I am installing my remote starter/alarm this week and after going completely thru the instructions, (as well as every post i could find an oz. of info on), there were just a few things that i wanted to make clear before going at it.
1. Is the Violet Secondary Ignition wire (in the ignition harness) hot during crank? Accessory? On only? or a combination with On?
2. My system features a two 12v+ constant power supplies and specifically states NOT to use the same source for the two. I have used the Green for 1, just wondering where another constant source is for a 10ga wire.
3. When I cut the brown starter wire to attach to the Starter Inhibit Relay, my instructions didn't specify which end when on terminal 30 and which went on terminal 87a. I believe 30 is to ignition and 87 is to solenoid.
4. My instructions state to tap the tach signal to three different coils; cylinder 1, 3, and 7, in order to get an equal distribution. Just wanted to confirm.
5. One wire on my system is for 'entry illumination' (separate ones for the door triggers) but I haven't seen this option in any of the articles posted. Leave it out?
6. We have two starter wires in the ignition, but I only have one starter wire with my alarm. Will it be safe to tap this same wire to both starter wires? Or should I only tap to the Brown?
maybe a few more that Ill stop there for now.
thanks in advance!
__________________
07 King Cab XE; limo tint all around; 4 pc., 20-bar billet grille; aftermarket power windows and door locks; more to come...
Ignition is hot in the On and Crank positions, not ACC
I've always used the same source for all of my installs. That being said, if you're worried about the current flow, you can run a fused power wire from the battery (10 ga minimum)
The relay should be set up so that 87a is empty, 85 has a -trigger coming from the brain, 86 should go to the ign, 87 will have one half of the starter wire and 30 the other...it doesn't matter which half goes to which.
I've never heard of this, and unless there are three different wires, I wouldn't recommend it or you'll have to diode isolate them away from each other so as not to screw up the ECU. I'd just stick with one...realize that the tach is only used to tell the R/S when to stop cranking and in an over rev shutdown
This wire will turn on your dome light when you unlock the doors...I usually don't hook it up because it's usually more of a PITA than it's worth.
DO NOT TAP THEM TOGETHER!! Make sure first that both starter wires are +12v...nissan got into the habit of making their second starter wires negative (-), but it's been a while since I did my R/S and I don't have my documents w/me at work. You're going to need another relay set up as follows: 85 to the 2nd starter output wire on the brain(should be one, if not PM me and I'll explain the secondary course), 86 and 87 to +12v, and 30 to the 2nd starter wire...87a is not used.
thanks in advance!
Happy installing!!!
Correction: On question 3...I meant 87a will have the wire...not 87. 87 will not be used in this case. Sorry for the confusion!
__________________ EX - 2006 Granite King Cab SE 4X4, Big Tow, Off Road, Utility Bed, Popular w/Captains Chairs, Viper 791XV, Voolant CAI, AVS In Channel Vent Visor,Courtesy Nissan Big Tow Chrome Mirror Caps, Magnaflow Single Side Exhaust, Lund SS Bug deflector, Lund SS step rails, Truxedo Lo-Pro, PRG Mini-lift, Throttle Body coolant bypass mod SOLD
2010 PRO-4X CC Galaxy Black w/Captain's Chairs, PRO-4X Utility, Leather, Stillen Intake, Nissan black hood protector, Nissan black running boards, Truxedo LoPro QT, Viper 5902 Alarm w/Remote Start, and Vent Shade In Channel Vent Visors.
- Marc
Member CTFBC
Reason: Automerged Doublepost
Now that's service! thanks so much for the first round of questions, i definitely wouldn't have figured all that. I've been going at it for a couple hours and ran into some issues.
7. All my research was consistent in the brake light being a Red/Green at the brake switch. There are two harnesses with the following wires present:
4-pin - Green/Red ; Red/Black ; Red/Yellow ; Grey
2-pin - Red/Black ; Brown/White
Any suggestions on which to tap?
8. Door Pins - Instructions say:
Right/Front is Red/Blue in pin 12
Red/Blue was in pin 9
Yellow/Black was in pin 12
Which should I go with?
Thanks again, all help is greatly appreciated!
__________________
12volts green (40A) + ignition harness
Starter brown + ignition harness
Second Starter lt. green or blue/green + ignition harness
Ignition black/red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory red + ignition harness
Second Accessory purple + ignition harness
Keysense red/blue to black/red + ign harn or BCM R of column, pin 37
Power Lock blue - driver door module in door
Power Unlock red (double pulse) - driver door module in door
Lock Motor purple 5wi BCM to right of column, pin 65
Unlock Motor green 5wi BCM to right of column, pin 59
Parking Lights+ red/blue + dimmer switch on dash
Parking Lights- N/A
Hazards white/black - BCM to right of column, pin 29
Turn Signal(L) green/black + BCM to right of column, pin 60
Turn Signal(R) green/yellow + BCM to right of column, pin 61
Reverse Light green/white + inside rearview mirror
Door Trigger see notes - BCM to right of column
Notes: The LF door trigger is lt. blue in pin 47. The RF door trigger is red/blue in pin 12. The LR door trigger is red/yellow in pin 48. The RR door trigger is red/white or gray in pin 13. Use all four wires and diode isolate each.
Dome Supervision blue - BCM to right of column, pin 63
Notes: The blue wire is for the dome lights and puddle lights. For the step lights use red/white in pin 62 at the BCM.
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT white/blue or black ac any ignition coil
Wait to start N/A
Brake Wire red/green or red/black + brake pedal switch
Parking Brake green - parking brake switch or cluster
Horn Trigger red/white - horn switch
Memory Seat 1 lt. green/black - memory mod. left of column, pin 9
Memory Seat 2 pink/blue - memory mod. left of column, pin 25
Memory Seat 3 N/A -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on the SE and LE models. Optional on the Crew Cab XE models.
Door Lock Interface Required:
No Type:
Data Bus
Part #: IM-Nissan-1
Notes:
Smart Starter Kill Relays: Not Available
Best way to do it is to test it and see which one give's you +12V when you press the pedal. I believe it's the one located higher towards the dash...but again, it's been a while. Use a Digital Muti-Meter (DMM) if you can!
For door triggers you NEED to test. The colors for these vary so often it's rediculous. They are negative trigger, so I recommend hooking up one of your leads to +12v and the other to the suspect wire...open the door, if it reads +12v...that's it.
That's what I'm here for!
BTW...what unit are you installing?
- Marc
Member CTFBC
You need a relay to convert the negative door pulse to positive pulse.
Only if the unit he's installing only accepts positive door trigger. Most have two wires...one for positive and one for negative. DEI's units use purple for + and green for -. This is why I asked him what unit he's installing. Maybe I can give him a few more tricks.
- Marc
I'm installing a Prestige unit i bought several years ago but only got a month out of it before parking the 69 chevy. But yes, the unit does have a wire for the neg door trigger so i'll go ahead and do some testing for assurance.
Thanks for all your help! i'll let yal know how it goes
__________________
Keep us posted...and in case you want some quicker answers in case I miss the thread, just PM me. BBF doesn't have all the answers all the time...but he knows where to find em
- Marc
