Water Leak - Nissan Titan Forum
post #1 of 8 Old 04-20-2010, 08:06 PM Thread Starter
A-37
Shift_Newbie
Quoted: 0 Post(s)
Water Leak
2005 Titan, 25K miles: Front carpets get soaked from rain. I've read about some problems with the rear window leak causing wet carpets. Has anyone had wet carpets NOT caused by the rear window? If so, what was the fix?
Trying to locate a leak while looking under the instrument panel is impossible.
A-37 is offline
post #2 of 8 Old 04-20-2010, 08:20 PM
sirdukedh
Shift_Hardcore
sirdukedh's Avatar
Quoted: 0 Post(s)
Are you sure its rain water? if so, it could be bad or mis-alinged weather strips.
04 XE. Motto Metal 909's 18's,Airaid MXP CAI , JBA headers, Custom CAJUN B-pipes, Borla XR-1, Leaf spring helper mod, green LED lights in grill, fog lights, engine bay, Halos, etc...Ferreus Custom Skull grill, 35% Tint, Trifecta tonneau cover, Eye Lid mod, Airaid TSB, Screen delete mod, Axle Vent mod, UPREV Tune
sirdukedh is offline
post #3 of 8 Old 04-21-2010, 11:01 AM
mcginkleschmidt
Shift_Enthusiast
mcginkleschmidt's Avatar
Quoted: 0 Post(s)
A known issue that you will want to rule out is the AC condensate leak for which a TSB was issued and is shown below:
DISCLAIMER: If you find a posting or message from me offensive, inappropriate, or disruptive, please ignore it. If you don't know how to ignore a posting, complain to me and I will be only too happy to demonstrate...
mcginkleschmidt is offline
post #4 of 8 Old 04-21-2010, 04:22 PM
Toomnymods
SHIFT_Track_ADDICT
Shift_Obsessed
Quoted: 3 Post(s)
i had the same problem and it ended up being the a/c condensation line
all i did to fix the problem was tear off the black boot, and replace it with my own 12" clear plastic hose with a clamp, now the water drips onto the ground instead of back in thru the firewall and onto passenger floorboard..
Toomnymods is offline
post #5 of 8 Old 04-21-2010, 09:11 PM Thread Starter
A-37
Shift_Newbie
Quoted: 0 Post(s)
Thanks for the info. I'll check with the dealer tomorrow to see about this.
A-37 is offline
post #6 of 8 Old 04-26-2010, 01:00 PM Thread Starter
A-37
Shift_Newbie
Quoted: 0 Post(s)
The insulation pad that runs up the incline of the footwells got soaked again and I can't figure out how to remove the pad with taking apart half the stuff that's under the dash. I considered cutting the pad for ease of removal but that's a last resort.
As for the A/C drain hose possibility, I haven't even driven the truck for a few days and it rained.
Suggestions?
A-37 is offline
post #7 of 8 Old 04-29-2010, 03:59 PM Thread Starter
A-37
Shift_Newbie
Quoted: 0 Post(s)
Continuing Saga........
I ran a hose along the lower windshield seal and water came in at a gap in the sheet metal seam just left of the dead pedal. The passenger's side has the seam but it's filled with sealant. I squeezed some silicone into the gap.
Just in case there's also a leak caused by the A/C drain hose, I looked for the hose from under the truck and from under the instrument panel. I even ran the engine with the A/C on. No draining. So..........where's the hose??
BTW, there's a TSB on lengthening the hose. I called the dealer. He's aware of the TSB but it isn't a free job. I thought TSBs were free. Guess not.
A-37 is offline
post #8 of 8 Old 04-29-2010, 04:05 PM
baseballfanz
SHIFT_Mr. Quick Answers
Shift_Obsessed
baseballfanz's Avatar
Quoted: 0 Post(s)
The A/C condensor drain hose is behind the passenger side fender liner.
You have to take the fender liner off to see it.
TSB is only free if you're still under warranty.
It's not a recall.
There's another TSB for water leak if the carpet is wet on either side after rain or car wash.
Look like that's what your problem was.
NTB07-034
baseballfanz is offline
User Tag List
Linear Mode Linear Mode
Water leak in titan acflye General Discussion 3 08-19-2007 09:08 AM
Water Leak in Cabin :( HELP Gator_Titan Technical Discussion 2 07-30-2007 04:58 PM
Big water leak... Gator_Titan General Discussion 6 07-30-2007 04:03 PM
Water leak not fixed jsethmor General Discussion 7 12-08-2006 11:21 AM
WATER LEAK ??? bubby2403 Technical Discussion 6 04-05-2006 09:20 PM
