trailer dual filaments reversed symptom - Nissan Titan Forum: Club Titan Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Nissan Titan Forum: Club Titan Forums > Nissan Titan Forums > Towing and Hauling
  #1
Old 11-08-2012, 01:42 AM
Filbert Filbert is offline
Shift_Enthusiast
'06 CC: truck's lights all okay.
trailer lights seem to have filament reversed, as in
running light is bright and brake/turn is dim.
both sides.
symptoms are the same on trailer and new magnetic spare set.
the 2 fuses under the hood are good.
do not see any fuses under the dash.
how to check the relays?
  #2
Old 11-10-2012, 10:12 PM
Forestteck Forestteck is offline
Shift_Newbie
Maybe a ground wire problem on the trailer. Also check to see that you have a good clean hith ball/trailer hitch(ground travels through hitch). my 2 cents.
__________________
2004 Nissan Titan 4x4 LE Crew Cab with Big Tow.
  #3
Old 12-06-2012, 03:00 PM
Shift_Enthusiast
I find that the ground lead on the 7-lead socket has no continuity with the frame or tow hitch. I assume there should be.
Is there a fuse for the ground lead?
Any reason not to simply directly ground that lead locally, perhaps with a fusible link, rather than hunting for the break?
  #4
Old 12-07-2012, 11:59 AM
challenger3x2's Avatar
challenger3x2 challenger3x2 is offline
Shift_Enthusiast
Maybe wires on truck end of 7 pin connector have worked loose. Also there are at least 3 fuses plus a couple of relays under hood that are tow package related.
What type of trailer?
Do trailer lights work properly with other tow vehicles?
__________________
06 Titan LE,4x4,Steel Leather,Red Alert,Big Tow,Factory Step Rails,Brush Gaurd,Floor Mat,Bed Extender.. Add On's- In Channel Window Vent,Rear Spoiler mounted on RollBak Retractable bed cover... 2 Deg Timing Mod.. AirRaid TBS... NISMO Cold Air Intake.. BullyDog GT III and FlowMaster cat back dual exhaust.. Drilled/slotted rotors and Evolution pads front and rear.. JBA headers, rear sway bar.
  #5
Old 12-20-2012, 05:52 PM
Shift_Enthusiast
Apparently a false alarm.
The system works perfectly on third and fourth trailer tried.
Thanks for the suggestions.
Dual Yes Dual Ported Enclosure !!!!!!!!! tech12volt Audio / Video and interior electronics 33 10-12-2008 12:13 AM
Reversed Valves, TB Bypass Mod TitanBlue Performance Mods 2 10-14-2007 11:18 PM
Weird symptom after my oil change Kubed Technical Discussion 3 07-07-2006 09:11 AM
My New Trailer Rossi General Discussion 29 04-16-2006 12:39 PM
Installed FM Super 40 Dual In / Dual Out ....... Red-Thunder Performance Mods 17 09-09-2005 08:36 PM
Powered by vBulletin®
