» Wheel & Tire Center
» Sponsors
» Sponsors
ClubTitan.org is the largest Nissan Titan Forum on the internet. Registered Users do not see the above ads.
  #1
Old 08-20-2008, 03:58 PM
PoDunk_Titan's Avatar
PoDunk_Titan PoDunk_Titan is offline
Shift_Fanatic
Video of Step By Step ECU Reset
When trying to explain how to reset the ECU through the computer doesn't always work. So I videotaped myself doing it so I could send to him. Figured I'd share the video link on here as well. I hope this helps someone.
http://www.youtube.com/watch?v=RUhHiJgsmAg
__________________
IRC VK56 Team Member
'04 CC 2WD SE BT w/ K&N FIPK 2, Custom SLP Loudmouth Exhaust, Throttle Body Bypass, Stillen LongTubes, Tru-Trac, PRG Street Traction Bars, Uprev.
Exhaust videos:
http://youtube.com/watch?v=5CT78FTkZhg
http://youtube.com/watch?v=Rq7-ZOWhV...eature=related
  #2
Old 08-20-2008, 04:09 PM
kha4079's Avatar
kha4079 kha4079 is offline
CTs Little Chihuahua
Shift_Obsessed
will you lose your tuning with resetting your ecu?
__________________
IRC VK56 MEMBER 07 Titan Crewcab, UPREV TUNED, Detroit Truetrac, TB Bypass Mod,Transmission Cooler, Ported and Polished TB, TB Screen Removed,Stock Airbox with Custom 4" Ram Air, E-Fans, Magnaflow 18 Inch , JBA Shorty Headers, No Cats. Transgo HD2 VB reprogramming kit, Zex Wet Nitrous Kit 100 shot 12.97 @ 104 mph
  #3
Old 08-20-2008, 04:10 PM
TexasTitan05's Avatar
TexasTitan05 TexasTitan05 is offline
Shift_Obsessed
i wish i could get youtube at work...
__________________
Jeremy/Houston, TX
d0va Signatures
  #4
Old 08-20-2008, 04:14 PM
Shift_Fanatic
Quote:
No. I know it had been addressed before and the answer is no. I checked mine after I did the ECU reset. It will put you back in your stock map though, but all you have to do is switch it to wherever you want it to be. I guess this is more for people w/o osiris/cypher who throw codes and want to clear them. or if you don't have your laptop on you.
__________________
Exhaust videos:
  #5
Old 08-20-2008, 04:25 PM
EAC-ISR's Avatar
EAC-ISR EAC-ISR is offline
Shift_Fanatic
man i had my volume up and when u started the truck up it scraed the crap out of me,sounded really mean..
__________________
2006 XE CC SMOKE TITAN,SB FILTER INTAKE SYSTEM,POWER BT MIRRORS UPGRADE, 6.5 INCH ECLIPSE AVN30D W/NAVI)2 7 INCH HEADREST MONITORS,2 WAY PAGING ALARM,BAK BACKFLIP Tonneau BED COVER ,PRG MINI LIFT KIT, MBS PREDATOR WHEELS 17''S,
YOKOHAMA H/T-S 315/70/17, TB SPACER,22" MAGNAFLOW MUFFLER,WADE WINDOW VENTSHADE AND HOOD PROTECTOR
DDM 8000K HID KIT,DDM 6000k fogs HID kit,
ISR-ILLEGAL SPEED RACING
  #6
Old 08-20-2008, 04:29 PM
Converted's Avatar
Converted Converted is offline
Shift_Fanatic
Why do this??
Clear codes only reason?
__________________
2004 CC 4x2 Galaxy Black, Rockford in dash 6-disc, DVD and TV, Tech12Volt Enclosure w/2 10" Alpine Type R DVC's powered by Rockford P5002, low profile fiberglass Tonneau, AVS in channel, AVS bug deflector, 25% tint on front windows, Volant Gen II CAI, Smoked tails, Magnaflow muffler, Armada Air Dam, remove a leaf drop mod... AND Finally
Custom UPREV tune by Henson Performance
Born 11/03
Adopted 05/06
  #7
Old 08-20-2008, 06:26 PM
Shift_Fanatic
Quote:
Originally Posted by Converted
Why do this??
Not necessarily only reason but that is a good one. there is a list of different things you can do with it and that is done @ the same time but I only did that one the most.
__________________
Exhaust videos:
  #8
Old 08-20-2008, 08:08 PM
04titanss's Avatar
Shift_Obsessed
Good Video. You should have added, If you have a SES light write down the number of blinks for the code thrown, before you hold down the accelator to clear them. Just my .02.
__________________
2004 XE KC Performance Mods: PGM, Stillen LT Headers, RB 170 T-Stat, 2*, Volant Gen 3 W/ RB Ram Air, 07 Exhaust W/ Magnaflow 22" Muffler, Truetrac, Jettech Helper Springs, 2.5* Pinion Shims, Burnout Mod, Volant NR Mod, Pgm WP Mod. UNTUNED 13.900 @ 96.67mph
  #9
Old 08-20-2008, 11:54 PM
Shift_Fanatic
Quote:
Yeah I thought about that. I never really worried about it because I knew the codes I was throwing.
__________________
Exhaust videos:
  #10
Old 08-21-2008, 12:13 AM
Canadian Miner's Avatar
Canadian Miner Canadian Miner is offline
Shift_Hardcore
The codes and how to troubleshoot them are in the service manual and/or there are online lists.
I always record the code two or three times and then look it up before clearing the code. Some codes are caused by temporary issues, moisture, that last mod, pulled wires etc. and after clearing do not return. Others (true problems) will return. And still others that cause a flashing engine light will not clear.
__________________
vB code is On
The Fastest Speed someone has gone with there Titan TroyTitan Performance Mods 189 11-27-2009 12:59 AM
How To - Titan ECU Reset, Throttle & Idle Learning Procedure RockyMtnTitan Do it yourself, Tech Tips 79 08-31-2008 11:27 PM
To ECU reset or Not to ECU reset??? Domo General Discussion 8 06-05-2007 05:13 PM
Don't reset the ECU Qaher Off Topic 4 12-04-2006 09:56 AM
Reset ECU...Truck hauls arce!!! bigshan1 Performance Mods 6 02-17-2006 10:56 AM
Powered by vBadvanced CMPS v3.0.1
Powered by vBulletin®
