» Featured Product
» Wheel & Tire Center
» Sponsors
» Sponsors
Go Back   Nissan Titan Forum: Club Titan Forums > Mods and Technical Discussions > Performance Mods
  #171
Old 06-20-2009, 10:46 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Shift_Enthusiast
Send a message via AIM to DarkblueTA
Quote:
Originally Posted by Toomnymods View Post
Just wondering some more variables of your setup where it wouldnt spool..
Did you have a ball bearing turbo?
What was the dia. of the primaries on your long tubes?
What was your collector size on the longtubes?
What dia piping to the turbo from the manifolds?
Lastly how far back was the turbo?
Was your volumetric efficiency around 93% like the VK56 engine with cams at 6k?
Without knowing all of your setup its like comparing apples to oranges..
1 No, normal journal. BB only spools 200-300rpms faster. If you think otherwise, you're fooling yourself. STS kit on a 2002 SS Camaro from T76 to a BB 76 only added the above spool time. He also runs 10.1 @ 135 in the vegas heat and is driven around town all the time.
2 primaries were 1 5/8" Normal long tubes on a 5.7 liter AND they were coated.
3. Collector was around 3"
4. 2.75"-ish
5. replaced the muffler
6. If you think the VE is 93% you're kidding yourself.
I also had a smaller turbo with a .80 a/r on the ehaust side. I already told you all the stuff we did to the exhaust system pre turbo after putting it on and then it worked fine afterwards. If you don't want to listen, that's not my problem. You forget that your turbo is going to be the biggest restriction in your exhaust.
Not apples to oranges only the vehicles are, turbo's are turbo's are turbo's and if you don't set it up right, it will not run correctly. Period. Now do yourself a favor and read up on the subject.
I'm done trying to help, good luck with your project and hope it works for you.
__________________
DarkblueTA
98 Trans Am.
Engine *Check*
Suspension *Check*
Rear *Check*
Clutch/shifter *Check*
Turbo system *Check*
Yeah, she's ready
Daily driver: 2007 Red Brawn Titan King Cab.
  #172
Old 06-20-2009, 11:02 PM
Toomnymods's Avatar
Toomnymods Toomnymods is offline
SHIFT_Track_ADDICT
Shift_Obsessed
Send a message via MSN to Toomnymods Send a message via Yahoo to Toomnymods
I'm going to go ahead and buy me the .85 a/r exhaust housing and swap the 1.19 for a 1.06 and save it for later when i switch to a front mount after the motor is built.
I bought the dual ball bearing cause i heard it spools harder and realibity is much greater, i dont feel like having to tear it apart after a yr and replacing parts hopefully can get 2-3 yrs out of it before having to replace anything in the turbo
Our headers are nearly identical but my primaries are only 2.25" and my piping will stay 2.5" up to the turbo, and probably a 3.5" to 4" out the back
With a .85 ar This will spool fully by 3800 rpms right? I guess this is my goal, cause on the street when i floor it it almost instantly goes to 4k when the converter locks up ( i know you really can't go by the dummy gauge in the truck) but i imagine it's within 200 rpms or so
__________________
05' Blizzard White 4X2 KC SE
Wheels: Foose Speedster 6 22's /w Nitto 420-S 305-40R-22
Garrett GT4094R Ball bearing turbo, Tial 60mm WG, Tial 50mm BOV, Air to Water Intercooler, etc...
Performance mods: Toomany... click here for info:http://www.cardomain.com/ride/2685188
12.3@109mph 7/9/10 HRP
93 Map 468 RWHP / 480 TQ in 96F heat
109 Map 488 RWHP / 493 TQ
Stereo Mods: Alpine IVA-W505 DVD/CD player
  #173
Old 06-21-2009, 06:55 PM
Mychael101's Avatar
Mychael101 Mychael101 is offline
Shift_Obsessed
DarkblueTA, he obviously has enough faith in what people in message boards and salesmen have to say. Let him play the hand he was dealt. He's made it clear that he has it covered and doesn't need our help. I'm actually surprised that he is actually asking more and more questions of you.
BTW, I'm thinking I'll be heading your way in September for a weekend. So count on the first few drinks being on me. If things go well on my tuning project, I may end up down that way for several months.
Toomny, I wish you the best on your project. I look forward to your results regardless of the outcome.
__________________
Turbo system by me, tuned by Bully Dog
444hp and 512ft lbs at the wheels on 91 octane
The trouble with doing something right the first time is that nobody appreciates how difficult it was.
http://www.youtube.com/watch?v=gw8srjVVVXI
  #174
Old 06-21-2009, 06:56 PM
Toughtitan08 Toughtitan08 is offline
Shift_lurker
The VK56 is 340 cu in and is over 100% vol efficiency when cammed. I can guarantee that Chris' engine puts out well over 400hp at the crank. I am also doing a single turbo setup based on the same turbo, GT4094R with
the 1.19 or 1.09 a/r. Garrett told me that with a 5.3L engine it will spool plenty fast enough. Mine will be front mount of course, in my 1986 Cutlass. I don't think the a/r will be that prominent an issue with him myself. If a little old 4.8L can spool a PT88 standard journal turbo then a slightly bigger BB 94mm turbo will not be that much of an issue for a bigger engine with better efficiency.
