Checking 4wheel drive - Nissan Titan Forum: Club Titan Forums
» Auto Insurance
» Featured Product
» Wheel & Tire Center
  #1
Old 02-24-2013, 04:25 PM
91wm6 91wm6 is offline
Shift_lurker
I'm loking at an 06 Titan crew cab 4x4 tomorrow with 91k miles. Any specific procederal recommendations for testing 4 wheel drive?
  #2
Old 02-24-2013, 04:41 PM
04offroadtitan's Avatar
04offroadtitan 04offroadtitan is offline
Shift_Fanatic
Take it up a snowy hill on your test drive. That's what I did when I bought my 04.
Sent from AutoGuide.com Free App
__________________
New ride: 2010 Crew Cab Pro-4x; Volant Powercore intake; Magnaflow muffler swap
Coming Soon PRg leveling kit
Old Ride:2004 King Cab LE with Off-Road and Big Tow
PRG Leveling Kit, JBA Cat-Back Exhaust w/ SLP Loudmouth muffler,New Volant Powercore Intake,2 degree advance,Axle Vent Mod, Stillen Differential Cover w/M1 75w-140
Other rides: 2008 Armada SE; All stock and will probably stay that way since it is the wifes. We'll see.
2004 Dodge 1500; Wifes first truck so we kust kept it. All stock.
1972 Ford F100 Ranger XLT; 360 with cam, headers, edelbrock 600, Edelbrock Al. Intake, straight pipe dumped below cab. Its loud. (thinking about possioble VK56 swap in the future when done with school)
  #3
Old 02-24-2013, 05:08 PM
NBhunter80's Avatar
NBhunter80 NBhunter80 is offline
Shift_Enthusiast
Check the front and rear axles for signs of fluid which indicate seal leaks. Front dif pinion seal leaks are common, and also check where the front axle meets the dif for any sign of fluid which may indicate that the front axle has pulled out of the dif. Check the rear axle and brake rotor dust shield for signs of fluid, and also the rear pinion seal. Make sure the rear axle vent isn't clogged (if the cap spins, it is not clogged). As far as testing your 4wd, you can check if it is working by going on a snowy road, dirt road, or even on some grass. Make sure you test both 4 high and 4 low, and ensure the transfer case shifts smoothly between the two. If the truck has the offroad package, test out the e-locker as well. Give it some gas in 4x4 to ensure it hooks up well, but also drive really slow with the windows down and listen for any popping, whining, or any abnormal sounds from the difs or transfer case. If there are any fluid leaks or whining, popping sounds from the axles, I would walk away from that truck. Good luck!
__________________
2005 LE King Cab 4x4 Offroad Big Tow FFV, Purchased used on 2008/11/30.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, 33 x12.50r17LT Hercules Trail Digger tires on OEM OR 7-spoke 17" rims, 3" Rough country Lift, Bilstein 5100s front and rear, Hawk LTS brake pads, MOOG lower ball joints, 2011 Pro4x rear end, Axle vent mod, NGK iridium spark plugs, 2 degree timing advance, Stock airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
Engage and disengage 4wheel drive??? HeavyMetalTitan Technical Discussion 3 12-28-2009 12:48 PM
Might be Checking out! SiMpLyMoDiFiEd General Discussion 14 07-22-2009 12:20 PM
Pictures of 4wheel part event in SA d0va Off Topic 1 11-12-2007 10:55 PM
Just Checking In NavyTitan New Member Introductions 24 12-09-2006 02:41 PM
4wheel indicator lamp ayuh General Discussion 0 07-02-2006 09:01 PM
Powered by vBulletin®
