Help with axle shaft removal - Nissan Titan Forum: Club Titan Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 12-09-2012, 05:27 PM
Drummer0314's Avatar
Drummer0314 Drummer0314 is offline
Shift_Enthusiast
I am trying to pull the axle shafts out of the diff. any ideas whats holding them to the LSD. I have everything off that can come off still nothing. Any ideas?
__________________
2008 Nissan Titan CC XE Majestic Blue, Big Tow, Dynomax Bullets, Xtreme Rhino-Lined Badges, 6" Pro Comp Lift (Stage I), Alpine IVA-W505, MTX 604, MTX 801D, 20x8.5, +10 Offset XD775 Rockstars, 35x12.50x20 Toyo M/T's.
  #2
Old 12-09-2012, 08:21 PM
04titanss's Avatar
Moderator
Shift_Obsessed
A long pry bar wedged bewteen the axle flange and backing plate is all I needed to pop the axle out of my housing. Nothing holds them in to the carrier, remove the 4 nuts off the axle retainer, behind the backing plate, and all should pop out.
__________________
04 XE Mod List
  #3
Old 12-09-2012, 09:18 PM
Shift_Enthusiast
so the plates on each side of the LSD and ring gear assembly and they should just slide out? What holds them in?
__________________
  #4
Old 12-09-2012, 09:19 PM
Shift_Enthusiast
never mind I see what your saying I have all that off so the spines are the only thing holding them in?
__________________
  #5
Old 12-09-2012, 10:32 PM
HRTKD's Avatar
HRTKD HRTKD is offline
Shift_Obsessed
I believe there is a square bracket with four bolts (that come through the brake backing plate towards the inside) that holds the shaft in.
__________________
Club Titan Rosetta Stone
Jim
  #6
Old 12-10-2012, 12:03 PM
04titanss's Avatar
Moderator
Shift_Obsessed
That only holds the backlash/preload adjuster. With every thing removed the axles should come out with a little force. With the spider gears coming apart in yours, some of the material may have wedged itself between the splines. May have to rent a slide hammer from the local auto parts store to get the axle out.
__________________
04 XE Mod List
  #7
Old 12-10-2012, 09:33 PM
Shift_Enthusiast
I work for a family business which is a shipyard and we have huge slide hammer to remove 3 inch diameter shaft out of yachts, and still it wont budge. I guess next its off to putting a portable hydraulic press on it.
__________________
  #8
Old 12-10-2012, 11:30 PM
04titanss's Avatar
Moderator
Shift_Obsessed
Post some pics before you put the hydro on it.
__________________
04 XE Mod List
Rear Axle shaft and seals. gebeaird General Discussion 2 10-14-2011 07:52 AM
Drive shaft removal HELP! AlwaysBeingDumb Technical Discussion 2 09-02-2011 11:06 PM
wtb a true trac a uprev and a body lift and a rear axle shaft williamseng1 For Sale/For Trade 1 06-03-2010 06:10 PM
Axle Shaft Wes13_07TITAN General Discussion 2 11-25-2009 04:50 PM
axle shaft replacement q TitanLE General Discussion 4 03-18-2008 11:27 PM
Powered by vBulletin®
