my short belt mod :) - Nissan Titan Forum
post #1 of 13 Old 07-06-2007, 12:03 PM Thread Starter
Toomnymods
SHIFT_Track_ADDICT
Shift_Obsessed
Quoted: 3 Post(s)
Well after pulling the serpentine belt and idler pulley, and taking 2hrs or so to try to pull off the fan pulley and the mount i realized that this was going to be much much tougher than anticipated..
Being that the a/c compressor mounts with 1 bolt to the bottom of the fan pulley mounting hardware i decided i had to cut the fan pulley mount so i could still maintain strength thru the fan mount ( for the pulley) i shaved it down so it would't rub by going from the top pulley down to the a/c pulley (which bypasses the fan pulley and idler) Believe me this fan definatly has a LOT OF restriction on the motor, the pulleys weigh in around 2lbs combined and you can try to spin it but the pulley for the fan won't even spin 1/2 turn without stopping from restriction, so thier is without a doubt a gain of 5hp just by bypassing that IMO.. This is why I probably didnt see any gains from removing the stock fans and going to the electric fans cause we havent bypassed the idler and the restrictive fan pulley.. I plan to get this re-dynoed in arlington when i return to see what gains i got from removing those 2 pulleys for everyday driving..
As for the track pulley I can't bypass the powersteering cause i'd have to have the teeth ( or grooved part) of the pulley facing the tensioner which would be bad, it is supposed to have the flat part of the belt against it, so bypassing the power steering can't be accomplished unless a idler is put in on the right side of the motor (which imo wouldnt be worth it) But i was able to bypass the a/c compressor, fan pulley, and the idler pulley on the left side of the motor, im hoping this shows some good gains for 4-5 hrs of frustration,lol
will letcha know how she does at the track if it stops raining this weekend :/
The street pulley goes from 8 to 5
The track pulley goes from 8 to 4
Toomnymods is offline
post #2 of 13 Old 07-06-2007, 12:10 PM
KINGMADE
Creator of the DUMBEST thread ever!
Shift_Obsessed
KINGMADE's Avatar
Quoted: 0 Post(s)
Try to get some videos of you running if you can.
KINGMADE is offline
post #3 of 13 Old 07-06-2007, 12:16 PM Thread Starter
Toomnymods
SHIFT_Track_ADDICT
Shift_Obsessed
Quoted: 3 Post(s)
i bought a brand new camcorder a sony dcr-sr42 with 40X optical zoom and it has image stabilization just for the sole purpose of videoing track stuff only problem is i won't have a camera man,lol and i'm not leaving my camera with a stranger..
post #4 of 13 Old 07-06-2007, 12:20 PM
KINGMADE
Shift_Obsessed
KINGMADE's Avatar
Quoted: 0 Post(s)
I am going to get some velcro to attach mine to the dash.
KINGMADE is offline
post #5 of 13 Old 07-07-2007, 10:33 AM
Rossi
Go fast tester
Shift_Obsessed
Rossi's Avatar
Quoted: 5 Post(s)
The tensioner is not a grooved pulley...it is flat...hard steel Chris.
You won't hurt that thing one bit having the teeth up against it for a mile or two.......I dont' think there would be a problem having it that way perm!!!
2006 SE Crew Cab Big Tow Sold 5-25-2010
1/8 8.79 @ 77.45 1/4 13.89 @ 95.99
Rossi is offline
post #6 of 13 Old 07-07-2007, 10:42 AM Thread Starter
Toomnymods
SHIFT_Track_ADDICT
Shift_Obsessed
Quoted: 3 Post(s)
does your crank slip off the belt any at WOT?? only like 4" of the belt is even touchin the crank with it run that way that's nother reason i decided not to do it that way..
post #7 of 13 Old 07-07-2007, 10:51 AM
Rossi
Go fast tester
Shift_Obsessed
Rossi's Avatar
Quoted: 5 Post(s)
The way I do it there is no difference.....
Now the way you wanted it set up....not sure if you will get enough grab to work.
But look at the top pic on my attachment......I get plenty of grab.
Rossi is offline
post #8 of 13 Old 02-16-2008, 09:07 AM
Daniel Sabin
Shift_Enthusiast
Quoted: 0 Post(s)
Found a 7 rib belt that fits good.
Thanks for the PM Toomnymods my son wanted to finish the mod after I went to work. He wants a Titan but can't afford one. LOL
The Gates/Napa Micro-V belt part number 070786 seven rib 79 1/8 inch belt is a great fit for Toomnymods short belt mod.
On the adjuster it is right at the middle mark and having all seven ribs on the pulleys is nice but I think Toomnymods is correct 6 or even 5 ribs would be OK with the reduction in power need from his mod.
Thanks Toomnymods for a great mod I have Chevy people asking about this mod and how they could do something like it. LOL
Daniel Sabin is offline
post #9 of 13 Old 02-16-2008, 12:29 PM Thread Starter
Toomnymods
SHIFT_Track_ADDICT
Shift_Obsessed
Quoted: 3 Post(s)
do you like the results?? seems to accelerate ever so slightly faster from 0-40mph or so.. 60's didnt drop but im sure this mod doesnt hurt.. this truck has a lot of rotational mass to turn and that is robbing hp..
post #10 of 13 Old 02-16-2008, 12:36 PM
KINGMADE
Shift_Obsessed
KINGMADE's Avatar
Quoted: 0 Post(s)
you still working on locating some crank pulleys?
KINGMADE is offline
User Tag List
Linear Mode Linear Mode
Track Short Belt Mod Rossi Performance Mods 50 01-16-2013 01:04 PM
22$ Mod - Lessons learned bakershack Technical Discussion 39 04-05-2011 01:04 AM
What's the real deal with the 90mm mod??? flamez95 Exterior Mods 3 05-09-2007 04:05 PM
Update on DIY airbox mod and Amsoil air filter. suddenurge Performance Mods 9 03-21-2007 11:19 PM
Bad serpentine belt or tensioner? suddenurge Technical Discussion 12 01-16-2007 04:46 PM
