Y-PIPE and the other has the same diamter as the stock y-pipe. The dual systems lost speed in the lower range (below 40 mph) and I am convinced that is because of the minimal torque gains and I believe loss of back pressure. So if you want pure sound, the duals are the way to go. But if you want performance, the single exits with the smaller Y-pipe proved to be the best. But if you must use duals, use 2 to 2.25" pipes.
This was done on a Dynojet Dyno and times were tested with my Beltronics FX2 accelerometer.
  #2
Old 03-18-2006, 09:39 AM
Galaxian Galaxian is offline
Shift_Enthusiast
That's awesome! Thanks!
  #3
Old 03-18-2006, 11:17 AM
Chief Chief is offline
Shift_Hardcore
Thanks Shailey,
All of these comparisons are to a stock system????
Thanks!!!!!!!!
Chief
__________________
"I'm in denial!!!! I admit it!!!! (me)
ZZZZZZZZZZZZZZZZZZZZZ
04 SILVER XE CREW CAB 4X4
OFFROAD PACKAGE
PREFERRED PACKAGE
"HEMI FOR LUNCH BUNCH" MEMBER
  #4
Old 03-18-2006, 01:27 PM
float_test's Avatar
float_test float_test is offline
Shift_Obsessed
Wow Shailey! thanks for all the hard work you've put into this. Im impressed with your results as im sure every one else is too. Did you have a cai on when testing these exhausts? The reason i ask is i installed the Gibson swept side after the K&N drop in and the butt dyno says i lost low end torque, i have since replaced the stock air filter and believe ive gained it back does that make any since? Do you recall the torgue gain on the gibson i must have missed that one. Sorry for the long post man. Thanks Roy
__________________
IRC Member "International Racers Club VK56"
"IRC Crew Chief"
05 4x2 KC/SE Silver/Power Captain
Mods: PGM, Uprev, Nismo LT's, Hybrid Exhaust, etc...
No Big Tow......No Squeak......
Built 5/10/05
Captured 7/2/05
  #5
Old 03-18-2006, 03:00 PM
shailey's Avatar
Shift_Obsessed
I am terribly sorry, I should have explained a little better by what I meant when I said stock. I meant without the headers and computer reprogramming. I had completely reset the computer back to stock. The a/f ratios were in the 13 to 13.5 range under wot and idle test showed 102% and the timing was at 16*. I had the stock exhaust manifold and ecm and I had installed an Airaid cold air intake and poweraid TBS.
The torque gain on the Gibson was 15 lbs. of torque peak to peak. And the Borla produced almost the same results (12/14).
And Chief, yes this is compared to the stock exhaust system. The only variable that changed (when comparing these dynos) throughout the entire process was the exhaust from the rear cats back.
After I got the headers put on, I decided to try the JBA system just because of the gains posted on the website. I thought, hey, magnaflow was truthful, maybe they are too. So I bought it and the gains were very close to the manufactureres claims over pure stock. So I have actually found during this process, 2 manufacturers with numbers that are not misleading. I hate reading things like you gain 25 hp and 35 lbs of torque. Then in the small print you find out that peak to peak might only be 5 hp and 10 lbs of torque. Sure it is great to get higher numbers at certain spots in the rpm range, but I want the peak numbers to go up.
I will be trying out the Bassani exhaust shortly and will add to this list.
  #6
Old 03-18-2006, 04:21 PM
Shift_Hardcore
Thanks Shailey, no need for apology. You are only helping out.
I'm just very interested in the comparisons to stock. The only mod I have done is to split the pipe into 2 AFTER the muffler. It's because I feel less backpressure is going to make you lose overall. I want it quiet and to be honest, I don't have much interest in making mine faster.
What you are saying seems to support the backpressure/torque issue, but it also looks like some gains can be had with the right system.
Thanks again for all the hard work!!!!!!!!!!
Chief
__________________
OFFROAD PACKAGE
PREFERRED PACKAGE
  #7
Old 03-18-2006, 04:38 PM
float_test's Avatar
Shift_Obsessed
Thanks again shailey. I never heard of bassani, learn alot from this forum from guys like you.
__________________
"IRC Crew Chief"
Built 5/10/05
Captured 7/2/05
  #8
Old 03-18-2006, 04:39 PM
Mercury175 Mercury175 is offline
Shift_Enthusiast
Shailey:
Where any of those tests using a X Pipe. I am running a 2.5" X-pipe (after the cats) with all 2.5" pipe. It goes into 2 FM 40 series and stright out the back. All exhaust components are 2.5" except for the 3.5" tips. Do you think the set-up I am running is costing me low end torque? I also have the AEM and I will be putting a Helix power tower on soon. I also have the Active tuning ground kit.
__________________
2005 Nissan Titan KC 4X4 LE Glxy Blk AEM Brute Force CAI W/ Dry Filter, Helix TBS, Clarion N.I.C.E. DVD/NAV/CAM/SERIUS OEM Hood Protector,Banks Monster Exhaust, ATS painted fender flares.<br /><br />I want:<br />MORE POWER!! DR Coilovers, Bilstien Shocks, Retrax cover
  #9
Old 03-18-2006, 05:13 PM
shailey's Avatar
Shift_Obsessed
I did not run an X pipe on any of them. And the two dual setups that I did try were also 2.5" pipes and I lost low end torque on both (figured because of higher times with the FX2 accelerometer). The FX2 times all of your speeds in 10 mph increments so I was able to see that the times were slower up to 40 with the dual system set up. Which leads me to believe that low end torque was lost. Now, once the truck got going it seemed to pick up drastically, but not until about 40 mph.
More than likely the Helix power tower will help recoup that lost low end torque. I found through dynos that the tbs in 3rd gear dynos, did not hardly show a noticeable increase (3 and 5). However, I am pretty certain that the tbs is designed to operate in the lower rpm range because with it on, 0-60, 1/8 and 1/4 mile times all came down. So the hp and torque increase is more noticeable in the range below 3150 rpms.
Hey float, here is a link to the Bassani page:
http://www.bassani.com
  #10
Old 03-18-2006, 05:22 PM
Shift_Enthusiast
Thanks man. You have allot of great info. I'll be getting my timing advanced 2 degrees as well. Should that give more low end as well?? Once again, thanks.
__________________
Powered by vBulletin®
