aight heres my suplies any of em not gnna work? before i open em also how do i conect the switch to the that (VVV) or do i just conect it straight to the wire somehow
You got everything you need, except I would use braided copper wire, not solid. It is easier to run, not as stiff and is better against breakage went bent.
You can also grab some small dia. wire loom(black, maybe 3/8" or 10 mil.) for an ultra stealthy install.
aight i got the switch done its basicaly a switch w/ 2 male conectors atatching to 2 feale ones w/ 2 seperate wires coming out... now when i cut the harness wire do i atatch these 2 wires and eclctrical tape it or put a plastic screwp cap on it??
..........................................cut here
comp.--------------------End A{A.....B}End B---------------brake pedal
..................... ..crimp to End E|E......F|crimp to End F
blade connector End C to switch|C.....D| End D blade connector to Switch
...............................................swi tch
You cut the factory wire, that leaves you 2 factory wire ends lets call them end A and end B
From your switch you also have 2 wires, and 4 wire ends. we will call them C, D, E and F.
Ends C and D will get connectors and go to the two posts on the switch.
Ends A and E will be crimped together. Ends F and b will be crimped together. That's it, your done.
Quote:
Originally Posted by kseer
sorry but still not graspin it do i conect the switch wires too the cut hareness wires? im more of a visual learner...
