How hard to remove drivers floorboard Carpet? - Nissan Titan Forum: Club Titan Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 12-11-2012, 04:12 PM
BigA's Avatar
BigA BigA is offline
Shift_Hardcore
I noticed I have damp to wet carpet under my drivers side floor mat. When I get moved back to OH next weekend I want to pull the carpet to see if I can find the leak. How do I remove the carpet from the front floorboard? I would assume thiers a seam somewhere between the front and the back?
__________________
2005 Nissan Titan SE 4x2 Radiant Silver, Big Tow, Popular Package with Captains chairs, OEM Foglights, Bugsheild, Bedliner, XM/Sirius Radio
  #2
Old 12-11-2012, 07:00 PM
scr38's Avatar
scr38 scr38 is online now
Administrator
Shift_Obsessed
I think the carpet is one piece. You will have to remove the seats, seat belt anchors, center console (if you have one) and the thresholds and kick panels.
  #3
Old 12-12-2012, 08:21 AM
BigA's Avatar
Shift_Hardcore
Quote:
OK, yea I'm not going to do all that, I'll just have to pull back the drivers side as much as I can then get the garden hose out and check for leaks.
__________________
  #4
Old 12-13-2012, 12:55 AM
goodkill's Avatar
goodkill goodkill is offline
Shift_Newbie
its a AC hose,its a $10 Home Depot fix carpet should peel back pretty easy. i did my passenger side a few months ago.
__________________
http://www.dirtkingfabrication.com/
http://legitaccessories.com/
Recognizing that I volunteered as a Ranger, fully knowing the hazards of my chosen profession, I will always endeavor to uphold the prestige, honor, and high esprit de corps of the Rangers.
  #5
Old 12-29-2012, 01:57 AM
PAPARYNO's Avatar
PAPARYNO PAPARYNO is offline
Shift_Enthusiast
How do u fix it. Where is the write up?
Sent from my iPhone using AutoGuide.com App
__________________
06 TITAN LE CC 4X2 Loaded w/Nav & DVD,BT, ValentineRD, G-Tech, TrueTrac,
AEM BruteForce CAI, Stillen LongTubes and Fr&R Swaybars, Jwt Cams, Uprev,
Magnaflow 50 Duals, NX 75Shot w/RemoteOpener, PRG Trac Bars & Fr. Leveler
Stock> 0-60mph 7.81sec. 1/4mile 16.01sec.@87.0mph
Mods> 0-60mph 5.21sec. 1/4mile 13.67sec..@99.93mph
DT Dyno SAE #'s N/A Map 325.71 RWHP / 364.06 TQ
DT Dyno SAE #'s NX100 Map 458RWHP / 518RWTQ !!!
  #6
Old 12-29-2012, 05:01 PM
BigA's Avatar
Shift_Hardcore
Would the AC cause the drivers side to be wet? I thought the drain was on the passenger side? It being winter I have not run the AC lately, but the AC runs when the defrost is on correct? The AC has begun to have a mildew like smell when I first turn it on. I did pull the carpet back and couldn't find anything. I did find a seam gap on the underside on the transmission tunnel and I sealed that up.
__________________
  #7
Old 12-29-2012, 11:06 PM
sht06's Avatar
sht06 sht06 is offline
Shift_Enthusiast
Could be back window due to the stance of truck.That's 06 and newer with big back glass.Mine ran the gully from back to front floor board.The noise/heat insulation acts like a sponge. And yes A/C dose run when you select defrost.But I would start with seal around back glass.There was a T.B about squirting silicone in the large gap around back glass.Mine would leak after heavy rains.
Advise for racers/hard drivers KINGMADE General Discussion 18 10-27-2008 02:11 AM
wet floorboard timothyodell2525 Technical Discussion 1 04-06-2008 11:32 PM
Help, Wet Floorboard?!?!?! SniperT38 General Discussion 6 01-04-2007 08:30 PM
Wet Floorboard BigShowJoe General Discussion 5 10-14-2005 12:56 PM
front floorboard still wet galaxy Technical Discussion 10 08-26-2005 08:05 AM
Powered by vBulletin®
