Intermittent Starting Issues - Nissan Titan Forum: Club Titan Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Nissan Titan Forum: Club Titan Forums > Mods and Technical Discussions > Technical Discussion
  #1
Old 12-07-2012, 08:52 AM
jimv8eatr's Avatar
jimv8eatr jimv8eatr is offline
Shift_Newbie
Hey guys check this out...
My 04 Titan quad cab just started this intermittent problem. Yesterday morning, I turned the key and nothing. I turned the key again and it started right up. In the afternoon after work, the same thing. So I went home and started looking around for loose or corrosion on the battery posts. The Optima red top is perfectly clean. No corrosion, everything is tight. Meter is 12.2v off and 14.15v idleing. I turned the key to on and all the guages look normal, dash lights, interior lights, everything is fine. This time I turned the key maybe 4 times before it started. I was thinking a fuse somewhere but they are either blown or not, right? This morning, the first turn of the key and it fired right up. Any ideas?
__________________
2004 Crew Cab SE 4x4, Off-Road, Tow Package, S&B intake, throttle body bypass, Poweraid TBS, 170 degree thermostat, 2 degree timing advance, Flomaster, PRG Mini Lift, 315/70-17 BFG All Terrain's.
  #2
Old 12-07-2012, 12:04 PM
04titanss's Avatar
Moderator
Shift_Obsessed
Double check the cable terminals, my ground terminal that seamed tight was the cause of my No Start the other night.
Worst case is the solenoid on the starter is going out.
__________________
04 XE Mod List
  #3
Old 12-07-2012, 05:07 PM
HRTKD's Avatar
HRTKD HRTKD is offline
Shift_Obsessed
Check the ECU relay in the IPDM. Could be the IPDM itself too.
__________________
Club Titan Rosetta Stone
Jim
  #4
Old 12-08-2012, 01:35 PM
Forestteck Forestteck is offline
Shift_Newbie
I put up with this on my 04 for about a year. Then I had the starter replaced and problem solved.
__________________
2004 Nissan Titan 4x4 LE Crew Cab with Big Tow.
  #5
Old 12-08-2012, 02:36 PM
jimv8eatr's Avatar
Shift_Newbie
Quote:
I want to check the starter connections but I have no idea where the starter is? Don't tell me I'm gonna have to go to the Nissan stealership!
__________________
  #6
Old 12-08-2012, 02:39 PM
jimv8eatr's Avatar
Shift_Newbie
Quote:
Where is the ECU relay? Somewhere in the fuse panel behind the battery??
The update is that the truck has started every time since I asked the question! Figures...
__________________
  #7
Old 12-09-2012, 08:02 PM
Shift_Newbie
Yep, thats how it goes. My truck would start fine for a month and then go right back to not starting. The intake manifold has to come off to change starter. I saved myself at least $100.00 by taking truck to an independent shop I trust. Dealer was to expensive for my taste.
__________________
intermittent loping idle...??? MDADDYS Technical Discussion 7 06-07-2010 09:22 PM
Not starting!! Hippie General Discussion 4 04-09-2008 10:35 PM
Fuel Pump Intermittent problem blacksmith37 Technical Discussion 1 10-17-2006 08:34 PM
Starting to like CT again... goval General Discussion 15 02-18-2006 03:40 PM
Anyone with intermittent gauge problems? bigpapa Technical Discussion 6 09-14-2005 09:37 AM
Powered by vBulletin®
