Removing driver side panel and window motor - Nissan Titan Forum
post #1 of 11 Old 08-08-2011, 03:42 AM Thread Starter
Topper_Harlee
Shift_lurker
Quoted: 0 Post(s)
Okay, hopefully I fixed my intermittent window problem following one of the thread here (thanks Factor430!) I took some pics while I did it. Hoping I can be of some help to anyone else that want to try it.
1) roll up window, and tape it so it stays up. I use big clear tape at 3 places over the door frame.
2) pry out the power window switch, start at the back.
3) Disconnect the two plugs.
4) Remove the cover on the pull handle. I started from the botton. There are two screws under there, remove them with 10 mm socket.
5) Pry out the little cover by the door handle, remove the screw.
6) Remove the trapezoid shape cover, remove another screw.
7) Pry out the seat memory switch, start from the back. Disconnect the plug.
8) Pry out the step lamp at the bottom. Disconnect the plug.
ID:	48934   Click image for larger version
ID:	48935   Click image for larger version
ID:	48936   Click image for larger version
ID:	48937   Click image for larger version
Topper_Harlee is offline
post #2 of 11 Old 08-08-2011, 03:46 AM Thread Starter
Topper_Harlee
Shift_lurker
Quoted: 0 Post(s)
Dang it, the pics didn't show up. Any idea? It's 3 am, I'm going to bed. Will try to fix tomorrow.
post #3 of 11 Old 08-08-2011, 01:57 PM Thread Starter
Topper_Harlee
Shift_lurker
Quoted: 0 Post(s)
Okay, figured how to attach pics, but there seems to be 6 files limit :-( How do I work around this? I have 12 more pics to add.
post #4 of 11 Old 08-08-2011, 05:30 PM
scr38
Administrator
Shift_Obsessed
scr38's Avatar
Quoted: 25 Post(s)
Garage
Just make another post(s) with the added pictures.
scr38 is online now
post #5 of 11 Old 08-09-2011, 12:40 AM Thread Starter
Topper_Harlee
Shift_lurker
Quoted: 0 Post(s)
9) Pry up the armrest top cover. I started from the back. I didn't totally remove it, just enough so I can get to that single screw.
10) Use a long screw driver or 1/4" socket extension, remove the single screw.
11) Now you're ready to pull out the panel. I start at the corner and work all the way arond using plastic trim remover I got from Harbor Freight.
12) Caution, don't drop the panel. You'll have to disconnect the lock cable and the handle cable from the door. Just use your hand. It now should look like this.
13) Notice that some of the orange clips got stuck in the door. You must remove them and attach them to the panel before you reinstall the panel. I use the trim remover to get them out.
14) Next, pull the clear plastic off the frame. No need to pull it all the way off, but you want to go up to where the speaker is. This will make it easier to remove the motor and its assembly. I use a sharp utility knife to cut through the adhesive as I pulled out the sheet. Faster and keep the plastic sheet in one piece. Once you're done, you can just press the adhesive back together.
15) Unplug the connector. You'll have to detach it from the metal panel, then remove those 3 bolts next to it.
ID:	48941   Click image for larger version
ID:	48942   Click image for larger version
ID:	48943   Click image for larger version
ID:	48944   Click image for larger version
post #6 of 11 Old 08-09-2011, 12:47 AM Thread Starter
Topper_Harlee
Shift_lurker
Quoted: 0 Post(s)
16) Notice the location of the assembly relative to cable and stuffs. This will make it easier when you reinstall it. Take few pics or make a sketch.
17) Remove the bottom bolt holding the assembly.
18) Remove the two bolts at the top that hold the assembly to the glass window.
19) Now you can slide out the assembly. Don't disconnect any cables.
20) Remove the 3 silver color bolts.
21) Carefully pry out the motor from the spool. Do not let the cable spool come out. I used a giant plastic clip to keep the spool in while I was working with the motor. You can use big tape or something.
22) Now follow the direction on this thread on what to do with the motor, or go buy a new one :-) Thank Factor430 for those pics on what to do with the motor.
http://www.clubtitan.org/forums/showthread.php?t=58751
23) Oh, I also replace the clear white plastic plugs where the screws go in since they were worn out. I use the one designed for GM, they worked. I also replaced some of the orange clips. I got both from Autozone.
Feel free to make suggestion or ask for any additional info. Hope this helps.
ID:	48947   Click image for larger version
ID:	48948   Click image for larger version
ID:	48949   Click image for larger version
ID:	48950   Click image for larger version
post #7 of 11 Old 08-31-2011, 08:36 AM
ansuturteori
Shift_lurker
Quoted: 1 Post(s)
Teoriundervisning | Teori prøver
Turteori.dk - din genvej til kørekort til personbil, fornyelse af kørekort, Gratis teoriprøve, kørekort teori, teoritest, generhvervelse af kørekort, kørekort til motorcykel, truckcertifikat, kørekort til lastbil, kørekort til bus, kørekort til vogntog
ansuturteori is offline
post #8 of 11 Old 07-16-2012, 09:05 PM
Thade
Shift_lurker
Quoted: 0 Post(s)
I had to do this recently & these videos were very useful...
Thade is offline
post #9 of 11 Old 07-16-2012, 10:11 PM
Kronos1965
Shift_Obsessed
Kronos1965's Avatar
Quoted: 6 Post(s)
Thumbs up Great description!
What great timing!
I have to replace my window motor on my drivers' side!
Great write up.
Raleigh, NC
If there are no dogs in Heaven, then when I die I want to go where they went. -- Will Rogers
Kronos1965 is offline
post #10 of 11 Old 10-04-2014, 01:06 PM
Montag
Shift_lurker
Quoted: 1 Post(s)
Thanks Topper and Thade for the pictures and videos. This will help me save a lot of time and money on my 2007 Titan. I have to fix both windows. Just hoping the problem is only motor related and due to the regulators. I only have the motors.
Thanks!
Montag is offline
User Tag List
Linear Mode Linear Mode
Driver Side Window Switch Panel Street5927 Technical Discussion 2 11-01-2008 12:39 PM
Power window issue - driver side bulldog General Discussion 5 09-20-2008 01:52 PM
Driver side window Fixed..... Converted General Discussion 1 07-01-2008 07:19 PM
Driver side window wont roll down... Converted General Discussion 10 06-27-2008 06:04 PM
Driver Side Window Stuck!!! eagleterp18 General Discussion 5 07-29-2005 12:33 PM
