Part Number Thread - Nissan Titan Forum
post #1 of 49 Old 03-14-2007, 06:03 PM Thread Starter
RBsTitan
Shift_Obsessed
RBsTitan's Avatar
Quoted: 0 Post(s)
Part Number Thread
Hey Guys - What do you think if we had a specific thread for Nissan part numbers?
Always double check PN before ordering/purchasing.
Engine & Power Train Part Numbers:
21200-42L01 170F Thermostat 76.5C
01553-09321 Fender Clips
14064-WF701 Block studs
08918-3401A Exhaust nuts
20691-30P00 Catalyst Flange Gasket
14094-31U00 Exhaust Manifold nuts
16175-7S000 O-ring gasket for Throttle Body
21430-7S001 Radiator cap
20692-65J00 Exhaust Gasket
999MP-MTJ00P J-Matic Transmission fluid
16546-EA000 Air filter OEM
14041-ZE00A 2007 Engine intake manifold Cover
15208-9E000 Oil Filter OEM
38350-8S10A 05 Finned rear diff. cover
36522-8S10A brackets for brake cable
38321-8S10A longer bolts
(Some place will sell a whole kit with all neccessary parts)
43070-7s200 rear axle spacer (need Left and right)
40210-7s210 rear axle bearing (need Left and right)
43252-7s200 rear axle seal (need Left and right)
(all three are necesary for seal replacement)
25146-5Z000 VDC switch
32006-7S160 ATP Switch
TCM Transmission Control Module
2WD w/ floor shifter 31020-8S502
2WD w/ floor shifter BT package 31020-8S702
2WD w/ column shifter 31020-8S204
2WD w/ column shifter BT package 31020-8S104
4WD w/ floor shifter 31020-7S305
4WD w/ floor shifter BT package 31020-8S205
4WD w/ column shifter 31020-8S005
4WD w/ column shifter BT package 31020-8S605
These are for front wheel alignment on Titan with out cam bolts.
54580-7S005 Cam Bolt (Quantity 4)
54559-7S005 Cam washer (Quantity 4)
38322-41L00 Breather Rear Axle
25060-7S00A Fuel Sending Unit Gasoline Only
25060-ZH00A Fuel Sending Unit FFV Only
92120-ZC200 Condenser Fan and Assembly
21631-7S000 Tranny cooler line (Tube to cooler, early type, require new hose clamps)
21633-7S000 Tranny cooler line (cooler to radiator, early type, require new hose clamps)
21631-ZC00A Tranny cooler line (Tube to cooler, later type, come with clamps)
21633-7S000 Tranny cooler line (cooler to radiator, later type, come with clamps)
01558-00181 Hose clamps (4 per line)
These parts are use to fix rattles when windows is partially opened.
Glass run rubber, front door, LH 80331-7S000
Glass run rubber, front door, RH 80330-7S000
Seal Assembly, Front door inside LH 80835-7S000
Seal Assmebly, Front door inside RH 80834-7S000
Interior Part Numbers:
68257-7S500 Nav. bezel
69674-5Z000 Radio clips
999M1-VP005 In Cabin filters
25540-CA000 Fog light stalk (stalk only) Non Auto Headlights
25540-ZC00A Fog light stalk (stalk only) Auto Headlights
25552-8S210 (04-06) Steering Wheel Audio Control switch
25552-8S21A (07) Steering Wheel Audio Control switch
86400-ZC001 05 Headrest (Non leather)
999M1-VQ050 Smoker's Kit
999F1-6E000 Pathfinder Accessory Switch to fit Blanks on dash factory look
96920-7s614 Infinity Leather Center console cover
73940-7S040 Grab Handle (universal)
68260-7S000 XE Double Din radio Bezel
999U9-AS004 Sirus Sat. Kit Titan/Armada
999U9-VS006 Satelite unit bracket
B8377-5W900 Sat. Radio Harness
999U9-EP000 Sat. Radio Sub Harness
24016-7S202 DVD harness (From HU to DVD player)
24167-7S261 DVD Roof harness
28310-CG000 IR Headphone
80501-7S000 Door lock actuator - front, left
80500-7S000 Door lock actuator - front, right
96920-7S000 Center console lid assembly (Titan/Armada)
96925-7S000 Genuine Nissan coin tray
17226-AM605 Hose-Ventilation, for fixing wet carpet on passenger side.
