Tow Mode Not Working? - Nissan Titan Forum: Club Titan Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Nissan Titan Forum: Club Titan Forums > Nissan Titan Forums > Towing and Hauling
  #1
Old 11-06-2012, 09:43 PM
bipedrope bipedrope is offline
Shift_lurker
Unhappy Tow Mode Not Working?
Hey guys I finaily got a Titan I just have a few questions about the towmode and brake controller. First question is The Titan I bought did not come with the tow package as it was used and was the best condition at the time but I need a brake controller for the trailer I use time to time does this truck come with brake controller harness like others or do I need to run the entire thing? Second I've noticed alot of people here are towing in manual mode or 4th gear when I use the towmode I notice nothing changes my gears do not hold any longer and my trucks always trying to shift into OD I've driven on flat ground up hills loaded unloaded I even took the truck to the dealer they said all is well. When I owned my Chevy it held the gears loaded or not and did not shift to OD until it reached 60MPH so am I crazy or is this just how this truck is. ANY REPLY WOULD HELP GREATLY AS I'M HEADING BACK TO THE DEALER TO HAVE THEM SHOW ME THE DIFFERENCE
THANKS GUYS
  #2
Old 11-07-2012, 01:22 AM
Scottysize's Avatar
Scottysize Scottysize is offline
Shift_Enthusiast
What's the year model? Mine didn't come with the Tow Package either, but it was just a matter or ordering a cable with my brake controller. The cable plugs in behind the panel under the steering wheel. It even says "Trailer Brake Harness" on the cable.
Here is a link to the cable:
Amazon Amazon
(Note: Amazon says it doesn't fit 2012's, but it does.)
Here's the Brake Controller:
Amazon Amazon
As for Tow Mode, mine stays in a lower gear a little longer when it is turned on.
__________________
2012 SV CC Brilliant Silver/Charcoal Cloth 4X4.
Current Mods: DIY: Window Screen Mod | RetraxPRO Toneau Cover | LINE-X | Hypertech Energy Max | Airaid MXP w/PreFilter | Rigid Industries SR-Q2 Driving Lights | AMP Research Power Steps. (Install Tips)
Future Mods: One day AirLift Air Bags
  #3
Old 11-07-2012, 01:29 PM
Shift_lurker
Mine is a 2008 4x4 se thanks for the link
  #4
Old 11-07-2012, 01:36 PM
Shift_lurker
I'll look again but if that's all it really does it seems like a waste
Holding in a lower gear is good but to keep trying up shift to OD
ever time is gets a chance is really annoying.
  #5
Old 11-07-2012, 09:33 PM
Shift_lurker
Again thanks for the link ordered cable and controller today
  #6
Old 11-08-2012, 04:26 AM
Scottysize's Avatar
Shift_Enthusiast
Let me know if you have any problems. I can always take a picture if you need. I mounted mine under the dash below the steering wheel. It's out of the way, but you can always look down and see it if you need too.
__________________
  #7
Old 11-08-2012, 11:29 PM
HRTKD's Avatar
HRTKD HRTKD is offline
Shift_Obsessed
My understanding of Tow Mode is that it only holds the RPM's on the lower gears. It does not prevent you from going into overdrive. The general recommendation when towing is to manually keep the transmission in D (4th) not OD (5th).
If you don't have the tow package then you may also need a set of three relays to make the 7 pin outlet on the back fully active.
__________________
Club Titan Rosetta Stone
Jim
  #8
Old 11-09-2012, 03:32 AM
Scottysize's Avatar
Shift_Enthusiast
Oh ya. I forgot about those. Uhaul put mine in, but here's a link to everything you need for a 2008.
http://www.etrailer.com/question-37368.html
__________________
  #9
Old 11-09-2012, 08:55 AM
HRTKD's Avatar
Shift_Obsessed
Yes, if the dealer put in the OEM hitch then it came with the relays.
__________________
Jim
  #10
Old 11-10-2012, 09:55 PM
Forestteck Forestteck is offline
Shift_Newbie
I know what your talking about. I had a GMC that you could definitly tell when the tow/haul mode was on. On my Titan I can tell no difference when tow mode is on. I tow in 4th gear with tow mode on and get great performace towing 7,000 lbs.
__________________
2004 Nissan Titan 4x4 LE Crew Cab with Big Tow.
Using the Tow Mode? Mychael101 Performance Mods 5 05-03-2007 01:17 PM
when to use tow mode tashadog General Discussion 6 08-12-2006 07:18 PM
tow mode in D but not in 4,3,2,1 OldSpeed General Discussion 8 03-02-2006 09:14 PM
tow mode chefbob General Discussion 5 07-11-2005 11:42 PM
Tow Mode TheGoose Technical Discussion 6 03-22-2005 06:29 PM
Powered by vBulletin®
