Did my first 0to60 run with my new ramair set up.Put about fifty miles on it to give the ecu time to learn it a little.Went to the same spot were i pull 7.3 0to60 every time since i put on my 22's.First run 7.15 i am very happy with that time if I went back to my stock rims I am sure it would be even lower.air temp out side was around 70.I am still in my stock map from my uprev tune will switch to tuned map when i get the rest of this 87 out of my tank.So I am hopeing buy the weekend in my tuned map I should be some were in the 6's 0to60.I have to definitely get to the trac.
__________________
04 king cab 2wd 294 rear-Uprev generic tuned with JET maf and running tru duals 2 inch to muffler with H pipe to a single 18 inch magnaflow 2 in 2 out 21/2 inch tails will be changeing to 2 inch in the futur, nismo cai, iradium plugs, tb screen removed,trutrac. Liquid Metal 22 inch rims with Nitto 420 tires,1 1/2 inch rear drop by spring removal ,Helwig sway bar, roll pan, functional hood scoop in to Nissmo cai, grill inserts, debadged, slotted and drilled rotors, dash kit.TB bye passed, carbon fiber tail lights and Bilstein shocks, cover king leatherett seat covers, scan gauge ll, undercover bed cover, Best Gtech 6.16.
First run in tuned map had about 50 miles in to it. Might sounds dum but I have two different spot I do my 0to60 at.Did my slow spot today got 6.95 last one there was 7.35.I think it has a slight up hill grade.I have another spot real flat I usualy do about .2 better will try and hit that tomorrow.One of these days I will try and video it.Thats with these heavy 22's but they look good.
__________________
Yes and I was just reading another thread about ramair and they were talking about closeing of the fender intake so the air from the hood would be more direct.They have different set up but I think this will work for mine
__________________