25401-7S201 Driver's side switch unit, power window CC
25401-7S213 Driver's side switch unit, power window KC
25411-7S201 Passenger's side switch unit, power window
Exterior Part Numbers:
40206-ZC00A Brake rotors front
43206-7S000 Brake rotor rear
41060-ZC205 Brake pads kit front
44060-ZC205 Brake pads kit rear
41005-7S000 Torque member anchor bolts (4)
41014-7S010 Torque member
40135-7S205 Sliding pin kit
62822-7S000 Armada spoiler
76882-0M060 Front grill clip (the one that hold the front grill to the truck)
999F1-A6000 Fog light kits OEM with auto headlights
999F1-6001 Fog light kits OEM NON auto headlights
51111-7S000 Front tow hooks
999D5-2Q000 Genuine Nissan Hood Protector
80870-7s080 Body side moulding 04-06 Front door
80871-8s580 Body side moulding 04-06 Rear door
96354-8s600 / 96353-8s600 Big Tow Chrome Mirror Caps
999T7-WQ200 Nissan Bed Extender
999U9-VR002 Sirus SIGMA Antenna (inside)
999U9-VS000 XM Magnetic Antenna (outside)
26010-zc30a right hlamp
26060-zc30a left headlamp
26555-7s228 left tail
26550-7s228 right tail
24340-7S000 7 pins trailer tow connector
62256-7S200 Fog light holes cover
96210-7S000 License plate bracket, front
999T4-WQ300 OEM Grill guard
80610-ZC01A Outside handle bracket RH, front and rear on Titan
80611-ZC01A Outside handle bracket LH, front and rear on Titan
82501-8S51A Rear door lock assembly, Titan CC only, driver side
82500-8S51A Rear door lock assembly, Titan CC only, pass. side
28532-7S200 Rear sonar control Unit Titan
28532-7S400 Rear sonar control Unit Armada
25994-7S000 Rear sonar sensors Titan/Armada with chrome bumper
25994-ZC001 Rear sonar sensors Armada Galaxy Black (G10)
25994-ZF002 Rear sonar sensors Armada Silver (K12)
25994-ZF003 Rear sonar sensors Armada Smoke Gray (K11)
25994-ZF004 Rear sonar sensors Armada Shara Gold (C10)
25994-ZC009 Rear sonar sensors Armada Deep Water Blue (B18)
25994-ZC010 Rear sonar sensors Armada Sedona (CY1)
25994-ZC011 Rear sonar sensors Armada Canteen (D13)
25994-ZC105 Rear sonar sensors Armada White (Q10)
MISC Part Numbers:
25230-79964 Tow relays 6 poles (need one)
25230-79945 or 25230-79917 Tow relays 4 poles (04-05 need one, 06- need two)
28268-7Z800 Key Fob
28268-72800 04 Keyless entry pad
999KE-AR000 Keyless entry pad
40702-CK002 Tire Pressure Sensor O-ring
40700-CK001 Tire Pressure Sensor 4x2
40700-CK002 Tire Pressure Sensor 4x4
44003-7S000 Molykote M77 Grease
25300-4M400 Cruise control release switch
24167-ZH00A BCM sub harness
Accessories:
25994-ZC015 Rear sonar sensors
93502-8S210 (Require 2) Utility floor track KC
93502-8S500 (Require 2) Utility floor track CC
96150-7S200 Step pads for OEM step rails KC
96150-8S500 Step pad for OEM step rails, front, CC
96152-8S500 Step pad for OEM step rails, rear, CC
999D4-2Q000 Sunroof wind deflector OEM
999D1-WR000 TEXAS TITAN badging
999T6-WS0C2 TEXAS TITAN chrome step rails KC
999T6-WS0C4 TEXAS TITAN chrome step rails CC
999H1-A7003 OEM wheel locks
999T2-WQ300S1 Nissan Tool Box
91250-7S010 Sunroof sunshade
g.
