I am thinking about buying A handheld programmer (not uprev) for my 08 pro 4x. I already know the best is uprev but i dont need or want it due to minimal mods. I want to know which is the best among the three: BDGT, Superchips, Hypertech. Supposedly, the hypertech is supposed to have the best tune available for the titans, producing the fastest 0-60 and 1/4 mile times. It also it supposed to give the best increase in MPG's. I like the BDGT because of the monitoring screen and 2* timing advance.(Not sure if the 2* timing advance is even a big deal or not). Hypertech does not offer this feature unfortunately. Overall, with my research I have it down to hypertech and BDGT. Hypertech sounds like it has the best tune and fastest times whereas the BDGT has alot of nice features that the hypertech does not. I want to know if anybody has heard the same things about hypertech or not and what would really be the best handheld programmer (best tune) for the titans. If hypertech really does have the best tune and fastest times, I think I could/would sacrifice the BDGT monitoring system for the better performance tune. Let me know what you guys think? Thanks!
I'd say BDGT. Eventhough you only have plans for minimal mods the Bullydog is the only handheld that can still be used if your gonna add B pipes and headers. And incase your not aware, cracked exhaust manifolds on Titans aren't rare. If/when that happens, your cheapest and best fix is a set of headers and a good set of B pipes and you would already then have the BDGT to get AFR's back in acceptable ranges to remove CEL/SES.
__________________ '07 CC 4X4 banks ram air w/ tb screen removed, banks monster exhaust, prg minilift, PRG UCA's, PRG endlinks, 5100's all around, DK shackles, EBC brakes, headlight mod w/ JB switcbacks, Legit 55w 6000 hid's (lows and highs), modded tail lights, street scene grille shell, xd diesel 20x10 w/ terra grapplers, pinch weld mod, axle vent mod, BW pocket flares, PD'd stuff, BL step rails, SM designs bezel kit
I had the Bully Dog GT, but switched back to the Hypertech because I got better gas mileage. My 2 cents. Take 'em for what they're worth. I'm pretty sure you'll find most love the BDGT.
__________________
2012 SV CC Brilliant Silver/Charcoal Cloth 4X4.
BDGT hands down not just for the performance but the features and gauges you get. You just dont program with the BDGT and throw it in the glove box. Guys say the hypertech will perform a little better but I havnt seen any track time proof of that besides the difference will not be felt. Here is a video you may have seen I have posted it several times on titan forums of the BDGT 93 tune vs. stock tune.
Ya I just picked up a used bdgt and love it. Dedinetly can tell a difference on my truck and I've just been using the 87 tune. Especially down low. Plus all the features are great. Definetly glad I went with it.
Sent from my SCH-I500 using AutoGuide.Com Free App
__________________ New ride: 2010 Crew Cab Pro-4x; Volant Powercore intake; Magnaflow muffler swap
Coming Soon PRg leveling kit Old Ride:2004 King Cab LE with Off-Road and Big Tow
PRG Leveling Kit, JBA Cat-Back Exhaust w/ SLP Loudmouth muffler,New Volant Powercore Intake,2 degree advance,Axle Vent Mod, Stillen Differential Cover w/M1 75w-140 Other rides: 2008 Armada SE; All stock and will probably stay that way since it is the wifes. We'll see. 2004 Dodge 1500; Wifes first truck so we kust kept it. All stock. 1972 Ford F100 Ranger XLT; 360 with cam, headers, edelbrock 600, Edelbrock Al. Intake, straight pipe dumped below cab. Its loud. (thinking about possioble VK56 swap in the future when done with school)
Yeah.... I've got an 04. Their wasn't much going on then,... so I went with Jet chip, maxed out for headers... ram air, ...etc I'm sure theirs much better programs..... but it seems to still haul a**
You CAN install this unit without the RAM Mount and use the supplied suction cup / windshield mount it comes with. Installation is the same but you do not need the 5' HDMI cord. But the COOL factor is with the Ram Mount. Also out of sight and out of mind. One thing less to worry about when you leave your truck from prying eyes. Also, since the BDGT unit is so small to read, this is a perfect way to watch your engines VITALS at Eye Level keeping it safer to read it.
Follow the Bullydog Instructions it comes with, UPDATE if needed and you'll be good to go on to the next steps:
Tools Used:
Small Flat head to remove the trim surrounding the Driver Side handle
10mm Socket and Rachet to remove the Oh Sh*t Handle
Assorted small Allen Wrenches (forgot what size to use, but easy to figure out)
Test Light
My Install time: 30 Minutes. Your time may vary.
Installation Difficulty?: If you can install an intake system, this should be a walk in the park.
Programming the Unit?: Just YES or NO questions, You can increase you RPM, Speed Limits etc. But i didn't mess around with it. Until you figure it out, just use the basic settings.
My setttings: Performance, 2* degree timing advance, NO WOT. Throttle Adj HIGH.
Once you have your BullyDog / Ram Mount on, you can re-mount the mirror in reverse order. Pull down slightly on the headliner and run the BullyDog 5' HDMI extension. I have a auto dimming mirror so it came with the wire cover, re-install that as well if you have it.
Remove the Driver side handle with a 10mm socket, pull the liner/weather stripping from the door and pull aside the plastic pillar moulding. NOTE: Some trucks come with the Side Air bags so you need to run this between the A-Pillar and the air bags so if they deploy the HDMI cable does not interfere with it. Connect the supplied cable of the BullyDog into the extension cable and run it towards the OBDII Port, Plug in OBDII Adapter Plug into the Port and attach the HDMI Main WireHarness from the BDGT. The OBDII adapter has a switch to power up your unit but you would have to turn if on/off all the time.
I choose to use, The GT/Watch Power Wire. It connects into the OBDII adapter and you run that wire down and behind the A/C unit / Center Console. I used a wire coat hanger to push it thru the backside from the driver to passenger side, Once you push the wire out string it along towards the passenger fuse box compartment.
I had a Test light and choose the RADIO fuse that is controlled by the Key. Pull the fuse with the factory fuse puller, insert the wire and push back the fuse. It's tedious but easy to do and now the BDGT now turns on with the key instead of the switch on the OBDII adapter.
Re-read your BullyDog instruction sheet and/or Retrace your steps, making sure everything in place. It should power up with the key and backlit lighting will change with the lights on.
Put all your panels back in place AFTER checking power and you should be all good to go.
BullyDog BDGT has a driving coach to tell you that you are abusing the power (i.e. wasting gas) and you will see your actual MPG. The settings can be easily changed and you WILL notice a big difference. You DO have the option to shut off the coach and the beeping off. ~I Did. Who drives light footed? Lol
My opinion hands down is the BullyDog BDGT, though... HyperTech & SuperChips has a comparable item but the coolness factor of the watching all the temperatures at a glance not to mention your MPG (-/+) differs with driving style.
__________________
San Diego, Cali. 2006 Nissan Titan LE CC 4x4 PICS
Bully Dog PP, DDM HID 5K Low Beams & Fogs, Armada Air Dam
DR Coilovers, Total Chaos UCA's, Bilstein Rear Shocks. Foose DF-6 22" Black,
Stillen Front Sway Bar, Stillen Big Brake kit, AMP Research steps, GrillCraft.
Still amazes me that something small can pack such a BIG punch!
These guys are Great! and such a good price.
__________________
