Tow mode questions... - Nissan Titan Forum
post #1 of 6 Old 11-19-2012, 02:41 PM Thread Starter
Mauro
Shift_lurker
Quoted: 0 Post(s)
I just bought a 04 Titan and I love this "beast" so I guess I'm a "newbie". I've seen a lot of posts that mention to use the Tow Mode on 4th gear. Now the questions that I have are;
Do you turn on the Tow Mode on and then just put in 4th or do you go shifting manually from 1st up to 4th?
The other question is there anything wrong if you just put in Drive with the Tow Mode?
I'm towing a small travel trailer no more than 3,200 lbs. fully loaded. The truck didn't have the owner's manual when i got it so that's why I'm here asking.
Mauro is offline
post #2 of 6 Old 11-19-2012, 05:10 PM
HRTKD
Shift_Obsessed
HRTKD's Avatar
Quoted: 3 Post(s)
Just turn on Tow Mode whenever you want. It only holds the RPM in the first three gears. With a trailer that light you could probably get away with leaving it in D but if you notice the transmission temperature creeping up then shift down. If you don't have a transmission temperature gauge (only on the Tow package equipped Titans) then play it safe and keep it in 4th.
Jim
HRTKD is offline
post #3 of 6 Old 11-19-2012, 08:59 PM Thread Starter
Mauro
Shift_lurker
Quoted: 0 Post(s)
Thanks, that's what I thought. I wasn't too worried about it since the trailer is not that heavy. I just wanted to be sure. But if I use 4th in the tow mode, do I switch to it from D or do I need to shift the gears as if it was a manual transmission?
Mauro is offline
post #4 of 6 Old 11-19-2012, 09:04 PM
HRTKD
Shift_Obsessed
HRTKD's Avatar
Quoted: 3 Post(s)
Set it in D or 4 and let the transmission do its thing. If you manually shift then Tow Mode is useless.
Jim
HRTKD is offline
post #5 of 6 Old 11-20-2012, 12:51 PM Thread Starter
Mauro
Shift_lurker
Quoted: 0 Post(s)
Thanks man, I was going to do that but I wanted to be sure that I wasn't making a mistake. I got to get an owner's manual for this thing. Have a great Thanksgiving!
Mauro is offline
post #6 of 6 Old 11-20-2012, 03:30 PM
HRTKD
Shift_Obsessed
HRTKD's Avatar
Quoted: 3 Post(s)
You can download the owner's and service manuals in PDF format from:
http://x.nissanhelp.com/forums/Knowl....html?catid=44 (owner's manuals)
http://x.nissanhelp.com/forums/Knowl....html?catid=38 (service/shop manuals)
Jim
HRTKD is offline
User Tag List
Linear Mode Linear Mode
Using the Tow Mode? Mychael101 Performance Mods 5 05-03-2007 02:17 PM
Questions about Tow Mode gsxrraycer General Discussion 9 09-14-2006 02:08 PM
when to use tow mode tashadog General Discussion 6 08-12-2006 08:18 PM
tow mode in D but not in 4,3,2,1 OldSpeed General Discussion 8 03-02-2006 10:14 PM
Tow Mode TheGoose Technical Discussion 6 03-22-2005 07:29 PM
