» Featured Product
» Wheel & Tire Center
» Sponsors
» Sponsors
Go Back   Nissan Titan Forum: Club Titan Forums > Mods and Technical Discussions > Do it yourself, Tech Tips
  #1
Old 01-05-2007, 08:22 PM
robexploring's Avatar
robexploring robexploring is offline
High Maintenance FIC
Shift_Hardcore
Power Burnout/AntiTheft Mod-Brake Pedal w/Pics
THIS IS NOW ALSO KNOWN AS THE ANTI THEFT MOD. DOING THIS MOD ENABLES YOU TO KEEP THE TRUCK FROM SHIFTING OUT OF PARK W/ SWITCH IN MOD ON POSITION. WITH A SMALL HIDDEN SWITCH THIS MOD IS ALMOST UNDETECTABLE.
The way I know I believe is only for floor shift (center console) models.
What you'll need:
1-switch-Radio Shack or Pepboys-however fancy you wanna get.
http://www.radioshack.com/product/in...tId=2062523&cp
2'-3' 18ga. wire
2-18ga.(red) crimps http://www.radioshack.com/product/in...entPage=family
2-female, or male blade connectors 18ga.(red) or solder and iron depending on your switch http://www.radioshack.com/product/in...entPage=family
DO YOURSELF A BIG FAVOR-DON'T BUY CHEAP CRIMPS OR CONNECTORS!!!!!
A pair electricians pliers(OR a stripper, cutter and crimper or plyers)
Razor knife
Optional-electrical tape, wire loom
Ok, look under your dash at the brake pedal. Follow the assembly up and you will see 2 wire harnesses plugged into the assembly, a tan harness and a black harness . The black harness(the bottom one), and is the one you want. The harness will only have 2 wires, a red w/ yellow stripe(don't want to cut) and a red w/ either green or black stripe, which is the wire you want.
Pic 1. Highlighted in green. Be sure to cut the wire far enough away from the harness to leave room for stripping and crimping.
Slice the protective loom with a razor to give access to the wire. Cut the wire, strip and crimp your new wire to each ends of the cut factory wire. Run/secure your new wire under dash going to your switch location, and connect them to your switch using either male/female blades or solider. You can wire loom and tape if you wish to make your install factory clean. That's it!
Here's a pic of my switch- Pic 2. (Which will be redone shortly to the way I did in Pic 3.)
And Pic 3 is of how I did Penguin's(very stealthy!)Thanks to TitanSE for the idea!
The bottom dash panel comes off by 2 screws in the bottom corners, then gently pull on panel straight out. You can see one screw in Pic3.
You are basically putting a switch on the red w/ green(or black) wire circuit. You'll know when the power burn mod is "on" cuz you will have no brake lights and you won't be able to shift out of park. This is good, so you won't be drive around all the time with it on. With the Mod off, everything is normal.
Happy modding.
Big thanks to KingBean for the idea!
__________________
06 CC, LE, Galaxy, 4X4, O/R, BigTow, DVD, Nav, Loaded-All Options
MODS: BULLY DOG! Truxedo Tonneu, Banks Monster, ECO#3, 2 Deg Advance, Throttle Body Spacer Install, Screen Delete, Coolant Bypass Mod, Power Burnout Mod(Anti Theft Mod), Insulated & Enclosed AEM CAI, Conical Filter w/Velocity Stack, PRG Leveling Kit, Foglight Mod, R1 Concepts Drilled/Slotted Rotors & Pads, 320/60r18 TOYO PROXES
Stainless: Hunter Grille & Headlight Guards, Steelcraft Taillight Guards, E&G Customs Grill, Lund SS, Pillars & Sills.
Other: Hunter Alum. Boards, Chrome Tailgate Bib, Chromed Nissan 5 Spokes, $27 Dynachrome Springs
Numbers: 15.35 1/4mile(OLD)Atco Thread
299hp & 347trq(OLD)
  #2
Old 01-05-2007, 08:24 PM
RIDER's Avatar
RIDER RIDER is offline
"Looks Great"/Linkmaster
Shift_Obsessed
Great write-up!
__________________
[Click picture for MOD List]
  #3
Old 01-05-2007, 08:33 PM
Bighitter's Avatar
Bighitter Bighitter is offline
Shift_Hardcore
Great mod, one suggestion I would make is to get T clips to tap into the factory wiring, it is a little bit safer of a connection and more secure. I can post a pic and model number of the radio shack part tomorrow, I just used them to tap into the trigger for my rear view camera.
  #4
Old 01-05-2007, 08:37 PM
Shift_Hardcore
That's a good idea. Please share those pics!
__________________
299hp & 347trq(OLD)
  #5
Old 01-05-2007, 09:27 PM
Bighitter's Avatar
Shift_Hardcore
I will take some tomorrow, I see I am going to have to get another switch now so I can add this in, thats 3 total I wil have sheesh.
Here is a link to the two type of tap-in connectors I am using, which should work well with the factory harness.
http://www.radioshack.com/search/ind...&origkw=tap-in
  #6
Old 01-05-2007, 09:56 PM
Shift_Hardcore
I used these before, and don't think they can be used here. You need to interupt the circuit via a switch, those would just piggy back the circuit, never really interupting it, so the engine will still kill the RPMs when attempting a burnout.
I just used these:
Crimps: http://www.radioshack.com/product/in...entPage=family
Blades: http://www.radioshack.com/product/in...entPage=family
__________________
299hp & 347trq(OLD)
  #7
Old 01-05-2007, 10:02 PM
Bighitter's Avatar
Shift_Hardcore
Ahhh my fault, I didn't read your post close enough. Yeah those are both good choices for the work then. Sorry for getting this a little off track.
  #8
Old 01-05-2007, 10:50 PM
JERDOG's Avatar
JERDOG JERDOG is offline
Shift_Hardcore
Great post !!! Thanks !! Jer
__________________
'09 HHR SS
Lighting Silver, 5spd, Brembro brakes, stage 1 soon
  #9
Old 01-06-2007, 09:56 AM
baseballfanz's Avatar
baseballfanz baseballfanz is offline
SHIFT_Mr. Quick Answers
Shift_Obsessed
Great write up but where's the pictures/video off your burnout?
__________________
Titan/Armada part numbers
Nissan's OBD II codes
  #10
Old 01-06-2007, 10:17 AM
Shift_Hardcore
My Avatar, and here is a post of me at Atco raceway. There are pics and a Vid.
http://www.clubtitan.org/forums/show...highlight=atco
__________________
299hp & 347trq(OLD)
Powered by vBulletin®
