Radiator hose collapsed - why? - Nissan Titan Forum
post #1 of 14 Old 11-29-2007, 04:40 PM Thread Starter
Predator
Shift_Enthusiast
Predator's Avatar
Quoted: 0 Post(s)
I was looking under my hood today at my dead battery and I noticed that my top Radiator hose was collapsed.
Why does that happen?
Is there anything that needs to be fixed?
thanks
2005 Titan 4x4 LE King Cab - Silver
Offroad/Bigtow/Steprails/LowPro Tonneau Cover/Sirius
Predator is offline
post #2 of 14 Old 11-29-2007, 04:43 PM
TITAN57
Shift_Obsessed
TITAN57's Avatar
Quoted: 0 Post(s)
There have been a few complaints about that...........can't remember
the outcome
2004 4x2 SE Crew Cab Big Tow
TITAN57 is offline
post #3 of 14 Old 11-29-2007, 04:43 PM
scr38
Administrator
Shift_Obsessed
scr38's Avatar
Quoted: 25 Post(s)
Garage
This happens often. When the coolant cools it contracts and the vacuum causes the hose to collapse. Really nothing to worry about.
scr38 is offline
post #4 of 14 Old 11-29-2007, 06:32 PM
skyhammer
Shift_Enthusiast
Quoted: 0 Post(s)
The Spot and TT both have several threads on this subject. While no one had reported any problems with the hose collapse, some folks didn't think this was normal and they thought that eventually this would weaken the hose.
Whenever this topic comes up, it is in the Fall when we experience rapid and large temperature extremes.
At any rate, the fix for this has been a new radiator cap, everyone I have read about with this problem replaced their cap and never had the problem again. TS has the best thread on this. Some people also had a new hose made that has thicker sidewalls, as the Nissan hose is rather flimsy.
07 Tundra Limited DC, 4X4, 5.7L
NAV, TRD,TOW
Xlerator Exhaust, aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline
post #5 of 14 Old 11-29-2007, 06:59 PM
54warrior
Shift_Hardcore
54warrior's Avatar
Quoted: 0 Post(s)
Send a message via AIM to 54warrior
Interesting, I assume this is the upper hose?? Usually the lower ones have the springs inside them, correct???
2005 Nissan Titan CC SE 4x4
6" Stage 1 Procomp Lift, SAW Coilovers-Front, Bilstein 5125 Series Shocks-Rear, Total Chaos Shackles, Custom Skid Plates
35x12.50-18 Kumho Road Venture M/T, 18x9" KMC Addict's, PRG Billet Drive Shaft Spacer, PRG Street Traction Bars, Hella 500 Series Driving Lights
54warrior is offline
post #6 of 14 Old 11-29-2007, 07:47 PM
skyhammer
Shift_Enthusiast
Quoted: 0 Post(s)
All the pictures I have seen are of the upper hose which I guess makes sense, as it seems to me that the upper hose is the one which has a better chance of losing fluid under a vacuum condition.
I never paid much attention to the bottom hose and don't know if is of a sturdier construction than the top hose.
NAV, TRD,TOW
Desert Sand Mica
post #7 of 14 Old 11-29-2007, 08:18 PM
asheborotitan
Shift_Enthusiast
asheborotitan's Avatar
Quoted: 0 Post(s)
I just had the same problem this past weekend. I was changing my oil and noticed the collapsed hose. I let the pressure off the cap and the hose flexed back to normal. I have not looked at it since then to see if is has done it again. Funny, how a thread on this comes just when I had the same issue!!
White 2006 Crew Cab 4x4 off road package, Westin Nerf Bars, Bully Step bar in rear hitch receiver, Cabelas Bug Deflector, Spider Web Grill, Aftermarket Sirius radio. 6 CD changer, Fog Lights, Adjustable Brake pedal, Electric Rear Window.
asheborotitan is offline
post #8 of 14 Old 01-04-2008, 06:31 PM
LasVegasTitan
Shift_Enthusiast
LasVegasTitan's Avatar
Quoted: 0 Post(s)
I had this happen recently, turned on the truck and it fixed itself after a minute. Now for some reason my resevoir is like completely full almost, what would cause this? Is the truck ok to drive right now?
LasVegasTitan is offline
post #9 of 14 Old 01-04-2008, 06:34 PM
cool65hntr
Shift_Enthusiast
cool65hntr's Avatar
Quoted: 0 Post(s)
This happened to mine too
I bet its more common than everybody thinks, its just that not many people notice this
2* Timing Advance Bull Bar with 6 in Pro Comp 130 watt Lights 15% Tint Roll-n-lock bed cover
Bed Liner JBA EVOL exhaust PRG Mini Lift with 1.5 in blocks Donahoe Racing Rear Shocks
Toyo Open Country M/T 33/12.5/18
Chrome fog light Bezel-Thanks shorttimer (karma)
cool65hntr is offline
post #10 of 14 Old 01-04-2008, 07:31 PM
LasVegasTitan
Shift_Enthusiast
Quoted: 0 Post(s)
did the level of your overflow tank get extremely high too?
User Tag List
Linear Mode Linear Mode
