manual shift mode wont turn on - Nissan Titan Forum
post #1 of 7 Old 04-14-2011, 12:18 PM Thread Starter
jonmeskeete
Shift_lurker
Quoted: 0 Post(s)
I have a 2006 titan 4x4 with the automatic transmission with the shifter is on the column. There is a button on the end of the shift to turn on the manual mode and a toggle switch to shift up and down through the gears but when i press the button nothing happens and I can not shift up or down. Is there a light that is supposed to come on when you turn on the manual mode? any ideas what might be wrong? I looked to see if there was a blown fuse but I do not know which fuse it would be. Any help would be greatly appreciated.
jonmeskeete is offline
post #2 of 7 Old 04-14-2011, 03:03 PM
340titan
Shift_Enthusiast
Quoted: 0 Post(s)
I thought that was for when you was hauling trailer.
340titan is offline
post #3 of 7 Old 04-14-2011, 04:13 PM Thread Starter
jonmeskeete
Shift_lurker
Quoted: 0 Post(s)
Quote:
This is used anytime you need to shift to a lower gear. there is a separate button to go into tow mode. there is no way to shift into a lower gear other than to use this manual mode switch
post #4 of 7 Old 04-14-2011, 09:24 PM Thread Starter
jonmeskeete
Shift_lurker
Quoted: 0 Post(s)
found a possible answer
I did some more searching and I think I found the answer. I guess I was not wording it correctly the first time I searched for it. The answer was right here on the forum
here is the link http://www.clubtitan.org/forums/show...t=shift+button
I am going to try this tomorrow and I will post my results
post #5 of 7 Old 04-15-2011, 10:30 PM Thread Starter
jonmeskeete
Shift_lurker
Quoted: 0 Post(s)
Talking It Worked
I took the cover of the steering column this morning and sure enough there was a black wire that had broken off the connector I repaired it using a small piece of wire for a household thermostat a small snap connector that I purchased at Radio shack and a wire tie. Now it works again. I will post pictures of the repair over the weakened.
post #6 of 7 Old 04-17-2011, 09:18 AM Thread Starter
jonmeskeete
Shift_lurker
Quoted: 0 Post(s)
Pictures of repair
here are the pictures I said I would post.
ID:	48514   Click image for larger version
ID:	48515   Click image for larger version
post #7 of 7 Old 04-18-2011, 10:58 AM
04titanss
Moderator
Shift_Obsessed
04titanss's Avatar
Quoted: 2 Post(s)
Nice clean repair, Good job.
04titanss is offline
User Tag List
Linear Mode Linear Mode
Help!! Titan Wont Shift From Park Gear! KiNg28 Technical Discussion 13 03-14-2013 12:22 AM
Radio wont turn on spclolmpcsarea12 General Discussion 5 11-23-2008 05:31 PM
Truck wont turn on when its cold, when zytan General Discussion 11 05-11-2007 07:33 AM
Manual shift mode Ravelo Performance Mods 12 12-17-2006 08:33 PM
stereo wont turn on BizNutz General Discussion 9 11-08-2006 02:10 PM
