» Featured Product
» Wheel & Tire Center
» Sponsors
» Sponsors
  #1
Old 12-05-2007, 10:38 PM
SHAKEDOWN's Avatar
SHAKEDOWN SHAKEDOWN is offline
Shift_Enthusiast
A/C Blower cutting off problem solved?
Some of you might remember I had posted a spotty problem with my fan/blower cutting off by itself. Others have too. When it happened I would have to turn off the fan and then turn it back on and it would work fine. I could never get it to repeat itself for the Dealer. This started happening just a couple of weeks after taking delivery in May of '05. It would only happen, as I recall, when using the A/C. Finally, the other day I was sitting in a parking lot with the A/C on and the fan quit without any imput from me. I was a couple of miles from the Dealer and I took it to them so they could observe it happening. The tech, after putting a tester on the blower control, said it was the resistor in the "Variable Blower Control Module" located under the glove box. It is a $56.95 part. Part number 27151-5Z000. It is an easy install. Just two screws and the power plug. Hope this helps you other folks who have the same issue. Time will tell if this new module will permanantly solve the problem. I will let you know if it happens again.
ID:	34930   Click image for larger version
ID:	34931   Click image for larger version
__________________
Titan 5.6/It's the price we pay for the power we want / 2005 SE 4X4/ Red Alert/ Crew Cab/ Big Tow pkg/ SE Popular pkg/ Westin stainless nerf bars / Truxedo bed cover/ AccuPower-USA POD brake controler/ LineX Bedliner
  #2
Old 12-05-2007, 10:44 PM
rltilley's Avatar
rltilley rltilley is offline
Shift_Enthusiast
The fan in my Xterra recently started only working on level 4 (high). Turns out this is a common problem with the Xterra & the solution was the same as yours. A new blower resistor. It was a $25 part & took 10 minutes to replace. Location was also under the glove box. Works perfectly now.
  #3
Old 12-07-2007, 09:52 PM
Greenlee Greenlee is offline
Shift_lurker
Thanks for posting this. My truck has done this a few times.
It usually only does it after driving long distances. It happened three times on a trip from Colorado
To Texas.
__________________
2006 Crew Cab 4X4 LE
  #4
Old 08-03-2008, 05:07 PM
SHAKEDOWN's Avatar
Shift_Enthusiast
It's been eight months now and the problem has never repeated. Looks like the new module is the permanent fix.
__________________
  #5
Old 08-03-2008, 11:47 PM
NKTITAN711's Avatar
NKTITAN711 NKTITAN711 is offline
Shift_Obsessed
I'm glad you got it straightened. This will help out others with the problem.
__________________
2005 CC 4x4 SE Radiant (sexy) Silver. Stillen dual exit exhaust, AEM Intake, PowerAid TBS, Stillen Long tube headers, Stillen B pipes, '07 intake manifold, Tru Trac, MagHytec Diff. Cover, Active Tuning grounding kit, T-REX grill, chrome door pillars, Ventshade In Channel visors, OEM rubber floor mats, tint on front windows, Orion 10 sub and Orion Cobalt 150x2 amp, Delphi XM Unit, U.W.S. Step Rails, Throttle Body Coolant Mod, Ams-Oil, Sylvania SilverStars (hi/low), White Knight Custom rear light system. PRG UCA's, S.A.W. Coilovers, 1" rear block, Icon rear shocks, UPREV OSIRIS TUNED!!! BFG KM2 35's on 18" chrome OEM 6 spokes.
  #6
Old 08-04-2008, 04:23 AM
cpaul cpaul is offline
Shift_lurker
Do you know if the module had three fins or five. The five fin is the fix for the problem. The old dealer stock may not have been upgraded yet. The three fin did not have enough surface area to dissipate the heat from the power transistor in the module.
  #7
Old 08-04-2008, 09:13 AM
hihosilver's Avatar
hihosilver hihosilver is offline
Shift_Fanatic
Send a message via AIM to hihosilver
thanks alot mine does the same thing i am on my way to the dealer now
__________________
** 05 4x4 cc xe**
* mods*
exterior-leveling kit,go rhino step bars, bull bar, 1 piece black billet grill, hids(4300k), black ebay tail lights, jba exhaust piping with slp muffler, k&n air charger intake, 2* timing,6" pro comp lift
interior-2 10" subs, bazooka amp, custom mounted scan gauge
* future pro comp 6" lift, rims and tires and alot more lol
  #8
Old 08-04-2008, 02:33 PM
SHAKEDOWN's Avatar
Shift_Enthusiast
New module has five fins. I did not think to look and count the old modules fins.
Did not think about the heat disipation either but it makes sense. Good point.
__________________
  #9
Old 08-04-2008, 06:33 PM
04titanss's Avatar
Shift_Obsessed
Good Find!
__________________
2004 XE KC Performance Mods: PGM, Uprev, Stillen LT Headers, RB 170 T-Stat, 2*, Volant Gen 3 W/ RB Ram Air, 07 Exhaust W/ X-Pipe, Duel 14" Magnaflow's & Duel 07 Tail Pipe's, Truetrac, Jettech Helper Springs, 2.5* Pinion Shims, Burnout Mod, Volant NR Mod, Pgm WP Mod.
UNTUNED 13.900 @ 96.67mph
Best TUNED Run 13.665 @ 98.31mph
04 XE Mod List
  #10
Old 08-15-2008, 06:29 PM
Mychael101's Avatar
Mychael101 Mychael101 is offline
Shift_Obsessed
Tried it today and my a/c was still broken. This makes the 3rd repair attempt. They are sending someone from Nissan to check it out now.
__________________
Turbo system by me, tuned by Bully Dog
444hp and 512ft lbs at the wheels on 91 octane
The trouble with doing something right the first time is that nobody appreciates how difficult it was.
http://www.youtube.com/watch?v=gw8srjVVVXI
Problem with A/C, heat speed dial bassguy Technical Discussion 7 11-21-2007 10:35 PM
A/C always on...Read This! SMPLMN General Discussion 5 04-23-2006 09:21 AM
Rattle Underneath...Problem Solved With PICS Crazy_Steve General Discussion 6 02-11-2006 08:23 AM
Front Differential Problem w/ NO help from NISSAN AlaskanTitan General Discussion 11 12-14-2005 06:09 PM
Problem solved lroshau General Discussion 15 01-09-2005 09:31 AM
Powered by vBulletin®
