2005 Titan LE - Nissan Titan Forum
post #1 of 5 Old 06-27-2019, 10:16 AM Thread Starter
BuddyB
Shift_lurker
Quoted: 0 Post(s)
2005 Titan LE
Hi everyone. Changed out all four rotors recently. The front calipers are held in place with 2 bolts which require a 21mm socket for removal. It took a breaker bar with a 3 ft cheater pipe to remove the bolts. They appeared to be installed with permanent Locktite. Service manual I have recommends that they be replaced once removed.
Nissan dealership parts do not show nor list these bolts in their computer system.
Any ideas on where to purchase new bolts. They have to be torqued to 165 ft lbs.
thanks
BuddyB is offline
post #2 of 5 Old 07-03-2019, 07:38 PM
Morrellp
Shift_lurker
Quoted: 2 Post(s)
I reused the bolts and used blue loctite. I had to go to Nissan for a bolt in the past.
Morrellp is offline
post #3 of 5 Old 07-03-2019, 11:33 PM Thread Starter
BuddyB
Shift_lurker
Quoted: 0 Post(s)
Quote:
I basically did the same thing. Used Blue Locktite and reused the bolts. Only concern the bolts being torqued twice now and eventually cracking. Nissan did not show the bolts in their parts listing. And I forgot to mic the diameter and measure the length before I reinstalled them.
BuddyB is offline
post #4 of 5 Old 07-04-2019, 03:59 PM
Morrellp
Shift_lurker
Quoted: 2 Post(s)
I am in Canada and contacted the dealership and the bolt was only $7.00
Morrellp is offline
post #5 of 5 Old 07-06-2019, 07:58 PM Thread Starter
BuddyB
Shift_lurker
Quoted: 0 Post(s)
Can you provide a part number?
BuddyB is offline
User Tag List
Linear Mode Linear Mode