2004 CC LE 4x2 5360lbs
DYNO: Stock: 275rwhp 331tq (Fram AirHog)MODS: PGM 90mm Throttle Body, Custom PGM Throttle Body Spacer, Custom Throttle Body Intercooler, RBS Custom Ram Air, 170 Thermostat, Volant G1 CAI, Stillen Headers, Custom B-Pipe w/Cats in line, Custom Banks Exhaust, Father of Titan UpRev Tunes, JWT Cams, Detroit TruTrac LSD, N20, lol
UpRev ProTuner and IRC CREW CHIEF "International Racing Club VK56"
13.90 FST beating mustang
13.30 @101.79 FST 80shot
RBsTitan is offline
post #2 of 49 Old 03-14-2007, 06:07 PM
baseballfanz
SHIFT_Mr. Quick Answers
Shift_Obsessed
baseballfanz's Avatar
Quoted: 0 Post(s)
Fusible Links
24370-C9900 Fusible Link 40A+40A+40A
24370-C9906 Fusible Link 50A+30A+30A
24370-C9911 Fusible Link 30A Pink
24370-C9921 Fusible Link 40A Green
24370-C9922 Fusible Link 40A
24370-C9912 Fusible Link 100A
999U9-AS006 Sirus Sat. radio 06-
62050-7S200 Lower grill, front bumper
68257-7S000 Console trim, non nav.
68263-7S000 Rubber mat, cubby hole above the radio
26420-8J000 Courtesy lamp, inside door.
Front Bumper
62022-7S202 Se and LE Chrome
62022-7S025 XE
999T4-WQ100 Front skid plate
999T7-WQ600 Bed tube rails, KC
999T7-WQ350 Bed tube rails, CC
999W1-WR000 18" Chrome wheels 6-spokes
999R2-KM000 Cargo carrier Load Warrior
999R1-2Q000 Load Warrior extension
999N3-WQ100KC Tonneau Cover KC
999N3-WQ100CC Tonneau Cover CC
999L2-BN000 Spare tire lock
999C2-WR002W Under seat storage bin, rear
999E1-WQ000 All weather floor mats KC front only
999E1-WQ001 All weather floor mats CC front only
999L2-AL000 Air bag Anti-theft bolts
999M1-AD000 Air bag Anti-theft bolts
999E2-WQ000GY Floor mats, gray,KC
999E2-WQ001GY Floor mats, gray,CC
999E2-WQ000CH Floor mats, charcoal, KC
999E2 WQ001CH Floor mats, charcoal, CC
999U7-VR000 iPod interface kit
999T5-WQ100 Hitch receiver
999T5-KN000S2 Hitch receiver plug
999T7-WQ820 Weight distribution hitch ball mount
24167-7S000 E-brake sub harness
999L1-WS000 Auto dimming rearview mirror w/ compass
999T7-WQ400 Bed tent
999T2-WQ300 Sliding tool box
999R1-WQ100 Sliding overhead racks
999R1-KL001 Overhead rack Safari basket
999T7-WQ500 Sliding bed divider
999T7-WQ700 Tie down cleats
999C3-WQ100 Sliding bed upper tray
01553-S3500 Door trim clip
23100-8S100 OEM Alternator
12033-7S002 Piston ring set for 5.6 Titan/Armada production date of 10/04 - 8/06
12033-ZE00A Piston ring set for 5.6 Titan/Armada production date of 8/06 and on (2007)
21082-7S00A Cooling fan clutch
92120-7S000 Cooling fan
21200-AD200 Thermostat
21460-ZC00A Radiator OEM
21710-7S500 Coolant Reservoir tank
ECM (ECU)
23710-7S06A 4WD without towing package
23710-7S80A 2WD
23731-4M560 Crankshaft Position
23731-4M506 Crankshaft Position sensor
23731-AL616 Camshaft Position sensor
22448-7S015 Ign. coil assembly
24080-7S200 Battery cable, NEG.
68260-7S301 Instrument cluster lid
25070-CD000 Oil pressure sending unit
17040-7S00A Fuel pump
25605-7S000 Horn assembly
25630-79960 Horn relay
28710-7S000 Wiper motor assembly
28920-7S000 Washer pump, (windshield washer fluid)
28911-7S000 Wiper level sensor
25260-AM620 Wiper switch
28910-7S000 Windshield washer reservoir
14002-7S000 Manifold assembly, left, with cats. 04-06
14002-7S010 Manifold assembly, right with cats. 04-06
14036-7S001 Manifold gasket
20100-7S200 Exhaust system 04-06
11720-7S000 Serpentine belt
11955-7S000 Tensioner
23100-8S100R Alternator
23300-7S000R Starter
H0601-7Y000 Door lock cylinder, left
H0600-7S000 Door lock cylinder, right
Tail gate
90606-7S200 Tail gate handle assembly
90500-7S200 Tail gate support arm right
90501-7S200 Tail gate support arm left
90606-7S200 Rear tail gate handle
93486-7S200 Tail gate bed cap.
