Heater will not Blow Hot Air - Nissan Titan Forum
post #1 of 14 Old 06-03-2009, 02:48 AM Thread Starter
BruteTitan
Shift_Hardcore
BruteTitan's Avatar
Quoted: 0 Post(s)
Question Heater will not Blow Hot Air
Well just a few days ago my heater in the titan quit blowing hot air, it only blows cold air. This happened instantly, not over a period of time. I have the dual climate controls and the fan works fine, ac works fine, but the temp. doesn't change at all from 60-90*. What do you think the most common problem could be? I am thinking something to do with the temp control module or actuator. Anybody got any ideas. Coolant is fine, just replaced raditor cap, engine temp is fine.
06 Titan LE 4X4-
Cosmetic Mods- Asanti AF142 22's, Toyo Proxes 305/45/22, Air Lift Air bag auto leveling kit, PRG shackels, 140 Series LightForce Lights behind grille, Black Halo Projector headlights w/8000K HIDs High/Low/Fogs, Stainless Gauge Faceplate, Tech 12 underseat sub, Viper 5900T auto start/security, Billet grillle, Chrome bug guard, Armada spoiler painted to match, 5% tint, vent visors, Black LED Taillights/Third Brake light, Keystone Good Hood
Performance Mods- AEM Brute Force CAI, Airaid TBS, Stillen Ceramic Headers, Dynatech Highflow Cats, Custom Borla Dual Exhaust, Uprev Tuned, Detroit Truetrac,IPT Trans Rebuild Kit, IPT VB, Burnout Mod
BruteTitan is offline
post #2 of 14 Old 06-03-2009, 06:27 AM
benbrookjohn
Shift_Newbie
Quoted: 1 Post(s)
Try to isolate the problem by shutting off all controls but the primary and see if you get hot air and visce/versa.
benbrookjohn is offline
post #3 of 14 Old 06-03-2009, 06:58 AM
CrashBoss
Shift_Enthusiast
Quoted: 0 Post(s)
Check the servos that move the damper plates, and the damper plates themselves in the air box for free movement.
The servos themselves are fairly bullet proof, but the chinsey little plastic doo-hicky (technical term) that the rods connect to break easy if there is a jam, i.e. airbox distorts due to high heat.
Neighbors Armada went through this saga last fall. Nissan, out of frustration and my neighbor threatening lemon law, replaced the entire airbox/damper set up.
05 KC 2x Big Tow LE-Injen CAI, Armada Lip, Volant LED tails, led 3rd lamp, DDM HID 55W high, 35W low, 880 fog all 5000K, Lorado tonneau.
CrashBoss is offline
post #4 of 14 Old 06-03-2009, 07:32 AM Thread Starter
BruteTitan
Shift_Hardcore
BruteTitan's Avatar
Quoted: 0 Post(s)
Where is the airbox/dampner located? Is it inside the dash on the passenger side? Ya it doesn't work under any of the modes, defrost, feet, face, ac on/off, dual/single climate. That sounds like the problem, but Alaska doesn't get high heat situations although it gets actuated often due ambient temperature fluctuations. Thanks
06 Titan LE 4X4-
post #5 of 14 Old 06-03-2009, 10:05 AM
CrashBoss
Shift_Enthusiast
Quoted: 0 Post(s)
Here is the link to the FSMs
http://www.nicoclub.com/FSM/titan/
That should help you get going with it...
post #6 of 14 Old 06-04-2009, 10:56 AM
DEMOND
Shift_Hardcore
DEMOND's Avatar
Quoted: 0 Post(s)
Send a message via AIM to DEMOND
This happened to the wifes 2004 maxima and come to find out there was no coolant in the radiator. No leaks found in the garage or driveway but some how the upper and lower rad hoses wear bad and leaked. It also never ran hot without coolant. I just re-read your post and see that the coolant is fine.
DEMOND is offline
post #7 of 14 Old 06-04-2009, 11:41 PM
Kronos1965
Shift_Obsessed
Kronos1965's Avatar
Quoted: 6 Post(s)
No heat...
A couple things to also consider checking.
1. Coolant level.
2. Replace radiator cap
3. Check thermostat
Raleigh, NC
If there are no dogs in Heaven, then when I die I want to go where they went. -- Will Rogers
Kronos1965 is offline
post #8 of 14 Old 06-05-2009, 03:08 AM Thread Starter
BruteTitan
Shift_Hardcore
BruteTitan's Avatar
Quoted: 0 Post(s)
I just had the cap replaced.... I will check the level just in case though.
06 Titan LE 4X4-
post #9 of 14 Old 06-05-2009, 10:26 AM
Titanupgirl425
Shift_Enthusiast
Quoted: 0 Post(s)
JUST COME TO VEGAS... roll your windows down.. it will blow hot air!! lol jk.. im sorry that really sucks though.. seeing that you live in alaska.. =(
DESERTROGUE™
TitanNutGirl™
TUGthedieselhunter™
[/CENTER]
Titanupgirl425 is offline
post #10 of 14 Old 06-06-2009, 03:49 AM Thread Starter
BruteTitan
Shift_Hardcore
BruteTitan's Avatar
Quoted: 0 Post(s)
Ya Alaska's weather sucks...Except 24hrs of daylight in the summer is kinda nice
06 Titan LE 4X4-
User Tag List
Linear Mode Linear Mode
Hot Air 54warrior Off Topic 1 12-10-2007 11:28 AM
SunCoastHood: Discount & Group Buy! Rock$tarTitan General Discussion 32 11-15-2007 01:34 PM
The Science Behind An Air Intake TheSquid Technical Discussion 17 10-26-2007 11:07 AM
How To - Install Volant Cold Air Intake M4ck Do it yourself, Tech Tips 21 12-03-2006 01:10 AM
Ram Air-Check out OEM air box snorkel under left front fener AquaDios Performance Mods 6 02-03-2006 06:17 PM
