Trans. Temp. Sensor location - Nissan Titan Forum
post #1 of 5 Old 11-05-2010, 05:57 PM Thread Starter
elbarto
Shift_lurker
Quoted: 0 Post(s)
hello guys/girls
I recently purchased a Bully Dog Triple GT and I have been unable for it to show a Trans. temp. read out. I have notice that a number comes up in and out for a split second. I seen the temp as high as 282 which it can't be. I have seen also 142 which makes more sense. It only happens for a split second while shifting gears.
So my question is - where is the temp sensor at? I was thinking it might be loose or something. I have been looking around, but no luck.
Anynone has any ideas of how to fix the dog or where the sensor is?. Thanks.
Later.
btw, have not downloaded a tuner. Just plug it in and been using the readouts Do not know if it makes a difference.
elbarto is offline
post #2 of 5 Old 11-05-2010, 06:28 PM
gweasel77
Shift_Obsessed
gweasel77's Avatar
Quoted: 0 Post(s)
The BDGT can't read trans. temp on the Titan.
You'd have to install a short throw trans. temp gauge into the test port on the passenger side of the trans.
Engine operating temp is usually 170-195F
2005 NISSAN TITAN SE KC FFV
IRC VK56 MEMBER
performance:
Custom 4" RamAir / Custom Fujita CAI / '08 IM / AirRaid TBS / Nismo LT Header's / UpRev Osiris Custom Tuned / Trans. Cooler / Catch Can / TruTrac / Banks Monster Exhaust / MT ET Street P295/45R/17 DR's
exterior:
Ruff Racing R286 22"x 9.5" Chrome's w/ 305/45/22 Yokohama Parada Spec-X's / Slotted Frozen Rotor's / Hawk LTS Brake Pad's / Stillen Diff Cover / ST 2" Drop Shackles / PRG Camber bolt's / Helwig RSB / Bilstein HD Shock's / DDM 8K HID's / Tow Hook's / Armada Air Dam / SolarGard Tint / Debadged
~ best 1/4 time - 13.91 @ 96.82MPH
60' - 1.90
1/8 - 8.85 @ 77.17MPH
gweasel77 is offline
post #3 of 5 Old 11-05-2010, 06:50 PM Thread Starter
elbarto
Shift_lurker
Quoted: 0 Post(s)
Thanks for the quick response. Based on the product information sheet, it does read trans. temp. Also, a couple of TT members say that it does.
At least for me, it has not done it consistently. Only does it every once in a while, during the up-shift.
Maybe a misprint on the product info sheet, but just want to make sure I am not missing something.
Thanks.
ps. http://www.bullydog.com/documents/40...heet%205.0.pdf
ps2. 06 CC 4x4 non-big tow if it helps.
elbarto is offline
post #4 of 5 Old 11-05-2010, 08:30 PM
scr38
Administrator
Shift_Obsessed
scr38's Avatar
Quoted: 25 Post(s)
The transmission temp sensor is inside the transmission. Actually, there are two of them. They send their signals over the CAN (the network between the different computers in the Titan).
scr38 is offline
post #5 of 5 Old 11-10-2010, 08:52 PM Thread Starter
elbarto
Shift_lurker
Quoted: 0 Post(s)
well, that might explain why I could not find it that easily. I still dont know why only the temp shows up for a split sec. in the bully dog while it is going thru a gear - ie. up shifting.
Thanks.
elbarto is offline
User Tag List
Linear Mode Linear Mode
Finally installed Trans Temp SCedTITAN Performance Mods 22 06-26-2009 05:51 PM
Do 2X4 SE Titans have a factory trans temp sensor? MIAPLAYA Technical Discussion 5 08-19-2007 07:43 PM
trans temp?????? Greg General Discussion 2 04-10-2006 08:09 PM
WHEN TRANS TEMP GOES UP THERE IS A chris General Discussion 7 04-03-2006 02:54 PM
Trans temp with a heavy trailer bigpapa General Discussion 15 04-03-2006 06:53 AM
