VDC Off, SLIP, & BRAKE lights on..... - Nissan Titan Forum
post #1 of 14 Old 05-10-2011, 08:40 PM Thread Starter
schristy1
Shift_Newbie
schristy1's Avatar
Quoted: 0 Post(s)
Send a message via Yahoo to schristy1
2004 Titan - VDC off, Slip, and Break light all come on at various times while the engine is running. Sometime while parked right after starting, sometimes while driving straight down the road at highway speeds. Lights never come on while VDC is manually turned off, which leads me to believe it's in the VDC system. No issues with ABS or ECM, so I'm guessing the wheel sensors are OK. That leaves the G sensor and the steering position sensor, correct? I've been searching the boards for days, I've heard everything from low brake fluid to old brake pads to mismatched tires. I have Toyos on the front, Wranglers on the back (all the same size). Brake fluid id fine, and brakes were replaced trying to figure out what this issue is. Any clues? I've been searching for two weeks!
schristy1 is offline
post #2 of 14 Old 05-10-2011, 09:56 PM
richworxs
Shift_Newbie
Quoted: 0 Post(s)
i had this happen to me once in a while and stopping starting the truck would clear it. i had the ECM relay recall done and haven't had it happen since. May not be related but since there is a recall and its free, wouldnt hurt to rule it out.
richworxs is offline
post #3 of 14 Old 05-10-2011, 10:33 PM
scr38
Administrator
Shift_Obsessed
scr38's Avatar
Quoted: 24 Post(s)
Probably a bad wheel sensor.
scr38 is offline
post #4 of 14 Old 05-11-2011, 12:44 AM
nandonismo
Shift_lurker
Quoted: 0 Post(s)
Brake lamp fuse?? Was workin on a g35 nd all those lights were on checked around on the forums nd found out that could be the problemo. Sure as **** the brake lamp fuse was out.
NISMONANDO
k&n intake super 44 flowmaster cortex SC
nandonismo is offline
post #5 of 14 Old 05-11-2011, 08:52 AM
BiXLL
Shift_Obsessed
BiXLL's Avatar
Quoted: 0 Post(s)
Send a message via AIM to BiXLL
Quote:
I agree.....
Born-4/27/04
Adopted-7/25/04
Smoke SE CC 4X4
Popular Captain, Big Tow, Utili-trak, Bed Extender,Fog Lights, OEM Seat Covers, Truxedo Lo Pro, Xm SkiFi 2, Bushwacker FenderFlares, APS Billet Grill, Weathertech Vent Visors, Lund Bug Shield, Stainless Door Pillars, Stainless Window Sills, Chrome Tailgate trim, Challanger Tube Steps, X-Pel Paint Protection, Front Tint, PIAA Silicone Wipers, Gibson 3" Stainless Single, Volant CAI, Airaid TB Spacer, ECO Fuel System, 2% Timing Advance, Active Tuning Ground Kit, DR Coilovers , Total Chaos arms, Bilstien 5100s, Deaver 2 1/2" Rear Spring Pack, Pro Comp Extreme 1079s. BFG AT 315x70x17, LM Bull Bar, PIAA Driving Lights, Wireless Keypad, Remote Start, under seat gun safe
BiXLL is offline
post #6 of 14 Old 05-12-2011, 11:24 PM
rpeles
Shift_Fanatic
Quoted: 10 Post(s)
In addition to all of the above, try resetting the ECU.
rpeles is offline
post #7 of 14 Old 05-15-2011, 10:03 PM Thread Starter
schristy1
Shift_Newbie
schristy1's Avatar
Quoted: 0 Post(s)
Well, I ended up replacing the left front hub. It came with a new sensor. I had noticed a slight dead spot when spinning the hub by hand, I figured I'd try it.
Took the truck out for a 250 mile trip. The lights didn't come on until 100 miles in. I killed the engine and reset them. They came on one more time during the trip. Considering they were coming on every 10 seconds, it it's improved. Do you think there could be more then one bad wheel sensor?
post #8 of 14 Old 05-16-2011, 08:34 AM
BiXLL
Shift_Obsessed
BiXLL's Avatar
Quoted: 0 Post(s)
are you lifted? Is it possible that one of the sensor wires is damged only making partial connection?
Born-4/27/04
Adopted-7/25/04
Smoke SE CC 4X4
BiXLL is offline
post #9 of 14 Old 05-16-2011, 08:50 AM Thread Starter
schristy1
Shift_Newbie
schristy1's Avatar
Quoted: 0 Post(s)
Totally stock, just getting old. 125k on the truck.
post #10 of 14 Old 10-29-2011, 02:15 PM
deerbound40
Shift_lurker
Quoted: 0 Post(s)
This is a place also to look depending on how long you have run your brakes as they ware down your master cylinder or brake fluid res has a senser when fluids run low your slip/trac controll light may turn on.
deerbound40 is offline
User Tag List
Linear Mode Linear Mode
Need Help: VDC Off and Slip lights both on thorracing01 Technical Discussion 14 05-10-2012 12:49 PM
slip, brake, vdc lights are constantly on on dash izeek98 Technical Discussion 8 11-18-2009 09:17 PM
ABS, Slip, VDC Lights on! BiXLL Technical Discussion 2 09-27-2008 09:56 PM
Warning lights: VDC off, SLIP, Brake??? Rbsimmons64 Scheduled or Preventive Maintenance 24 09-22-2008 11:18 PM
Brake, VDC & SLIP lights !!!!! aldaman Technical Discussion 3 02-25-2008 04:31 AM
