Airbag blinking light wont reset!!! - Nissan Titan Forum
post #1 of 6 Old 04-14-2013, 10:24 AM Thread Starter
zalez
Hey everyone and thanks for your answer in advanced.
I have a 2008 Nissan titan and the airbag blinking light wont turn off(reset).
I tried the "turn key on and off for 5 seconds" and it wont work.
At first the light was blinking fast and after i did the reset "key on and off"
the light blinks slower and thats as far as i got. The light is still on just blinks slower now.
Can some one advise pls.
Thanks!!
Daniel-zalez
zalez is offline
post #2 of 6 Old 04-14-2013, 02:08 PM
Scottysize
Scottysize's Avatar
Quoted: 3 Post(s)
Taken from "The Other" site, because I know where it is, but haven't looked on here.
If you have the airbag light, it will show steady for a few seconds (the manual says 7 secs) after you turn the key from off to on (but not start) and then start to flash. Here is how to reset it:
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
If it does not work the first time, just repeat the steps again.
If you have an actual problem with your air bag system, you can count the blinks in diagnostic mode and perhaps narrow down the problem.
I got the below information here: http://www.nagtroc.org/forums/index....=&showentry=31
The SRS airbag light on the driver console can be used to read SRS specific trouble codes on the GT-R without the use of a Consult-III device.
There are 2 modes of operation for the SRS indicator light, the normal every day one called "User Mode", and the more advanced "Diagnosis Mode".
Normally, the car always operates in Normal mode. That is to say, the light goes on for 7 seconds (if it doesn't, that's a fault code as well, or your lamp's burnt out) when the ignition is put to "ON", then one of these things can happen:
The light turns off (indicating all is OK!) and at this point, you cannot go in "Diagnosis Mode" (that advanced mode is only available when there's an actual trouble code)
The indicator stays on. Which means you should take cover because it indicates an airbag has deployed or a serious malfunction is occurring.
or finally, the indicator blinks in 1/2 second pulses, indicating there are SRS fault codes to be read
If you did something like change to aftermarket seats on a Premium (US) or Canadian car, you will lose the side airbags in the seats, and this will trigger an error code.
To read the actual malfunction code while trying to fix the issue (not going to detail that part here), you have to put the vehicle in SRS "Diagnosis Mode". Again, this can ONLY be done if you have condition #3 listed above.
Follow these steps to go from "User Mode" to "Diagnosis Mode".
Using the starter button, put the car to "ON" mode (without starting the car. Do not press the brake pedal).
The SRS Light will light up for 7 seconds. As soon as the SRS light goes off, turn the car off (before the quick 1/2 second error blinks appear)
Wait more than 3 seconds (count to 5!)
Do step #1, #2 and #3 two more times (you must do it three times total)
Put car to "ON"
At this point, if everything went right, you will now be in SRS "Diagnosis Mode". How to tell?
The SRS light will now light up for 7 seconds as usual, but then instead of blinking, it will either light up again for 3 seconds (A series code) or 2x 1.5 seconds (B series code) before flashing a 1/2 second error code and repeating again.
From that point on, your car will stay in SRS "Diagnosis Mode" until you clear all SRS error codes and turn the ignition off.
If there are still SRS error codes present when you shut the car off, it will come back in "Diagnosis Mode" whenever you put ignition to "ON". To get back to the regular "User Mode" without having to fix all the SRS errors, you must simply follow the same above steps #1 to #4 again, and the car will revert back to "User Mode".
Ok, so now you're in "Diagnosis Mode" where you get the initial 7 second SRS light followed by either a 3 second blink or 2x 1.5 second blink, then blink codes. All the codes will repeat sequentially so you should note them down (eg: 3 second light, 2 blinks, 3 second light, 5 blinks, 1.5 second light, 1.5 second light, 6 blinks, etc etc) . If you lose count, just turn the car off and then back to ON as it will stay in "Diagnosis Mode"
Here's the table for the blink codes that come after a 3 second blink:
0 blinks: Self-diagnosis result is not deleted
1. Front LH seat belt pre-tensioner
2. Driver air bag module
3. Front RH seat belt pre-tensioner
4. N/A
5. Occupant Classification System control unit
6. Crash zone sensor
7. Air bag diagnosis sensor unit
8. Front passenger air bag module
9. N/A
10. N/A
11. Front passenger air bag OFF indicator
If you've removed your OE seats with side airbags and need to check if the SRS error code is related to either passenger or driver side module, the following series of blink codes associated with the 2x 1.5 second SRS light are the ones to look for ( #1 and #2):
Here's the table for the blink codes that come after 2x 1.5 second blink:
1. Front RH side air bag module
2. Front LH side air bag module
3. RH satellite sensor
4. LH satellite sensor
5. RH side curtain air bag module
6. LH side curtain air bag module
If you're troubleshooting an error code and think it has gone away, you can turn the ignition off and back to "ON" to reread the diagnosis codes. If you happen to clear all the codes and turn the ignition Off, the car will AUTOMATICALLY go back to "User Mode" since there are no more user codes.
There is also a recall NTB07-009 on a rear KC door wire harness that can result in an air bag light.
