I fish a lot and back into the water at the boat ramps, After doing the 40,000 mile maint. I found water in the diff. Of course I replaced with new oil. Now she's humming pretty good. Any sugg. on buying a used diff or having bearings replced. I found an 09 4x4 diff still waiting on a price. Is it the same as my 07?
Thank you for reading.
Jeff ( Best truck I've ever owned!!
What fluid did you use? Seems like a drain and fill would take care of that as long as you got the right stuff ( nissan diff 75-140 I think) I just had a quote for 700 to replace all bearings in pumpkin two on pinon,four on carrier, please someone correct me if wrong. Good Luck and Greeting to CT. or do this http://www.ringpinion.com/b2c/ProductDetails.aspx?ProdID=10624&Product=YGLNTITAN-32&Brand=Yukon_Grizzly_Locker&ShowAA=True&Year=2004&Model=Titan&DriveType=Rear Diff - 4WD&DiffId=92&Source=DiffWizard
Sounds to me like you caught it in time. I'd recommend doing the axle vent mod to prevent it from happening again.