__________________
2008 Titan KC LWB XE
Titan Tough with the right stuff!!
Cherrybomb c/b 300621 (tailpipes) Hooker Aerochambers with custom equal length X-pipe, AEM Brute Force CAI, BDGT, Silverstar Ultra bulbs (very bright).
14.1@95mph FST (BDGT time) 14.26@95.85 mph latest track time
Next: LT headers, Uprev Osiris Tuner, Level 10 VB, JWT cams, 3.73 gears, Eliminate one wheel peel!!!!
"If 'yer spinnin' you ain't winin'!!"
  #175
Old 06-21-2009, 07:54 PM
kha4079's Avatar
kha4079 kha4079 is offline
CTs Little Chihuahua
Shift_Obsessed
Quote:
Originally Posted by Qaher View Post
the below is their setup for me what do you think?
Upgraded turbo LSX 7.0L short block $7350
Turbo Long block w/L92 heads $11350
Upgrades include Dragonslayer crankshaft, Lunati Hbeam rods, Custom Turbo Pistons, ARP studs, Steel top turbo Piston rings.
Note: i told them that i will have a STS twin turbo rated between 800 to 1000HP.
if u can get a hold of an LSX block id go bigger than 427. theres a guy here in houston doing a 482 LSX build with a turbo
__________________
IRC VK56 MEMBER 07 Titan Crewcab, UPREV TUNED, Detroit Truetrac, TB Bypass Mod,Transmission Cooler, Ported and Polished TB, TB Screen Removed,Stock Airbox with Custom 4" Ram Air, E-Fans, Magnaflow 18 Inch , JBA Shorty Headers, No Cats. Transgo HD2 VB reprogramming kit, Zex Wet Nitrous Kit 100 shot, JWT CS2 CAMS12.97 @ 104 mph BEFORE CAMS 13.32 @ 102 N/A with cams
  #176
Old 06-21-2009, 08:12 PM
Toomnymods's Avatar
SHIFT_Track_ADDICT
Shift_Obsessed
Ahhhh screw it Do this!! 540cuin. twin supercharged prob well over 1,600 hp and 1,200 tq
reading thru the comments it said on the street he de-tunes it down to 1,000hp lol
http://videos.streetfire.net/video/N...40ci_91856.htm
__________________
  #177
Old 06-25-2009, 12:43 PM
JROCK70 JROCK70 is offline
Shift_lurker
cant wait to see it man, im saveing up the money to start my beautiful titan project, hopefully ill be able to begin soon. I might have some question in the next few months.lol
  #178
Old 07-04-2009, 01:40 PM
Toomnymods's Avatar
SHIFT_Track_ADDICT
Shift_Obsessed
I ordered another 400 bucks of fuel stuff from Jeg's yesterday, I'm glad to say the fuel system is almost complete just need my 20 gallon fuel cell, RC engineering injectors, and custom made fuel rails.. Will post the pics soon as it arrives..
__________________
  #179
Old 07-08-2009, 08:54 PM
Toomnymods's Avatar
SHIFT_Track_ADDICT
Shift_Obsessed
OK the Shipment has Arrived :P
Here I mainly finished buying the rest of the Russell anodized 6an, 8an, and 10an fuel fittings, the 10AN stainless steel braided hose, and the MSD RPM pickup wire needed for the Aeromotive fuel controller i bought a few weeks ago..
All that is needed for the fuel system now is my 750cc RC engineering fuel injectors, and the custom made fuel rails
Here's the pics:
Might not look like much but this was over $400.00 of fuel accesories, pushing my total spent so far already over $6,000 now
In the center is the 8AN 180 degree fitting that'll be used for each fuel rail to feed fuel to the front of both of the fuel rails ( I bought two of these )
This was the most expensive part I bought in this session the 20 ft. of Russell 10AN stainless steel braided hose
Lastly is the MSD RPM pickup wire that'll be used to feed rpm signal to the Aeromotive fuel controller
__________________
  #180
Old 07-08-2009, 09:09 PM
RelentlessNiSMo's Avatar
RelentlessNiSMo RelentlessNiSMo is offline
Shift_Fanatic
Great job buddy!! Cant wait to see the next step!! We got ours up and running again today...now back to the Dyno we go.
__________________
New Year's Surprise!! New ClubTitan member!! myusername Off Topic 10 01-05-2008 05:17 PM
2 Years, 71,717 Mile Gala Event TheSquid General Discussion 17 08-14-2006 05:27 AM
What a difference 100 years make! Off Topic 5 12-04-2005 11:53 AM
28 years comin up float_test Off Topic 10 11-23-2005 03:52 PM
ISS marks five years... Flight_Test Off Topic 4 11-02-2005 12:53 PM
Powered by vBulletin®