VOLUNTARY RECALL CAMPAIGN 2004–2006 NISSAN TITAN REAR DOOR HARNESS
Nissan has determined that on some 2004 – 2006 model year Titan King Cab vehicles, a defect that relates to motor vehicle safety exists.
In some affected vehicles, there is the possibility that the wires in the harness routed through the rear doors and into the body on each side of the vehicle may break due to over bending of the harness as the doors are opened and closed. The wires in the harness control various systems including the seat belt pretensioners, the passenger side seat belt tension sensor, and rear audio speakers.
If the wire for the seat belt pretensioners breaks and makes contact with a wire for the speaker, there is a possibility that the pretensioner may deploy and tighten the seat belt. If this happens when the belt is retracted, it will not be possible to use the seat belt. If one of the wires for the seat belt tension sensor breaks inside the passenger side harness, the passenger side front air bag will not deploy as designed in a frontal crash. Nissan is conducting a Voluntary Recall Campaign to inspect the wire harness cover for damage and, if necessary, a new wiring harness with a new type cover will be installed and
rerouted.
BROKEN SPIRAL CABLE:
If the steering wheel is turned with the steering linkage disconnected, it frequently breaks the spiral electrical cable in the steering wheel. The symptoms include airbag light on, horn & cruise control don't work. This frequently happens during header installation due to turning the steering wheel after disconnection of the steering shaft in the driver side wheel well area. WARNING: ATTEMPTED REPLACEMENT OF THE SPIRAL CABLE MAY DETONATE THE AIR BAG IN YOUR FACE. Make sure you know what you are doing before attempting replacement of the spiral cable.
Gone
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
: 2012 SV CC Brilliant Silver/Charcoal Cloth 4X4.
Mods it Had:
| LINE-X |
Final Fuelly for 2012 T:
My 2014 Passat:
2008 Bimmer:
Scottysize is offline
post #3 of 6 Old 06-26-2016, 09:31 AM
08 Titan XE
08 Titan XE's Avatar
I tested mine yesterday and it says that the drivers side airbag module is bad, how can these just go out? No crashes, nothing moved since I put in new steering wheel radio control several years ago as well as a new radio
Thanks in advance
08 Titan XE
2008 Titan XE CC/SB, Adopted 11/07, Radiant Silver 4X2, prefered package, 6 disc CD changer, key less entry, 6 spoke alloy 18" wheels, Nissan step tubes, Nissan tow hitch, Factory Bed Liner, S&B CAI, Power Aid TBS, Magnaflow 18" muffler swap, 4" rolled tip, 2* Advance Timing, Scangauge II, LE Big Tow Mirors (non-power), Kicker speakers, 6.9" front, 6.5" rear, RE-Q5, Sony 4 channel Amp, MX 2 channel Amp. 2 under seat subs w/enclosure, Bullydog PP, Steering wheel audio controls, and Burn-out Mod.
Lovin It
<a href="
" target="_blank"><img
08 Titan XE is offline
post #4 of 6 Old 08-02-2018, 10:00 AM
jcl541
I know this thread is a couple of years old, but I just ran into this problem. If I don't get a reply here, I'll try posting a new thread.
I have a 2016 Nissan Pathfinder. I was futzing around with the cable under my dash (above the pedals) that connects to a brake controller (for towing my camper). The brake controller usually sits in the glove box because I rarely tow. Anyway, after I got it connected, and the cable slack tucked back up the dash under so it doesn't hang down by my feet, when I started the car, all of a sudden the airbag light is on :-( I figured I probably just jiggled another something up in there related to the SRS system. On cursory investigation, I can't find anything obviously wrong, so I put it in diagnostic mode and I get a code of one long blink and 4 short blinks (yeah, N/A - not very helpful). The blinking is not resetting, so whatever I may have accidentally done is probably still "done"
Any advice on what I might have accidentally done, and how I can fix it? Thanks.
-J
jcl541 is offline
post #5 of 6 Old 08-02-2018, 01:41 PM
jcl541
working now
For the record, I put it into and out of diagnostic mode 3 or 4 times (after jiggling various wires and things) with no discernible effect, even after a ~30 minute break. The vehicle would stay in diagnostic mode if I didn't explicitly return to user mode using the same method - supposedly it will go back into user mode automatically on next start if there was no actual error code.
However, after a two hour pause I decided to drive it without having fixed the error-code, and the error code was miraculously gone! No idea why, or what that code (single 3 second blink, 4 short blinks) actually means.
For now, all is good.
-J
jcl541 is offline
post #6 of 6 Old 05-23-2019, 10:09 AM
Raykam
Tried the above now stays on 7 seconds followed by 3 fast blinks. What does this mean?
Raykam is offline
airbag light flashes and pass airbag off light is on rockroper General Discussion 3 07-08-2011 01:10 PM
Airbag sensor reset dkavetski Technical Discussion 5 03-27-2011 08:50 PM
How To - Reset Your Airbag Light QWIKWHIP Do it yourself, Tech Tips 45 03-28-2009 12:03 AM
reset airbag ?? pinecone Technical Discussion 1 03-06-2006 07:59 PM
Airbag Light blinking mysetitan Interior Mods 11 05-24-2005 08:59 PM
