VHT NightShades Headlight Mod "How To" - Nissan Titan Forum
post #1 of 30 Old 08-23-2009, 12:59 PM Thread Starter
ansin529
Shift_Enthusiast
ansin529's Avatar
Quoted: 0 Post(s)
2004 Nissan Titan KC SE
After some serious thought, I decided to tint my headlights utilyzing VHT Nightshades. There have been numerous threads that indicated a mixed review of thoughts as it pertains to this mod. My decision comes as a result of me being hard head, cheap and an individual who loves to perform his own aftermarket modifications.
This thread will provide my honest opinion of the product and it's application, before and after photographs and detailed instructions. The photographs were taken before my clearcoat application. I will submit a photograph of them at a later time.
*My Honest Opinion*
If you are an avid "do it yourself individual", you will be able to perform this mod utilyzing some paitence and moderate hair pulling. I would indeed recommend this mod to others who have or are currently thinking about it.
*Step by Step Directions*
1. Remove your headlight assembly from your truck (four bolts total).
2. Completely clean your headlight assembly with any kind of non abrasive cleaner or hot sudsy water.
3. Fill a bowl or small bucket of water with sudsy water and a soft rag.
The sudsy water will assist your sandpaper with gliding across the surface of the headlight.
4. Start out by using a 320-500 grit sandpaper and wet sand the entire surface of the headlight. Ensure that you are sanding the headlight surface evenly.
5. Wipe down the headlight with your rag from time to time to remove the oxidation and clear coat that is removed during sanding. This process will more than likely run you an hour or so while sipping on your beverage and swearing your arm is going to fall off.
6. After approximately an hour, wash the headlight surface and let it air dry. The entire headlight surface should be hazy from your sanding.
7. Now utilyze 800-1000 grit sandpaper and wet sand the entire surface of the headlight. Ensure that you are sanding the headlight surface evenly.
8. Once this is complete, complete step six again.
9. This step is very important. If you do not complete this step, you will be sorely disappointed when you notice your nightshades run and crack. Completely wash the headlight surface with somekind of acetone or wax and grease remover. You must ensure that there is no kind of oily residue left on the headlight before you begin your tinting.
10. Shake your can of VHT nightshades tint vigoursly for approximately five minutes.
11. Lightly spray your headlight with the nightshades across the entire surface.
12. Time 10 minutes between each coat and for goodness sakes; please ensure these coats are very light. My headlight received 10 individual layers. If you do not adhere to this recommendation, you will be wet sanding these headlights down for an hour more and have to start all over (do you really have to ask).
13. Once you reach your tinting preference, allow as close to 24 hours curing time.
14. Lights spray your headlight with your choice of clearcoat. This will give your headlight that glossy look you had before your mod.
Goodluck and I hope this helps anyone who is genuinely interested. If you think that this thread warrants a sticky, make it easy for everyone to research.
ID:	45134   Click image for larger version
ID:	45135   Click image for larger version
2004 Nissan Titan: Custom Interior (my creation),Custom Interior Lighting (my creation), Custom Audio (my creation), Burn-Out Mod, Blacked out Tailights, Black headlights with Leds and Halos, Duckbill Spoiler (my creation), Badge Removal, Throttle Body Coolant Bypass, 3 1/2" Aluminum CAI, Rear of Truck Lowered 3", Dual Exhaust, Street Scene Roll Pan,Custom Upper/Lower Grill (my creation), Tailgate Handle Relocation/Shaved Tailgate (my creation), Toneau Cover, Cowl-Induction Hood (my creation),Liquid Metal 20s/ Falken Tires,Tonneau Cover, Green Underbody Lighting, Custom Fog Light Covers (my creation) and Three Gauge A Pillar.
ansin529 is offline
post #2 of 30 Old 08-23-2009, 02:24 PM
BuenasNalgas
Moderator
Shift_Obsessed
BuenasNalgas's Avatar
Quoted: 0 Post(s)
My tails are tinted w/ VHT and love em. How is your light output with this? Do you have any pics that are not close ups of these on your truck?
