Column mounted manual shift button - Nissan Titan Forum
post #1 of 9 Old 02-23-2010, 08:31 AM Thread Starter
JCopeland
Shift_lurker
Quoted: 2 Post(s)
After 195,000 miles something has happend to my truck that I hadn't seen on here or heard about. The button on my shift lever that turns the manual shift on and off stop working yesterday. I know it was working Saturday and Sunday. I tried it again this morning and it still isn't working. Does anyone have any thoughts on what it could be or things I can check. Boat season is coming up soon. I have not looked at the fuses but all other electrical items seem to be working and the transmission in drive is working fine. Thanks for any suggestions.
JCopeland is offline
post #2 of 9 Old 02-23-2010, 01:47 PM
BBtruck
Shift_Enthusiast
BBtruck's Avatar
Quoted: 0 Post(s)
This should give you what you need.
http://www.clubtitan.org/forums/show...t=shift+button
L
My Galaxy '05 XE 4x1 modest mods:
Bilsteins HD front and back, PRG adj. shackles, PRG swaybar endlinks, Stillen front+rear swaybar, RAS, Stillen Rad, BD PP, S&B CAI, DT LT's, Berk MP, SS Zoomers catback, Mag-Hytec rear diff cover, CF dash kit.
BBtruck is offline
post #3 of 9 Old 02-23-2010, 02:32 PM Thread Starter
JCopeland
Shift_lurker
Quoted: 2 Post(s)
It sure does. Looks like I know what I'll be checking this weekend depending on the weather. Thanks a million.
post #4 of 9 Old 02-23-2010, 10:11 PM
o-fivecc
Shift_Obsessed
Quoted: 0 Post(s)
Yeah without even looking at that link BB posted, I bet its about the wiring. Those wires get rubbed and brake or touch which will cause it not to work
New ride: 2005 Pontiac GTO
Sold
2005 Crew Cab...13.7 @99.1 NA...13.3 at 103 Juicin'
Nismo LT headers, Uprev tune, no cats, JBA catback with 22" Mag, Detroit Tru-Trac, 07 intake, AEM Brute Force, Trans-Go shift kit
Nismo SS gauges, Graphite OEM 20's w/ Yokohama Parada Spec-X in 275/55/20, rear drop shackles, modded headlights, tinted tails, Armaden LEDs, Hellwig traction springs, Bilsteain 5100's rear, Hellwig rear sway bar, Armada airdam, DDM 8000k HIDs in headlights and fogs---And DDM sucks
o-fivecc is offline
post #5 of 9 Old 02-24-2010, 03:25 AM
pogi69x
Shift_Enthusiast
pogi69x's Avatar
Quoted: 0 Post(s)
I had the same issue at 33,000 miles so after I repaired it and it was kind of a pain. As I was putting the column together I thought "how could I make this last longer" so I applied glue from a glue gun at the corner, now I don't know if that is a fix but seems to be holding up for now.
2007 White K/C XE
2* Advance, K&N CAI, 18" Magnaflow, Pioneer AVIC D-3 NAV, Hifonics TXI 6008, 2 Audiobahn 10's, 13.5" Flip down screen, game port for son PS2, wireless head phones
WISH LIST
NISMO Headers, Nismo Exhaust, Volant CAI, PGM
I LOVE THIS TRUCK!!!!!!
pogi69x is offline
post #6 of 9 Old 02-24-2010, 08:07 AM Thread Starter
JCopeland
Shift_lurker
Quoted: 2 Post(s)
Did your problem turn out to be the black wire others have had the problem with? Depending on the weather this weekend I going to pull it apart and hope that is the problem. Thanks for the glue suggestion.
post #7 of 9 Old 02-24-2010, 09:28 PM
kha4079
CTs Little Chihuahua
Shift_Obsessed
kha4079's Avatar
Quoted: 2 Post(s)
i also have the same problem i have an 07 and it wont shift up only down
bored at home
kha4079 is offline
post #8 of 9 Old 02-24-2010, 11:14 PM
krh2
Shift_Enthusiast
krh2's Avatar
Quoted: 0 Post(s)
Quote:
I posted the fix, now get er done..
krh2 is offline
post #9 of 9 Old 10-15-2014, 12:16 PM
supahamster
Shift_lurker
Quoted: 0 Post(s)
Cool
I decided to create an account to let others know how to fix this issue (not being able to actually shift down or up).
I solved this issue after hours and hours of diagnostics. I ended up just bridging (bypassing) the harness and just splicing the red wire. The red wire is responsible for the up shifts. The black wire is responsible for the actual activation of the manual shift mode. I spent countless hours trying to fix the harness, but nothing worked. I'm assuming the wire actually stretched or broke inside, even without any visible damage to the outside of the wire.
supahamster is offline
User Tag List
Linear Mode Linear Mode
Request for help (Manual Mode Button) 15007875 General Discussion 6 07-24-2009 02:27 PM
body lift on a column shift? asepkid Suspension 11 12-30-2008 06:33 PM
Manual shift button not working wiscdave General Discussion 5 03-03-2008 10:23 AM
Column Shifter- Manual Shift Problem blackandtitan Technical Discussion 2 01-20-2008 02:47 PM
Best PDA mount option for Column Shift Methuselah Interior Mods 1 01-02-2006 06:09 PM
