» Wheel & Tire Center
» Sponsors
» Sponsors
ClubTitan.org is the largest Nissan Titan Forum on the internet. Registered Users do not see the above ads.
  #1
Old 12-22-2007, 10:31 AM
hpd's Avatar
hpd hpd is offline
SHIFT_Barney Fife
Shift_Hardcore
passenger side floor mat wett...............
im out of warrenty.... 1st of all..
cleanin' up Titan when i felt the pass. side carpet and it was wett..... is this gonna cost me..? is this a recall item..?? i know others have had this problem
help me out what goes on on this fix..
is this something i can do
or just the stealership...
__________________
HOUSTON POLICE DEPT
BAD BOYS BAD BOYS WHAT U GONNA DO WEN THEY COME 4 U?
  #2
Old 12-22-2007, 10:35 AM
nothatmanymods's Avatar
nothatmanymods nothatmanymods is offline
Shift_Enthusiast
i had this problem in one of my other cars and it was just the seal on the windshield needed to be replaced
__________________
  #3
Old 12-22-2007, 10:38 AM
Ol'Coot's Avatar
Ol'Coot Ol'Coot is online now
Shift_Enthusiast
I've been told that there may be an issue with the A/C condensate drain line. May have shifted......
  #4
Old 12-22-2007, 10:39 AM
hpd's Avatar
hpd hpd is offline
SHIFT_Barney Fife
Shift_Hardcore
is it easy to access?
__________________
HOUSTON POLICE DEPT
  #5
Old 12-22-2007, 10:53 AM
electricjohn electricjohn is offline
Shift_Fanatic
If you are still using your A/C or defrosters, I think it would be your evap coil drain. Its been a common problem, but I don't know the fix although it has to be a do it yourselfer. It is a known problem, but there is no recall on it. For a recall it would have to be a life-safety issue.
__________________
04 SE, White, CC, 4x4, B.T., Pop w/capt, Util. Bed package,Splash Guards,Floor Mats. No mods.(none planned). Gas whore.
  #6
Old 12-22-2007, 11:41 AM
scottsbro23's Avatar
scottsbro23 scottsbro23 is offline
Shift_Hardcore
Here ya go.....
Well here's what I used...
Go behind the passenger side wheel well liner and find the problem..its the brown tube...
Remove the tube from the firewall..
Insert copper "L" tube with rubber sleeve over the drain inside the firewall..
Then slide Brown drain tube back into postition over the Copper Tube..
Next remove all trim so you you can pull the carpet back and let it air out...
Hope this helps..... another member gave me the Copper "L" tube and sleeve... but I'm sure you can search and find more info...
__________________
RIP Bobby Godspeed Brutha
Happiness Is Beating Bama in Anything, Anytime, Anywhere
“I'll keep my Freedom, my Money and My Guns, YOU Keep the CHANGE"
04' LE 4x4 CC OR BT, PRG Mini Kit, Shackles & OR T-Bars, Toyo 35" M/T's, 08' Rear End, 09 Ranchos, Activetuning, 8000K HID Low/Sylvania Highs & Turns, Flowmaster, VOLANT, UpRev 2 deg, JL Audio Cleansweep, Kenwood Subs, Vshortt Custom Box, Clarion & Sony Amps, Cadence 6.5 Comps, 9" Stubby Ant. AVS, Custom Painted Engine Cover IV
SEMPER FI
WAR EAGLE
  #7
Old 12-22-2007, 01:05 PM
NKTITAN711's Avatar
NKTITAN711 NKTITAN711 is offline
Shift_Obsessed
Good info. Just incase mine acts up in the future. Hope it fixes you hpd.
__________________
2005 CC 4x4 SE Radiant (sexy) Silver. Stillen dual exit exhaust, AEM Intake, PowerAid TBS, Stillen Long tube headers, Stillen B pipes, '07 intake manifold, Tru Trac, MagHytec Diff. Cover, Active Tuning grounding kit, T-REX grill, chrome door pillars, Ventshade In Channel visors, OEM rubber floor mats, tint on front windows, Orion 10 sub and Orion Cobalt 150x2 amp, Delphi XM Unit, U.W.S. Step Rails, Throttle Body Coolant Mod, Ams-Oil, Sylvania SilverStars (hi/low), White Knight Custom rear light system. PRG UCA's, S.A.W. Coilovers, 1" rear block, Icon rear shocks, UPREV OSIRIS TUNED!!! BFG KM2 35's on 18" chrome OEM 6 spokes.
  #8
Old 12-22-2007, 01:23 PM
baseballfanz's Avatar
baseballfanz baseballfanz is offline
SHIFT_Mr. Quick Answers
Shift_Obsessed
Here's the TSB on it. While you are out of warranty I know the TSB have very details instructions on how to fix it.
__________________
Titan/Armada part numbers
Nissan's OBD II codes
  #9
Old 12-22-2007, 09:27 PM
jt04titan's Avatar
jt04titan jt04titan is offline
Shift_Enthusiast
i get water under my drivers floor mat just in the center no water anywhere else the edges of the mat aint even wet....cant find it..
__________________
2 degree timing,07 exhaust,14 inch mf dual in sigle out,k&n cai,stillen rear sway bar,armada air dam
  #10
Old 12-23-2007, 10:57 AM
hpd's Avatar
hpd hpd is offline
SHIFT_Barney Fife
Shift_Hardcore
thanks guys!!! thank u baseballfanz and scottsbro23 i will go to homedepot to get a tube to do it myself.....
__________________
HOUSTON POLICE DEPT
vB code is On
Titan/Armada Bolt-On Billet Grill Walkthrough kx250ryder Do it yourself, Tech Tips 15 04-10-2008 09:06 PM
Passenger side rear tire wear Brian68rs General Discussion 35 04-18-2007 10:29 AM
Fix for tick on passenger side!! MikeZ Do it yourself, Tech Tips 5 02-17-2007 04:57 PM
Ride Height - Higher on Passenger side italyguy01 Technical Discussion 10 10-20-2006 07:53 AM
flowmaster catback variation: dual out passenger side..... Thade Performance Mods 3 03-23-2006 04:28 PM
Powered by vBadvanced CMPS v3.0.1
Powered by vBulletin®
