Black transmission fluid less then 10k on my truck, wow - Nissan Titan Forum: Club Titan Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 02-04-2013, 01:05 PM
Tonyv46 Tonyv46 is offline
Shift_lurker
so as i said i had problems with my dealer
and i decided to take it on myself to change the fluid in the transmission
i used dexron3 temp till i get some amsoil
when i started the process i wasnt prepared to see what i did
it was solid black fluid looked like engine oil and smelt like burnt clutch
the pressure line goin to the rad cooler was the fualt it had come off(clip wasnt in right location) i drove like this not knowing
and i lost about 3-4quarts of fluid
and didnt have a problem till it started slipping
and wouldnt engage into gear till i let it cool down
should the dealer be held responible for not checking this line i have just slightly over 10k on my truck now
and my concern is that the friction plates are toast and the steelies between the plates are scored even blued
this should be covered under warrenty right ?
and 33s and 3inch leveling kit shouldnt do anything to void this ?
  #2
Old 02-05-2013, 09:10 PM
WhiteDuke WhiteDuke is offline
Shift_lurker
My stock tires are pretty close to 33's. I have no real world experience with warranty issues like this, but I can't see it causing thAt type of premature failure. I hope it is covered for you. Please let me know what is said
  #3
Old 02-05-2013, 10:38 PM
HRTKD's Avatar
HRTKD HRTKD is offline
Shift_Obsessed
Should be covered. But I wouldn't be using dexron3. Put actual Nissan fluid in there before you take it back or they might say the dexron caused the problem. I run AMSoil in my Titan's transmission without any issues.
__________________
Club Titan Rosetta Stone
Jim
  #4
Old 02-06-2013, 10:57 PM
Misfit482's Avatar
Misfit482 Misfit482 is offline
Shift_Enthusiast
I've heard of some dealers being real strict about stuff as simple as a leveling kit or larger tires. Hasn't been an issue with me for warranty stuff. Like HRTKD said, put some Nissan tranny fluid in there before you take it in. Is the Dexron you used J-matic approved? I forget which years used a different fluid type.
__________________
'07 CC 4X4 banks ram air w/ tb screen removed, banks monster exhaust, prg minilift, PRG UCA's, PRG endlinks, 5100's all around, DK shackles, EBC brakes, headlight mod w/ JB switcbacks, Legit 55w 6000 hid's (lows and highs), modded tail lights, street scene grille shell, xd diesel 20x10 w/ terra grapplers, pinch weld mod, axle vent mod, BW pocket flares, PD'd stuff, BL step rails, SM designs bezel kit
  #5
Old 02-10-2013, 08:45 AM
Shift_lurker
I'm taking mine back to the dealer tomorrow.friday it got stuck in 4 low for about 45 minutes. I tried everything. Even unplugged the battery for a while. Finally, I turned it on and put it in gear and never engaged. I put it in park and heard a shaft grind to a stop. It was not neat. Mine is a 2012. I hope trans is okay. But I definetly need my transfer case to work.
Transmission fluid help!! whitetitan01 Scheduled or Preventive Maintenance 15 01-30-2009 08:38 AM
transmission fluid mark General Discussion 0 10-08-2007 09:43 PM
Transmission fluid KING TITAN General Discussion 9 05-08-2007 09:11 AM
how to read the transmission fluid? alohaarg Scheduled or Preventive Maintenance 14 03-15-2007 03:20 PM
transmission fluid leak Magnum General Discussion 1 12-30-2006 12:50 PM
Powered by vBulletin®
