Another Trailer Light Problem - Nissan Titan Forum: Club Titan Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Nissan Titan Forum: Club Titan Forums > Nissan Titan Forums > Towing and Hauling
  #1
Old 10-29-2012, 10:15 PM
Forestteck Forestteck is offline
Shift_Newbie
I found out recently that my left side trailer lights are out (right side ok) and I have no running lights at all.(both sides). I tested connector on the hitch so I know its the truck and not the trailer. Any ideas? Thanks
__________________
2004 Nissan Titan 4x4 LE Crew Cab with Big Tow.
  #2
Old 10-30-2012, 04:27 PM
Shift_Newbie
Update: I found two blown 10 amp fuses. One under the dash and one under the hood in the square looking fuse box. The one under the hood is marked "Trailer Tow". When I changed the fuses, I got all of my turn signals back but blew the 10 amp fuse under the hood again. I am thinking now that my "Trailer Tow #2" relay has gone out and blows this fuse. I have no running lights and no power to the trailer brakes. What do you think? Does this sound right?
__________________
  #3
Old 11-01-2012, 10:09 PM
Wyatt's Avatar
Wyatt Wyatt is offline
Shift_Newbie
Yeah....I'd find a U Haul Trailer/Hitch Installation Center. They find that GREMLIN!!
  #4
Old 11-30-2012, 02:44 PM
challenger3x2's Avatar
challenger3x2 challenger3x2 is offline
Shift_Enthusiast
If the trailer your towing is older or has any kind of rusting issues your most likely loosing a good ground while traveling. When trailer lights are working are any of the bulbs flickering or weaker. If you work on trailer your self you could try running a common ground wire to each light and then back to trailer connector.
Trailer brake ground wires should also be checked and changed to the common ground wire from lights.
Rusting trailer frames and poor contact between body mounts between trailer body and frame will cause this condition.
At least thats what I have found.
__________________
06 Titan LE,4x4,Steel Leather,Red Alert,Big Tow,Factory Step Rails,Brush Gaurd,Floor Mat,Bed Extender.. Add On's- In Channel Window Vent,Rear Spoiler mounted on RollBak Retractable bed cover... 2 Deg Timing Mod.. AirRaid TBS... NISMO Cold Air Intake.. BullyDog GT III and FlowMaster cat back dual exhaust.. Drilled/slotted rotors and Evolution pads front and rear.. JBA headers, rear sway bar.
trailer light problem sledgie Technical Discussion 20 10-23-2008 11:52 PM
trailer light problems rtitan05 Technical Discussion 9 06-06-2007 07:59 PM
Trailer Lights Problem. Rossi Technical Discussion 2 05-17-2007 09:13 AM
OEM Trailer Hitch and aftermarket exhausts... problem? GalaxyTitan22 Performance Mods 5 03-23-2006 10:28 AM
Trailer Brake Problem? Nique General Discussion 11 10-03-2005 08:55 PM
Powered by vBulletin®
