popping noise? - Nissan Titan Forum: Club Titan Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Nissan Titan Forum: Club Titan Forums > Mods and Technical Discussions > Suspension
  #1
Old 01-28-2013, 04:22 PM
2010titan 2010titan is offline
Shift_lurker
Exclamation popping noise?
i've already seen SEVERAL threads about this issue, just no real answers...
at very low speeds (either at a stop or when backing out or pulling into my driveway) when i cut the wheel i hear a loud popping coming from the front. also when i first start the truck, if i havent driven it yet that day, there's sort of a creaking from the front too (though this isn't as big of a worry to me as the popping)
also, the other night i took the truck into a little mud. i drove a few feet into the mud, decided to shift into 4lo, and when i did i heard a loud beep as i put it into 4wd (it has never done this before) and when it beeped, the little icon on the gauge cluster which has a picture of a truck suspension (the one that highlights either 2 or 4 wheels to show whether you're in 2wd or 4wd) disappeared. i pulled out of the mud onto level ground. When i tried shifting back into 2wd, it beeped continuously until i shut off the truck. i waited a few minutes and restarted the truck, and the beeping had stopped and the truck went perfectly back into 2wd.
does anyone have ANY idea what the hell happened? did this happen because i wasn't on level ground when i shifted into 4wd?
thank you VERY much to whoever responds. pretty worried about both of these issues
dylan
  #2
Old 01-28-2013, 09:48 PM
HRTKD's Avatar
HRTKD HRTKD is offline
Shift_Obsessed
No, you don't have to be on level ground to shift the transfer case. Check your brake fluid reservoir. It's possible that it is low. Low brake fluid has been known to cause 4x4 issues or warning lights.
__________________
Club Titan Rosetta Stone
Jim
  #3
Old 01-29-2013, 01:30 AM
cjoh101's Avatar
cjoh101 cjoh101 is offline
Shift_Newbie
popping noise?
The popping noise could be a worn out cv axle or tie rod end.
Sent from AutoGuide.com App
__________________
2005 Titan LE CC 4X4 Galaxy Black
OBX headers
Walker b-pipes
Magnaflow y-pipe 2.25 DI/2.5 SO
Magnaflow 14" muffler 2.5 SI/SO
2* timing advance
Stock air box mod
Titan popping noise??? Supralative Technical Discussion 3 03-06-2011 11:34 AM
Loud popping noise and then clunking noise in driver's side rear suspension Greg_Mullins Technical Discussion 5 11-20-2010 03:01 PM
Need help with a popping noise. skeet General Discussion 17 03-19-2007 08:20 AM
Popping noise in the front end kentc1978 General Discussion 5 02-22-2007 04:36 PM
Popping noise Nabors Technical Discussion 1 01-16-2007 06:37 PM
Powered by vBulletin®
