Rear Axle Ring and Pinion Failure! - Nissan Titan Forum: Club Titan Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 11-29-2012, 10:27 PM
Drummer0314's Avatar
Drummer0314 Drummer0314 is offline
Shift_Enthusiast
Ok so yesterday I left work and was on my way home, when I approached a gas station where a lady refused to turn into the entrance because of a car leave was slightly away from the curb (she had plenty of room btw). Needless to say she was waving me to go around in the middle of the dang road, so I did well when switching lanes a truck was approaching me, so I floored the truck well i heard an explosion and then no power to the wheels. I coast into the gas station and get under the truck to see the diff. cover bulging out. I get back to my office and remove the cover to see all the teeth on the pinion laying in the bottom and half of the ring gear teeth missing. At this point I don't have a ton of money to fix, any idea of the most cost affective way to approach this repair? Some pictures below show damage.
ID:	50433   Click image for larger version
ID:	50434   Click image for larger version
ID:	50435   Click image for larger version
__________________
2008 Nissan Titan CC XE Majestic Blue, Big Tow, Dynomax Bullets, Xtreme Rhino-Lined Badges, 6" Pro Comp Lift (Stage I), Alpine IVA-W505, MTX 604, MTX 801D, 20x8.5, +10 Offset XD775 Rockstars, 35x12.50x20 Toyo M/T's.
  #2
Old 11-30-2012, 04:56 AM
cjoh101's Avatar
cjoh101 cjoh101 is offline
Shift_Newbie
If you don't want replace it with a used rear end or buying from the dealership you could do the following.
Detroit Trutrac
https://www.4x4parts.com/nissan/tita...gs-p-5912.html
Rear diff cover
https://www.4x4parts.com/nissan/tita...er-p-5959.html
Ring and pinion
https://www.4x4parts.com/nissan/294-...on-p-6437.html
There is probably some other stuff I missed that you might need, but with this you would not have to worry about it happening again.
Sent from my iPhone using AutoGuide.com App
__________________
2005 Titan LE CC 4X4 Galaxy Black
OBX headers
Walker b-pipes
Magnaflow y-pipe 2.25 DI/2.5 SO
Magnaflow 14" muffler 2.5 SI/SO
2* timing advance
Stock air box mod
  #3
Old 11-30-2012, 10:54 PM
NBhunter80's Avatar
NBhunter80 NBhunter80 is offline
Shift_Enthusiast
Looks like your spider gears broke in half and got caught in the ring gear. Unfortunately you will need a new carrier, new ring gear, and new pinion gear, along with a new dif cover. In all honesty, your best bet would likely be to find a used axle for $1500 or so rather than trying to rebuild your current axle. Your pinion seal may or may not be intact, and if that is blown as well, then your repair would likely be more costly than a used axle. Sorry to be the bearer of bad news. Good luck with the fix!
__________________
2005 LE King Cab 4x4 Offroad Big Tow FFV, Purchased used on 2008/11/30.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, 33 x12.50r17LT Hercules Trail Digger tires on OEM OR 7-spoke 17" rims, 3" Rough country Lift, Bilstein 5100s front and rear, Hawk LTS brake pads, MOOG lower ball joints, 2011 Pro4x rear end, Axle vent mod, NGK iridium spark plugs, 2 degree timing advance, Stock airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
  #4
Old 12-01-2012, 09:17 AM
04titanss's Avatar
Moderator
Shift_Obsessed
What gear ratio do you have?
__________________
04 XE Mod List
  #5
Old 12-01-2012, 10:44 AM
04titanss's Avatar
Moderator
Shift_Obsessed
I have a 2.94 rearend that needs axle seals and bearings I can part with, think it is a 06, do not know the milage on it.
__________________
04 XE Mod List
  #6
Old 12-02-2012, 02:10 PM
Shift_Enthusiast
Damn I need a 3.356 rear end
__________________
  #7
Old 12-03-2012, 07:53 AM
04titanss's Avatar
Moderator
Shift_Obsessed
I know a guy with a set of 3.36 gears and open diff that was pulled out of a 06 axle, would have to reuse your bolts.
__________________
04 XE Mod List
  #8
Old 12-03-2012, 04:16 PM
sirdukedh's Avatar
sirdukedh sirdukedh is online now
Shift_Fanatic
I know of the dreaded rear axle seal issue but never a rear end exploding. anyone know how this happens?
__________________
04 XE. Motto Metal 909's 18's,Airaid MXP CAI , JBA headers, Custom CAJUN B-pipes, Ultra quiet reso to Banks Monster muffler, Leaf spring helper mod, green LED lights in grill, fog lights, engine bay, Halos, etc...Ferreus Custom Skull grill, 35% Tint, Trifecta tonneau cover, custom air ram mod, Eye Lid mod, Airaid TSB, Screen delete mod, Axle Vent mod, UPREV Tune
  #9
Old 12-03-2012, 11:03 PM
mcginkleschmidt's Avatar
mcginkleschmidt mcginkleschmidt is offline
Shift_Enthusiast
There might be some Titan parts here that may be of use to you. Check out this link: http://www.titantalk.com/forums/jts-...e-options.html
__________________
DISCLAIMER: If you find a posting or message from me offensive, inappropriate, or disruptive, please ignore it. If you don't know how to ignore a posting, complain to me and I will be only too happy to demonstrate...
  #10
Old 12-04-2012, 10:33 PM
Shift_Enthusiast
Man i took it apart today and the pinion and ring gear are fine. The two gear on the end if the axle shaft splines are fine. the other two spiders gears inside the LSD are shattered into a bunch of pieces. now the damage is strange to me. Most of the time the ring and pinion break am I right?
__________________
WTB: 3.36 Rear Ring and Pinion or Axle for 04 N20ntegra24 For Sale/For Trade 0 08-17-2011 10:28 PM
WTB Rear End and/or Ring and Pinion for '05 Jeff0825 For Sale/For Trade 7 02-11-2009 03:59 PM
Need BT Ring and pinion chrisfuji For Sale/For Trade 16 11-09-2007 10:23 PM
Rear Axle Seall Failure at 16K Miles Jaho1979 General Discussion 17 11-09-2007 02:12 AM
Powered by vBulletin®
