Flat tire light on - Nissan Titan Forum: Club Titan Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 12-05-2012, 07:15 PM
Rallen Rallen is offline
Shift_lurker
Flat tire light on
My 2006 Titan le flat tire light is on. All tires at 37lbs scanner says low battery on rr? Can the batteries be replaced? Can I buy one new valve stem? What would the normal price be for it. Appreciate any help!!!
  #2
Old 12-06-2012, 12:05 AM
HRTKD's Avatar
HRTKD HRTKD is offline
Shift_Obsessed
Yes, you can purchase just one new sensor. Try a local shop first. Have them try to reprogram the sensor BEFORE you mount it to the wheel. That works. I tested four of them sitting on the concrete beside my Titan and also for another Titan owner.
__________________
Club Titan Rosetta Stone
Jim
  #3
Old 12-06-2012, 12:41 PM
Sullman Sullman is offline
Shift_lurker
Tpms=$$$
I did a STUPID thing and put on fancy chrome valve stem caps. I learned that this was a bad thing as they were dissimiliar metals and got a corrosion effect and had to replace 2 of the TPMS sensors in the tire for a lovely $240!! They did put on some rather plane PLASTIC valve stem covers and said DON'T do that again! I do believe that the average tire shop can service these if you didn't do what I did for about $15 a wheel...
-Sullman
  #4
Old 12-06-2012, 07:37 PM
Shift_lurker
Thanks all for the info... I appreciate it.
flat tire patched, found out 2 studs stripped. BigIslandTitan General Discussion 2 04-29-2010 06:04 PM
tire pressure light? FSUMitch General Discussion 3 09-17-2006 07:45 PM
low press. tire light SpeedTech Technical Discussion 17 07-09-2006 02:31 PM
Got a flat tire!! Kingoftheroad General Discussion 8 12-11-2005 10:05 AM
How do you change flat tire after 6" lift? Net4n6 Suspension 11 09-29-2005 09:21 AM
Powered by vBulletin®