90460-7S200 Tail gate support cable
NISMO related.
999G1-WQ000BK Red/Silver/Black - KC
999G1-WQ000WT Red/Silver/White - KC
999G1-WQ002WT Red/Silver/White - CC
999G1-WQ002BK Red/Silver/Black - CC
14002-RNA50 NISMO headers
16576-RNA15 NISMO intake
15255-RN012 NISMO oil filler cap
25450-4W300 Sunroof switch
91306-7S210 Sunroof rails
22680-7S000 MAF sensor
96301-ZC400 Power folding mirrors, non BT(07 LE Right)
96302-ZC400 Power folding mirrors, non BT(07 LE Left)
25570-ZA320 Switch assembly for LE power folding mirrors.
93870-7S231 Gas tank door.
38189-8S100 Pinion Seal
EDIT
80870-7S080 Door moulding, Front, right
80871-7S080 Door moulding, Front, left
80871-8S580 Door moulding, Rear, left CC
80870-8S580 Door moulding, Rear, right CC
999F1-YQ000 OEM Fog lights with auto headlights
999F1-YQ001 OEM Fog lights without auto headlights
This link has good info on how Nissan's PN work.
http://www.ratdat.com/technical/part...rtnumbers.html
baseballfanz is offline
post #3 of 49 Old 03-14-2007, 06:34 PM Thread Starter
RBsTitan
Shift_Obsessed
RBsTitan's Avatar
Quoted: 0 Post(s)
Parts for Header install
RBsTitan is offline
post #4 of 49 Old 03-14-2007, 06:36 PM
RIDER
"Looks Great"/Linkmaster
Shift_Obsessed
RIDER's Avatar
Quoted: 0 Post(s)
Great idea!
I don't have any to share though. LOL
[Click picture for MOD List]
RIDER is offline
post #5 of 49 Old 03-14-2007, 06:37 PM
baseballfanz
Shift_Obsessed
Quoted: 0 Post(s)
Hey Randy.
Instead of getting spread out in the thread, you should edit your first post with any additional PN people post.
Oh yeah, can you post the PN for the Big Mouth system?
post #6 of 49 Old 03-14-2007, 07:34 PM
Bodean
SHIFT_Transformer's_Hero AKA Fox Coil Resurrector
Shift_Hardcore
Bodean's Avatar
Quoted: 0 Post(s)
Anyone ever needs one PM me and I always shoot it right back.
Thats not my truck.
Jeff D.
Bodean is offline
post #7 of 49 Old 03-14-2007, 07:37 PM
shailey
SHIFT_The_Real_Slim_Shailey
Shift_Obsessed
shailey's Avatar
Quoted: 0 Post(s)
those look familiar. LOL
shailey is offline
post #8 of 49 Old 03-15-2007, 03:26 PM Thread Starter
RBsTitan
Shift_Obsessed
RBsTitan's Avatar
Quoted: 0 Post(s)
Quote:
Originally Posted by baseballfanz
Hey Randy.
Done and the Giant Mouth Part number is 1GM90MMRBT_T LOL
RBsTitan is offline
post #9 of 49 Old 03-15-2007, 03:30 PM
baseballfanz
Shift_Obsessed
Quoted: 0 Post(s)
Here's a few more for you
Front grill clip (the one that hold the front grill to the truck).
76882-0M060
Tow relays
6 poles 25230-79964 (need one)
4 poles 25230-79945 (04-05 need one, 06- need two)
Fog light kits OEM with auto headlights 999F1-A6000
non auto headlights 999F1-6001
post #10 of 49 Old 03-15-2007, 03:34 PM Thread Starter
RBsTitan
Shift_Obsessed
RBsTitan's Avatar
Quoted: 0 Post(s)
Wink
Quote:
Sweet but for the thread sake maybe you can PM me the most common and I'll add them to the first post? Here's some off the top of my head.
Valve body Gasket
Rear Axle seals
Head/Tail light assembly
Radiator cap
Snorkle tube air intake fender
Infinity center console leather armrest
Quote:
Hmmm...thought since I was Spring cleaning my PM folder I'd better post it.
RBsTitan is offline
User Tag List
Linear Mode Linear Mode
