Many thanks to SHAKEDOWN! My VBCM (Variable Blower Control Module) was THE CULPRIT! I replaced it and my problem was solved =)
A lil more info regarding my specific scenario:
I have a 2005 Titan. I first noticed my problem a couple of months ago. It started one day when I had my heater on around mid-speed and I noticed that it dropped to a lower speed. I then turned it to hi and it worked just fine. A few days later, it would only work on hi and no in between. About a month later, I went to use my A/C and the problem was still there, but then it started to turn off at the hi speed too. At times I would just put it at the mid-speed mark and it wouldn't do a thing. I'd leave it there for a few minutes then it would suddenly come on at the mid speed rate.. Then it would just shut off again. Eventually, it progressively got worse. At the hi speed, it would just turn on-off-on-off, etc.
My old/bad VBCM was a 5 finner. I replaced it with the 27151-ZM70A that I bought at the local dealership for $61 bucks (couldn't wait to buy it from an online seller, too hot here in Texas). It was a 3 finner! The 5 finner had small fins that are very close together. The 3 finner has coarser fins the have larger gaps. The 2 screws holding it in place are 7/32. Took me about 5 minutes to make the swap! I'm now a happy camper!! =)