___________
It's A Titan
BuenasNalgas is offline
post #3 of 30 Old 08-23-2009, 02:38 PM
pbballa71
Shift_Enthusiast
pbballa71's Avatar
Quoted: 0 Post(s)
Looks good I'm spraying mine sometime this week. Thanks for the info
VK56 Racing Member
2004 SE Crew Cab 4x4 BT,6" Fabtech, 18" XD Addicts, 35" Toyo MT's, Magnaflow 18" muffler, 2-10'' Pioneer Premiers, 1000 watt Kenwood amp, blacked out badges, tinted tails, VHT Niteshades Headlights, Helix TBS, TB screen removal, 55 watt 6000K HID low beams, Lund Avenger bug guard, Michelin floor mats
pbballa71 is offline
post #4 of 30 Old 08-23-2009, 05:23 PM Thread Starter
ansin529
Shift_Enthusiast
ansin529's Avatar
Quoted: 0 Post(s)
Thanks for the compliments guys...
I will take additional photographs of the headlights installed and from different angels this evening and will post them. I will also take photographs of them in operation during night time hours.
ansin529 is offline
post #5 of 30 Old 08-23-2009, 09:55 PM
titanman17
Shift_Enthusiast
titanman17's Avatar
Quoted: 0 Post(s)
that paint has red flakes in it because it is made for taillights. i think t is to help them shine more red in the dark.
i did my cousins and they shined with a red tint.
07 kc, 18x9 xd diesel wheels, s&b cai, helix tbs, flowmaster super 44s dumped before the axle, bully dog power pup, fabtech 6 inch lift, 35x12.50x18 nitto mud grapplers.
titanman17 is offline
post #6 of 30 Old 08-23-2009, 10:28 PM
titanse05
Shift_Obsessed
Quoted: 0 Post(s)
Ummm, yeah I would never do this in a million years but to each his own.
Titan with lots of mods.......
titanse05 is offline
post #7 of 30 Old 08-24-2009, 08:37 AM
usermmg
Shift_lurker
Quoted: 0 Post(s)
i also did my heads and tails about a week ago. The first attempt was all screwed up and my headlights came out totally black ( as you can see in the second image ). I removed the paint and started over. The finally attempt actually came out looking really good. The heads now have a smoked effect buy not shiny at all. I also made cut-outs for my back up lights on the second attempt at the tails as well...
ID:	45145   Click image for larger version
ID:	45146   Click image for larger version
ID:	45147   Click image for larger version
ID:	45148   Click image for larger version
usermmg is offline
post #8 of 30 Old 08-24-2009, 09:10 AM
titanse05
Shift_Obsessed
Quoted: 0 Post(s)
I'll stick with the headlight mod.
http://www.clubtitan.org/forums/showthread.php?t=26531
post #9 of 30 Old 08-24-2009, 10:28 AM
BuenasNalgas
Moderator
Shift_Obsessed
Quoted: 0 Post(s)
Quote:
Originally Posted by titanse05 View Post
X2
___________
It's A Titan
post #10 of 30 Old 08-24-2009, 05:25 PM
gabriel c.
Shift_Enthusiast
gabriel c.'s Avatar
Quoted: 0 Post(s)
if you are ever involved in an accident ( hope you never are ) especially at night guess what excuse they are going to use to fry you.
SIG SAUER
gabriel c. is offline
User Tag List
Linear Mode Linear Mode
Installed my oil "Catch cans", DIY mod ($20) Jarvis Performance Mods 1 07-17-2009 08:19 PM
in reguards to the "2007 intake manifold mod" thread... Jon_UT Performance Mods 30 04-27-2008 09:04 PM
VSS wire in 04 Titan LE, CC for "programing Nav while moving" mod Machado7 Interior Mods 10 12-09-2007 10:40 PM
Headlight "Karma" firecracker General Discussion 100 11-25-2007 04:29 PM
anyone wanna see my headlight "karma"?? lol... TitanLE General Discussion 20 01-16-2007 07:00 AM
