Code 0420 &-430 Cat problem - Nissan Titan Forum
post #1 of 4 Old 12-05-2009, 07:07 PM Thread Starter
kristian_dancer
Shift_lurker
Quoted: 0 Post(s)
Exclamation Code 0420 &-430 Cat problem
Hey I intermitantly get 0420 codes come up.
If I put premium in I get it.
If I run an injector cleaner I get it, and occassional it comes up at random times.
After resetting it stays gone sometimes for one or two fill ups.
It never comes up at the same point in the tank range say when Im running low.
The truck runs great with no obvious problems except this random code and a very occasional (first time yesterday) 0430.
Any Ideas? and any major concerns to worry about?
Thanks
Kris
kristian_dancer is offline
post #2 of 4 Old 12-06-2009, 06:36 PM
baseballfanz
SHIFT_Mr. Quick Answers
Shift_Obsessed
baseballfanz's Avatar
Quoted: 0 Post(s)
Any time you're getting codes for the cats it's a concern IMO.
The cats could break up and get suck back into the engine.
P0420
Diagnosis Logic
The ECM monitors the switching frequency ratio of heated oxygen sensors 1 and 2.
A three way catalyst (Manifold) with high oxygen storage capacity will indicate a low switching frequency of heated oxygen sensor 2. As oxygen storage capacity decreases, the heated oxygen sensor 2 switching frequency will increase.
When the frequency ratio of heated oxygen sensors 1 and 2 approaches a specified limit value, the three way catalyst (Manifold) malfunction is diagnosed.
DTC detecting condition:
* Three way catalyst (Manifold) does not operate properly.
* Three way catalyst (Manifold) does not have enough oxygen storage capacity.
Possible cause:
* Exhaust tube
* Intake air leaks
* Fuel injectors may be faulty
* Fuel injector leaks
* Spark plugs may be faulty
* Improper ignition timing
* Engine Control Module (ECM) program
P0430
Diagnosis Logic
Possible cause:
* Exhaust tube
* Intake air leaks
baseballfanz is offline
post #3 of 4 Old 12-06-2009, 09:37 PM Thread Starter
kristian_dancer
Shift_lurker
Quoted: 0 Post(s)
Thanks I am going to take it in to the stealer.
Any suggestions how to get them to pay for it ?
Do you know If I am covered under the Federal Envoiromental protection thingy (Technical term that) on all vehicles after 1995 something to do with 8 years or 80k miles it's manurfacturers problem or so I have heard.
She's a 2005 with 77,000 on her she has an aftermarket exhaust on her cat back im fairly sure.
Kris
post #4 of 4 Old 12-07-2009, 02:40 AM
Leadsled124
Shift_Obsessed
Leadsled124's Avatar
Quoted: 0 Post(s)
Kris
I believe you will fall under the emissions law. Manufacture responsible for cats for first 80k miles.
Leadsled124 is offline
User Tag List
Linear Mode Linear Mode
Codes 0420 and 0455 TW Catalyst B1 and Evap gross leak kristian_dancer Scheduled or Preventive Maintenance 6 10-09-2009 04:10 PM
Stolen iPod & Amp Problem YoungGunTitan General Discussion 1 02-18-2009 03:36 AM
Engine codes 420/430 scr38 Technical Discussion 32 08-28-2008 08:34 AM
Wild Idea for Stillen S/C CAT Problem Warp09 General Discussion 2 06-11-2007 10:13 PM
Set a code P 0420 JERDOG Technical Discussion 22 04-04-2007 11:11 PM
